Question about Dell 810 All-In-One InkJet Printer
Dell 810 giving Incompatible Ink Cartridge error message
I have a Dell 810 All-in-one inkjet printer. After getting fed up paying Dell's high prices for replacement ink cartridges, I purchased a compatible ink cartridge from somewhere else. I worked fine and I had no problems printing. It started getting low on ink and all of a sudden I started getting "Replace cartridge" messages. I bought another Dell cartridge from Dell this time and installed it. Now the printer won't print and keeps popping up an "Incompatible Ink Cartridge" error screen/message. I tried uninstalling and reinstalling the printer but toward the end of setup, the incompatible message popped up again and I can't use the printer. There is a Dell cartridge in the printer! I know (NOW) that I shouldn't have used a non-Dell cartridge but how can I fix this problem? I don't want to throw the printer away but it's looking like that may the solution right now. Any help?????
  • 1 more comment
  • Anonymous Mar 06, 2008
    I have the Dell 964 with the identical problem, I was able to switch back and forth with the old cartridges refilling them and resetting the machine as in the first tech repair. This made the printer work with the refills. Thanks for tech tip.
  • Anonymous Mar 12, 2008
    I have HP C6180 photosmart all-in-one and installed a compatable ink cartridge and error noted as "replace empty cartridge" and I know it is
    a new cartridge before the replacement the printer would at least print in
    black not color and now I have replaced with a original mfg cartridge and
    now will not print at all. what is the solution? frantic as I can not print out
    a refund form for the ink in errror that caused the problem to start with.
    jwayne9742@yahoo.com
  • Emjabr Mar 28, 2008
    I've had exactly the same problem described above with my Canon Pixma
    MP210. I've tried the solution above, but i'm still getting the same
    problem. Also, I've tried trying to print with only the black cartridge
    (which is an official one, unlike the refilled colour one), and this
    still doesnt work - it says that both the blank and colour cartridges
    are "incompatible", even when the colour cartridge isnt in, and the
    settings have been changed to printing only with the black cartridge.
    Any ideas?
I've had this same problem with my Dell 924 printer. I've tried all of the mentioned solutions and none worked. Paid almost $60 for 2 new Dell brand Ctg. and the printer still says "Incompatable Cartridge". It seems as though Dell is punishing me for not buying their supplies and they have disabled my printer. This should be illegal since the printer belongs to me, not Dell.
Posted on Dec 09, 2009
    Genius:
  • 1,142 Answers
Hi try these steps
STEP: Disconnect and Reconnect the Printer Power Supply
Top of Form 1
Bottom of Form 1
Unplug the power cord from the wall socket.
Disconnect the power supply from the back of the printer.
Wait 15 seconds.
Reconnect the power supply to the back of the printer.
Plug the power cord back into the wall socket
STEP: Clean the Contacts and Wick the Ink Cartridge
Ensure the printer is powered on.
Lift the scanner unit.
Open the cartridge latches and remove the cartridges from the carrier
Take a clean, damp cloth and wipe the nozzle of the print cartridge from front to back.
Turn the cartridge so that you are looking at the contacts on the back side of the cartridge
Using a clean dry cloth, wipe the contacts so that no dust or other contaminants are visible
Clean the contact inside the printer with the dry cloth used to clean the cartridge contacts.
Replace the cartridges in the carrier and close the scanner unit.
STEP: Verify Each Cartridge Carrier Has an Ink Cartridge
Check to make sure the left cartridge carrier contains a black or photo ink cartridge.
Check to make sure the right carrier contains a color ink cartridge.
Remove each cartridge and examine it to make sure the protective tape has been removed from the contacts and the print head.
Replace each cartridge in the proper carrier.
Let me know the status.
