Question about Zebex Alpha-70 Handheld
Stopped scanning Hello, I have a Curves fitness facility and have the GoFigure member software system. We've been using the Zebex Alpha-70 barcode scanner to scan members' keytags for almost 5 years now. It has recently stopped scanning. The light is still red, but it won't read anything.
  • swtyhd1 Jul 12, 2008
    I have the same scanner for a Curves fitness center with igofigure software. It has the red light and will also beep when a keytag is held under it, but it does not register in the program or on the computer's notepad.
  • CurvesKs Dec 11, 2008
    Help! When we upgraded to iGo 3.6 at Curves, the keytag scanner stopped working! What do I do?
  • 25 Answers
I seldom do this ...but I will comment on the Zebex scanner. This is ...errr ... not the best choice for future scanner needs. I will never forget commercial Zebex experience. They should have stuck to anti freeze (just kidding).
However if it did work and now doesn't there is one problem that is so obvious no one thinks of it ... check the clear plastic protector on teh front and see if it need cleaned. Greasy environments usually fog it over time.
I have the Zebex default codes somewhere in the shop ... but you can replace that scanner with a nice PSC, Mot, or Intermec for about 120.00 why not do that?
Posted on Jan 09, 2008
Driver Needed
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you
might see a yellow? ! question exclamation mark or red X this will mean you need to install a new driver for this device
right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options you can troubleshoot
hope this helps
Jul 15, 2012 | Zebex Alpha 70 (93086)
Need driver for z-3051hs barcode scanner
Hello. The problem will get resolved by going on the links below and download the driver for your Z-3051HS Barcode Scanner.
LINK 1 (Auto Sensor Standard Firmware Version 1.10)
LINK 2 (Standard Firmware Version 1.10)
The links above belongs to ZEBEX official website.
Easily save the file to your computer. Run and install it properly.
I hope I helped!
If you have any other questions, please leave a reply.
Thank you for using FixYa!
May 31, 2011 | Zebex ZBA Z-3051HS Barcode Scanner - P/N...
Installing the Zebex z-3010
Normally, these scanners need no software, as they simply send a series of digits to the active text box. Try opening notepad or word and scanning any barcode. It should type the number itself.
Apr 14, 2010 | Zebex Z-3080 Handheld
WHERE CAN I DOWNLOAD ZEBEX Z-3080 SCANNER SOFTWARE?
This device needs no software. You first need to set it up with the configuration card (http://www.zebex.com/old_website/documents/quick_program_card/z-3000.3001.3010/Programming%20Card_U_090202.pdf). Then it should scan the barcode number in to the selected text area.
Mar 24, 2010 | Zebex Z-3080 Handheld
Alpha 70 Series is not working after disconnecting PC and recnctg
Hello Suzanne. The problem you are going to find here is that Zebex doesn't make this model anymore and haven't for some time. If the unit has power and emits a beam, I have the Zebex generic Programming Card and Programming Guide available on my company's website. Have a look at the sections that include the "reset default" barcodes. Print out that page and try scanning them with your scanner. Resetting the scanner to it's default programming may get everything ironed out. If the scanner doesn't have power or emit a beam, then unfortunately you will be looking at getting a replacement scanner. I can recommend several different scanners what would work fantastically and be quite cheap. If you still need help, please feel free send a message or email me. I hope this helps. Good luck!
Dec 28, 2009 | Zebex ZB 2200AM
My scanner scans different numbers to what is on
Firstly, You must be reset scanner.
for reset,
to find programing manual.
if you don't have it.I can send to you.
1. scan start of configuration barcode
2. scan reset barcode
3. scan end of configuration barcode
best regards
Ufuk
Mar 07, 2009 | Zebex ZB 2200AM
Barcode scanner
please get programing manual for Z-3080 then
scan start of configuration barcode then USB emulation barcode then end of configuration barcode
probably your problem wiil be solved.
Nov 01, 2008 | Zebex Z-3080 Handheld
No code appear after I scanned the barcode.. Please help!
First of all,have you tried using a notepad ? just to verify that your scanner connected correctly to your pc If it's fine then you should find out if there's an enabled properties of your object such as text box, combo box, that was set to False,change it into true.
Aug 22, 2007 | Zebex 90940-RS232-9 Handheld
Zebex Z-3080 - prefix ? software ?
Please download the Programming Guide from the link http://www.zebex.com/documents/Users'%20Manual/A.Handheld/Programming%20Guide%20(MUL-53221-07).pdf.
Attached please find the samples for programmings.
Aug 15, 2006 | Zebex Z-3080 Handheld
Zebex Alpha-70 Handheld Logo
332 people viewed this question
Top Zebex Computers & Internet Experts
David Payne
David Payne
Are you a Zebex Computer and Internet Expert? Answer questions, earn points and help others
