Question about HP 1040 Plain Paper Inkjet Fax
Won't receive fax
Rings but will not receive/print incoming fax
  • 1 more comment
  • Anonymous Jan 17, 2008
    Same problem! All outgoing is good! Receiving seems to be a problem. I have been testing the fax machine with Smart Fax internet service. Have been having this problem for a couple years too! I need helpon this
  • Anonymous Mar 30, 2008
    fax wont recieve
  • Anonymous Oct 16, 2008
    We have ours (office) set on line 2. It "says" recieve, but won't print anything out
    I've lost the manual that came with it so am at a loss as to what to do.
Reset RING DELAY so that machine picks up on 1st ring, and does not disconnect before fax can be sent to you.
Posted on Jan 07, 2008
It not receiving with my ring master
Posted on Oct 07, 2008
3 Suggested Answers
  • 2120 Answers
SOURCE: HP640 not receiving with Distinctive Ring Option
You need a dedicated ANALOG phone line.
A DSL filter screens out ANALOG signals to a DSL device.not the other way around. There are no DIGITAL fax machines.
Posted on Aug 31, 2008
  • 2120 Answers
Unplug for 10 seconds. Set to AUTO ANSWER
Posted on Oct 09, 2008
Receiving faxes whilst connected to a phone line automaticly
Check video for 'fax receive set up' in similar model:
Manual receive: In coming call receives like telephone
Fax/tele: Incoming call rings like telephone if its not fax, if incoming is fax it will entered in fax mode automatically
Automatic: Incoming call converts in fax mode after ring count ends( ring to answer option also avail in fax set up mode rage 1-6 rings)
Fax: Incoming calls straight away converts in to fax mode.( this option only for dedicated fax lines)
Set up your best option as per your requirement.
Nov 29, 2012 | HP LaserJet 3050 All-In-One Printer
Hp officejet 6500 instructions for receiving a fax? Thanks
You can receive faxes automatically or manually. If you turn off the Auto Answer option, you must receive faxes manually. If you turn on the Auto Answer option (the default setting), the device automatically answers incoming calls and receives faxes after the number of rings that are specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings.)
If you receive a legal-size fax and the device is not currently set to use legal-size paper, the device reduces the fax so that it fits on the paper that is loaded. If you have disabled the Automatic Reduction feature, the device prints the fax on two pages.
NOTE: If you are copying a document when a fax arrives, the fax is stored in the
device memory until the copying finishes. This can reduce the number of fax pages stored in memory.
This section contains the following topics:
• Receive a fax manually
• Set up backup fax reception
• Reprint received faxes from memory
• Poll to receive a fax
• Forward faxes to another number
• Set the paper size for received faxes
• Set automatic reduction for incoming faxes
• Block junk fax numbers
• Receive faxes to your computer (Fax to PC and Fax to Mac)
When you are on the phone, the person you are speaking with can send you a fax while you are still connected. This is referred to as manual faxing. Use the instructions in this section to receive a manual fax.
NOTE: You can pick up the handset to talk or listen for fax tones.
You can receive faxes manually from a phone that is:
• Directly connected to the device (on the 2-EXT port)
• On the same phone line, but not directly connected to the device
NOTE: The automatic document feeder must be empty to receive a fax. If there are documents in the ADF, then the device will not be able to receive incoming faxes.
To receive a fax manually
1. Make sure the device is turned on and you have paper loaded in the input tray.
2. Remove any originals from the document feeder tray.
are documents in the document feeder, then receiving the fax will be
3. Do one of the following to answer a fax manually:
• Set the Rings to Answer setting to a high number to allow you to answer the
incoming call before the device answers.
• Turn off the Auto Answer setting so that the device does not automatically
answer incoming calls.
4. If you are currently on the phone with the sender, instruct the sender to press Start on their fax machine.
5. When you hear fax tones from a sending fax machine, do the following:
a. Press START FAX Black or START FAX Color on the device control panel.
b. When prompted, select Fax Receive.
NOTE: Depending on your country/region, the device might receive the fax
automatically when you hear fax tones from the sending fax machine.
6. After the device begins to receive the fax, you can hang up the phone or remain on the line. The phone line is silent during fax transmission.
Jan 30, 2011 | HP 1250 Plain Paper Thermal Inkjet Fax
How to recieve a fax on the Canon PIXMA MX340 Wireless Office All-in-One Printer
Take your incoming phone line and plug it into the place that says "line" on your fax machine. Plug another phone cord into where it says "phone" and connect this to your telephone. Test to make sure you have chosen the right places by dialing a phone number to fax to and listen for the dial tone. If you get a dial tone, then you have set it up correctly.
On the fax machine look for the button that says "menu". Push it and use the up and down arrows to navigate the options on the display. Look for fax set up and press "ok" or "enter" on the fax machines keyboard to access this area. Look for "number of rings" and change the fax machine to a number of rings that is less then your voice mail box if you have one. Then close and save your choices.
Have someone send a test fax by dialing your phone number for the line connected to the machine. The fax machine will pick up on the number of rings set and automatically begin receiving and printing a copy of your incoming fax.
You cannot use magic jack.
You can also choose to manually answer an incoming fax if you see that your display on the fax machine says "ringing" or incoming" you can push the "start" button and this will start receiving your incoming fax.
Sep 30, 2010 | Canon imageCLASS MF7480 Laser Printer
What is answer mode?
The answer mode determines whether the HP Fax answers incoming calls or not.
Different answer modes are :
* Fax
The HP Fax will automatically answer all incoming calls using the Rings to Answer setting. This is the default setting.
* FaxTel (unit with handset model only)
The HP Fax automatically answers all incoming calls using the Rings to Answer setting. If the call is a fax call, the HP Fax will receive the fax. If the call is a voice call, the HP Fax will create a special ring to indicate it is a voice call. The incoming voice call will need to be answered using the attached handset.
NOTE: If the HP Fax determines the call is a voice call, only the HP Fax will ring with the special ring tone. The other phones on the same phone line will not ring at all. You will not be able to pick up the voice call using the other phones.
* Tel
The HP Fax will not automatically answer calls. Faxes will need to be received manually.
* AnswerMachine
The HP Fax will monitor the line when an incoming call is answered by a person or by the answering machine. If the HP Fax detects fax tones on the line, it will receive the fax.
Jun 07, 2010 | HP Officejet 4315v All-In-One InkJet...
HP laserjet 1020 fax incoming fax, machine
hp laserjet is not a fax.It is only a printer.
Dec 09, 2009 | HP LaserJet 1020 Printer
Brother MFC-240 will not receive faxes...
I cant get my MFC-290 to receive incoming faxes
Sep 21, 2009 | Brother Multi-Function Center MFC-240C...
Fax not receiving
if there are "empty toner"
the printer not print received fax until cartridge replacement.
May 21, 2009 | Samsung SCX-4828FN All-In-One Laser...
Machine ringing but not receiving incoming fax calls.
hello! click on menu go to fax click menu set scroll down to easy receive click menu set if you follrwed the directions you should have no problem providing there is dial tone on that line. check with a phone and good luck brother sr tech
Jan 20, 2009 | Brother MFC 7420 All-In-One Laser Printer
HP 1040 Plain Paper Inkjet Fax Logo
433 people viewed this question
Ben Johnson
