Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Ultimate II is refusing to go into agtation/wash cycle
Whirpool Ultimate II will not agitate. By moving the dial forward I found that it will drain and spin fast. It will aso keep filling with water until I move the switch manually into the agitate/wash cycle. Happy New year!!!
  • tomatolover Jan 08, 2008
    Is the timer built into the control dial? Does anyone know how to test it before I order one to replace. Thank ( :
  • wiskey Jan 14, 2008
    Just replaced the coulper two weeks ago, I smelled plastic burning . It won't agitate now but will fill and spin.
  • 589 Answers
It sounds like a bad timer unit, and possibly a lid switch.
As far as the water overfilling, that may be an unrelated problem, such as the water level switch... but most likely the timer.
I have the same model, and it wouldn't drain.. and it would try to spin when full of water... an interesting sight to see!
Posted on Jan 08, 2008
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Won't drain or spin...just holds the water and will agitate if the dial is moved back. Any ideas?
A blockage in the drain hose if you are lucky. If you cannot hear the motor running on drain/spin but it's o.k. on wash it's likely to be the timer.
May 16, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirpool lsq9244eqo fills and drains but does not spin or agitate
It sounds like the agitator gripping teeth are worn out. To check this, take the agitator cap off with a strong knife or flat-head screw driver, pull the cap off and check the plastice teeth and four plastic hooks that grab the teeth. If they are worn out, then you will have to replace the agitator. To replace it, you will see a nut that is between the circlular teeth. Unscrew the nut and pull the agitator up hard.
Jan 12, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer will not agitate on wash cycle
could be a belt (doubtful) or it could be the connector underneath the. if the bolt isn't tight, it could be sliding along the cutout that makes the agitator work. tip forward and check it from beneath/backside whicheverr has the easiest access to view the connections.
Dec 05, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer fills but won t advance to the next setting for all cycle
Do you hear the ticking of the dial moving? if so it could be that the points aren't getting connection to cycle it threw the various cycles
Nov 22, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II keeps taking water.
ck your drain nose/drainline, chances are you have along hose, perhaps even draining along the floor behind hte unit, into a "closed" drain system. in which cawee the wwater is syphoning out during the rinse cycle, youlll needt o raise the drain hose to above 48" and have it drain into a stand pipe to prevent siphoning effect
Nov 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Replace the timer and your problem is solved.
May 14, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
sounds like the spline is stripped on the agitator take the bolt out of the center of the agitator remove the agitator and visually inspect the splines let me know if this works
Sep 12, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
227 people viewed this question
Dan Webster
Dan Webster
Sal De