Regards
Posted on Feb 09, 2008
2 Suggested Answers
  • 59 Answers
SOURCE: Dell 810 All-In-One InkJet Incompatible Ink Cartridge error message
Well, first off ,it's dell's fault, not yours. Even Official Dell cartridges are temperamental at best. The cartridge error you are explaining is common with Dells. They even have what's called a marriage issue, meaning the cartridge will work in only one single printer. However, I'm not sure how to fix it. Sometimes, you can install a new one and the other cartridge you never touched gives you fits, and goofs up. I'd say get a new printer. Dell is increasingly getting more stingy with their ink, and truth be told, I don't think their quality (*lexmark makes dell, so stay away from them too) matches HP or canon. If you want the best cost per page, get a canon that has individual ink cartridges. They are easy to refill, and print a great picture. You pay more $$ up front, but you'll save a ton in the long run
Posted on Jan 07, 2008
I get a cartridge missing message in a Dell 810 printer
I am having the exact same problem. Just got my cartridge refilled, and whenever I hit the print command, I keep getting the message "printer cartridge missing." It's obviously there! gaahhh, so annoying! I hate dell.
May 09, 2010 | Dell 810 All-In-One InkJet Printer
Printer giving 'incompatible ink cartridge' message
replace your cartridge with a new one or refill others old
check here how you can do it your self
utube.png You-Tube video "sOriLrbuBao" placeholder (do not delete) utube.png
utube.png You-Tube video "II9gpIXs_lE&feature=related" placeholder (do not delete) utube.png
Apr 16, 2010 | HP Officejet 5610 All-In-One InkJet...
I had my ink cartridge refilled, and now the
just clean the printhead contacts
if you see no result
you must change the cartridge
Apr 02, 2010 | HP DeskJet F4280 All In One Printer InkJet
What is a incompatible print cartridge? Its coming up with a warning exclamation mark and it wont print?
What is a incompatible print cartridge? The printer "Thinks" that the print cartridge, is NOT an original HP PhotoSmart one. Even print cartridge have chips.
Mar 28, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
Dell 810 printer showing "Incompatible cartridge" after cartridge
Return it! refilling cartridges often void your warranty. Not to mention the cartridges that come with the printer are usually 1/3 to 1/5 filled making you think that the new ones are over priced. Use original.
Jan 23, 2010 | Dell 810 All-In-One InkJet Printer
Printer is blinking. I installed a new ink
Sounds like your cartridge may be unseated or it is really incompatible. You do not state clearly that you have printed successfully with this cartridge before.
Oct 12, 2009 | Dell 810 All-In-One InkJet Printer
Dell 944 all in one - used NON-Dell Print Cartriges - Cheaper
Hi there
Your error message is coming from the Dell Series 5 ink Cartridge. To reset the error message, unplug the printer from the wall. Now remove the power brick from the back of the printer. Wait 60 seconds and then plug everything back in. This usually resets any error messages on the printer. Make sure the Dell Series 5 ink cartridges are intalled correctly by removing them and re-seating them .
Black in left or black side, color in right side or color side
If using a photo cartridge...
Photo cartridge in the black side(left) and color in the color side(right)
Dell Series 5 ink cartridges have a sensor in them that cannot be reset
It is also possible to get a new ink cartridge with a bad sensor. Please take it to the place of purchase for a refund or a replacement one.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Sep 13, 2009 | Dell A940 All-In-One InkJet Printer
Dell 926 printer
Dell cartridge are quite expensive, and refilled and non original cartridge are often not accepted by Dell printer. If you use non original cartridge often you keep getting this message unless you replace both cartridges.
Be also careful also if you use refilled, sometimes refilled can leak all over the inside of your Dell printer right when ink is coming to the end.
In your case try replacing both cartriges at the time, this usually clears the error.
A suggestion: Dell small inkjets are sold at a price often inferior to the cartridge set price, and now you know why, ask the price for a new Lexmark, HP, Epson,Brother, Canon etc. next time you have to replace a cartridge set, it may be worth buying a new printer.
Apart small inkjet sector, Dell produces excellent laser printers, computers, laptops and more.
You can read more opinions on small dell inkjets here or using google.
Aug 18, 2008 | Office Equipment & Supplies
Jan 07, 2008 | Dell 810 All-In-One InkJet Printer
Dell 810 All-In-One InkJet Printer Logo
1,119 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
