Question about Brother MFC-425CN Multi-Function Center All-In-One InkJet Printer
Unable to print Black
I have been using this printer for about a year and it's really good but it true style come the time when it is important it has decided it does not want to print black. Have done several cleaning sessions on it and still not wanting to print any ideas would be great as cannot afford to get a new one.
  • carlnewboult
    carlnewboult Jan 11, 2008
    Thanks for your help on this unfortunatly I did use cheap ink with this printer and now I have paid the price. Still managed to get a HP PSC 1110 for a tenner off ebay and it works fine do you have any views on this printer ?
  • 832 Answers
Do you use generic ink? If yes it can be that the bk channel within the print head is clogged due to wrong ink consistence.
What you can try is this:
1. Make sure that the cart is placed well and the hook secures the cart.
2. press menu then start bk copy then fourtimes arrow-up. machine will be in maintenance mode. press 7 then 6 then 4 then start bk copy. machine will refresh ink in tubes and ph and run some special cleaning procedure. when finished press 7 then 6 then 3 then start bk copy. machine will run a power purge. leave maintenance mode afterwards by pressing 9 then 9. run a test print. if you still cant see bk the ph is clogged and cant be fixed anymore!
Posted on Jan 08, 2008
  • Mix-it-up
    Mix-it-up Jan 11, 2008
    No. I dont have any experience with HP. You can take a look at www.fixyourownprinter.com
    Moe, the webmaster, and other folks there are very common with HP.
I have new photo (58) and color (57) carts and when I print wallet size (9 pics per 8.5x11 photo paper) the first 3 print true color and the last 6 are blue. I have cleaned the rollers and still do not...
hello, you are using the photo color ink cart, have you tried running a cleaning cycle or test print, the reason why i ask, is that maybe 1 of the colors is not printing, the test pages would prove what color is missing, if black not printing, it would print possible blue, or no black at all. i know you have put in new inks, but since the volume of ink in these cartridges run out according to usage, one color might run out before the others, and since black and yellow are the most used colors, without them your prints will show color faults.
Oct 07, 2010 | HP PSC 1350v All-In-One InkJet Printer
My HP Deskjet D4260 printer has been unused for 2 years. I have been told it would be useless to replace dried cartridges, because the inkjets themselves are probably clogged, and therefore the printer is...
That is absolutely not true. The printer you have uses integrated print head cartridges. This means every time you replace the ink cartridges you are replacing the print heads. Throw out the dried up ink cartridges and buy new ones. Your printer takes the HP 74 black and HP 75 color cartridges. There are XL versions of these cartridges that hold more ink and are a better value.
Dec 19, 2009 | HP Deskjet D4260 Printer
Wont print black
This worked for me on C6180
Good luck and let me know
1.Try placing sheet of black text on copy board, and run many copies black only. I ran 25x12 times still no black. Run head clean after about each 50 sheets. Persevered and finally BLACK ink OK
Inkypete
May 31, 2009 | HP Photosmart C7280 Laser Printer
Can't use black cartridge only to print
Unfortunately it is all true.
Personally I would stay away from Lexmark, I am a Canon fan, the MP520 looks real nice, but it's personal choice at the end of the day.
May 29, 2009 | Lexmark X2600 InkJet Printer
Can i print with only black ink?
Yes, but it is not advisable. You need to put ink in the other cartridges because after a bit of time they will dry out and become unusable. You will still get error messages that cartridges are empty.
It is in your best interest to at least put some ink into the other cartridges.
Apr 11, 2009 | Epson Stylus CX6000 All-In-One InkJet...
The ink cartons are full. Printing is not taking place
Hi I think I had a similar problem, I let the black and cyan run down really low. then it took a week to replace the cartridges. The result was no black and cyan. I put in new cartridges and of course no colour.
Solution: Take out the cartridge holder and take a cotton bud and soak all the ink pads in alcohol (no not beer)
I used clear alcolhol from the chemist, the reason for this is it dries out very well after the clean process with no contamination. Give the ink pads a good soak and rinse out in very hot but not boiling water and allow to dry. Then go through the deep clean process in 'printer maintenance'
You may have to do that several time but be patient and it should clear out and start to print again.
MCL
Mar 30, 2009 | Canon PIXMA MP780 All-In-One InkJet...
P210i card printer not printing clearly or like picture at all
Their is really a few reasons for this.
1. Being the most Common. I can not stress enough How
important it is to CLEAN the print head. The surface the contacts the ribbon at the card. Swabs and Alcohol.
1. There may be dust or embedded dirt
on elements of the print head
2. Contrast and/or intensity colors for P310C
may be set to high values. Adjust contrast and
intensity values for in software or with
programming.
Now if photoshop. Ideal you would not print above 300dpi. Due to the printer limitation on dpi.
Some personal tips I can offer are.
To try playing with the advance color setting.
Re size the PSD to 600dpi then print. I will sometime s achieve good results.
When you DO the Black text. Leave it off for the color run. And
Send the card back thru with a black ribbon in the printer.
The thin about this series of printers is. The will not print like you and I hoped for.
See.. A state DL is printed onto a thin piece of plastic that is slightly Larger the a CR80 card. Then is it melted on the the blank card. Thus achieving the true EDGE to EDGE, Your printer and the several I have had. are not true edge. And they are not Hi-resolution printers like The ones at the DMV.
But with some practice and many. I mean many cards and ribbons. One can get close.
If this is the printer that has to work. And you can not get it to work.
Try this tip, But do not use excessive force. and Timing Is Critical.
AT your own RISK!
You have to have lid open.. Dis-sable the switch that stops the printer when the lid is up. Put the card in. and Print. As the card goes under the head. As soon as the head. Goes down to print. Apply some pressure on the top of the head near the front of the fan.
Now if is a CMY ribbon. You have to release pressure so it can let the card go backwards. When the head goes down. Apply Pressure. .
Hope this helps.......
No one has a NEW looking ID. In fact 9 out of 10 Id's are faded.....
Possible a faded look would work....
OUT
I actuall took time and wrote this out for you,,,,,, Hope it solved this question.
Nov 23, 2008 | Zebra P210i Thermal Printer
Ink Cartridge Problem?
Seem to be or a cartridge problem or a printer driver.
disconnect printer from computer
cancel documents in queue
reboot & reconnect printer
Oct 14, 2008 | Epson Stylus C86 InkJet Printer
My HP PSC 1610V All-in-One
hi,
it is not possible to print without a color cartridge even if you are trying to print in black and white.
so i suggest u to replace the color cartridge with a new one and check
thanks and regards
agnel
Mar 12, 2008 | HP PSC 1610 All-In-One InkJet Printer
Printer will not print in Black at all
Had a similar problem.
It turned out to be poor quality ink refills that I bought at the local mall. Found a good ink supplier who charges $4.00 per cartridge.
Try removing the ink cartridge and cleaning with warm water or a little alcohol and a clean soft cloth or swab in the area where the cartridge is seated
Nov 27, 2007 | Epson Stylus 880 InkJet Color Printer
Brother MFC-425CN Multi-Function Center All-In-One InkJet Printer Logo
200 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
