Engine surging - Hyundai Lantra 1.6 GLSI auto est. 1997
Had new alternator fitted and engine began surging and battery boiling - fumes from battery leaking in to car. ? faulty alternator . Replaced alternator but engind still surging when idling and driving. any idears what it might be?
Can faulty alt damage ECU?
    Sergeant:
  • 288 Answers
The battery boiling is a result of the internal voltage regulator in the alternator overcharging the battery. Was it bulged out at the sides also? If the regulator was bad it may have overloaded some of the other electrical systems. It is possible something in the ignition system has been burnt out. I don't think the ECU is bad, as It should have plenty of safeties, like fuses, protecting it. Anything is possible, though, but a bad coil(s) could be burnt, thus giving you the bad idle, the computer is trying to compensate the fuel injection. A plug in with an engine diagnostic machine should tell. If you had a company install the alternator, I would make them give me a new battery and what ever else is bad. If you did this yourself, have a mechanic check it out, and send the estimate to whomever supplied the alternator. You can remove the spark plugs one at a time, leave the wire connected and start the car, see if they are sparking. This will tell you if the plugs are firing, and go from there.
Posted on Jan 07, 2008
    Sergeant:
  • 279 Answers
A faulty alternator could damage the ECU, in theory. I won't say for sure that it has. However, if the alternator is giving out too much power, it could be overcharging the battery. The easiest way to check this is to put a voltmeter across the battery terminals while the car is running. If it reads 15 or higher, you are overcharging.
As to why it's overcharging, it could be a bad alternator. But with the way the engine is revving it sounds like you may be getting a bad voltage read on the electrical system. The ECU thinks there isn't enough voltage, so it sends more fuel to rev the engine and thus cause the alternator to create more power, which boils the battery.
-Dyllan
    Scholar:
  • 48 Answers
You need to check out your voltage and charge regulator. Some are built into the car, and some are external. Check your fuse and relay boxes under the hood for anything blown. You are is not regulating the charge your alternator produces. Whoever installed the alternator is responsible for the charge function working. If you took it to a mechanic then they are supposed to finish the job. Otherwise go to your local auto parts store. Ask them too look up a voltage regulator for your model. Some people don't know how to use that system so go a couple of places to make sure you find someone who can really find your part. When you find the part you can either replace it (recommended) or use a OHM meter to test resistance on both new and old one. If the values are different, then replace the regulator. Let me know if anything in this car is much different than that.
6ya staff
SOURCE:
2005 F250 Battery lite would come on until warmed up, for approx 1 month batteries hold charge under a load. Had to jump start twice and while driving the Dash cluster went wild, IE ~ ABS Lite, A Wrench...
first i would check the alternator just to be on the safe side sounds just like the problem or the brain or body control module went haywire on and sometimes a battery will show that is good untill you actually use it might get a good diagnose from a local shop - dealer etc.
Sep 26, 2013 | 2005 Ford F 250 Super Duty
Where can i get a diagram or pictures of the engine in a hyundai lantra 1997 1.6
You can get that in pieces from the service and repair manual. You can download that for a small fee here.
Oct 10, 2012 | 1997 Hyundai Lantra
Will a 2000 lantra auto fit a 1998 lantra auto
MAKE SURE BOTH ENGINES 1.8 BECAUSE 1999 ELANTRA USED A 2.0 ENGINE. MAKE SURE BOTH ENGINES 1.8 ENGINES.
Jun 19, 2011 | 1995 Hyundai Scoupe
I need the cylinder head torque settings for 1997
1998 Hyundai Lantra "G4GM" engine 1795cc.there are two heads or blocks, one is called the M10, other is the M12, figure out which one you have cause the torque is different for stage one by 5nm........... Dont get confused theres 2 different engines so 2 different torques for stage1---------
heres the full details: Stage 1 - m10 = 30nm / m12 = 35nm-------------------------- -------- Stage 2 - tighten by 60-65 degrees ------------ stage 3 - tighten by 60-65 degrees. no sequence is given in the data book for tightening so go off what you thinks right, it doesn't matter on this engine.
Nov 17, 2009 | 1997 Hyundai Elantra
How do i fit rings to my hyundai lantra 1.8, also wrench setting for engine.
You have to use a ring compressor. Available at any auto parts store.
May 16, 2009 | 1997 Hyundai Elantra
Hyundai Lantra gearbox problems
the lantra gearbox is a Mitsubishi unit and i think it does not have bands just clutches.
Mar 31, 2009 | Hyundai Motor 1996 Elantra
Cant find starter motor on 98 lantra wagon
give autozone or advance auto a try
Feb 10, 2009 | 1998 Hyundai Elantra
Tappett settings
my mechanic told me you cant adjust the tappets on these Hyundais because they have hydraulic tappets.He told me to just use premium fuel to stop the rattle.I use 1/2 premium and 1/2 regular unleaded to make it a bit easier on the pocket.
good luck dude
Dec 16, 2008 | 1995 Hyundai Elantra
I,ve got a problem starting my 97 hyundai lantra 5dr sedan. i think it has something to do with the switch on the cluth, car normally won,t start unless clutch fully engaged,. i,ve got a new battery and...
try pushing the clutch to the floor with you toes if it starts and won't unless you push to the floor its the clutch start switch 22 bucks at auto zone i will be gettng help installing the new one i will let you know.
Oct 08, 2008 | 1995 Hyundai Elantra
Car Bonnet Protectors.
Try contacting a company such as Lebra on this. The company has been around for a long time and should be able to help you out. Make sure you give them all vital information on your car,such as whether or not it has foglights or a ground effect package. They make one style that just covers the first few inches of your hood, and another one that covers the entire nose of the vehicle.
Jul 06, 2008 | Hyundai Elantra Cars & Trucks
Computers & Internet Logo
363 people viewed this question
Ekse
Marvin
Marvin
