Question about GigaFast Ethernet WF719-CAPR Wireless-G 4-port Broadband Router
No internet connectivity with router
My wf719-capr was working fine since yesterday- suddenly it stops connecting to internet through router it works without router - lights are good on the router- Gigafast tech support line not working -pl. help wether the router is died or any solution exist.
I want to know how to reset the password to this gigafast. The reset button does not work..
please tel me [email protected]
Posted on Jul 17, 2008
    Problem Solver:
  • 12 Answers
Go to Network Connections, Right click and Repair your network at least 4 times. Log into your Router and re-clone the mac address of your computer! Make sure you ave a password setup in your Router!!!
Coach "J"
Have a great 2008!
Posted on Jan 08, 2008
6ya staff
SOURCE:
WPA support
It would help telling us what your problem is ?
Nov 02, 2013 | GigaFast Ethernet WF719-CAPR Wireless-G...
Setup as client
Login to your router and disable dhcp.
Now you have e switch and use only the 4 ports. The 5th leave at it is, so no cable in it.
I will be working on the internet and suddenly the connection is dropped. It will restart when I unplug and replug in. Will run fine for a few hours and then stop again and have to unplug/replug. All...
I would call the professional and have him replace/repair it for starters. There is obviously something wrong with the hardware or the connection of your Internet Provider, ether way the install should test the connection and stand behind his installation. If you paid this guy demand, politely but firmly of course, to repair it. 2DAYS OLD, I would be livid. By the way I do the exact same thing as your professional.
Nov 09, 2012 | NetGear N300 Wireless Router
I want adresse 192.168.?.?
should be 192.168.1.1 which is the default ip for most device. if you connect it to a router/switch you will have to remove and connect it to directly to your link source to configure it. After this you remove and connect to your router/switch since you have configured an ip for it to use. If you are using this as your modem then the above ip should work for this abd note that some service providers do not allow wirless as being its modem so check with your service provider if you are using this on the internet.
Again when you configure note that you can assign an ip from 192.198.1.2 going to the device if you are note using that as the modem.
To configure the device connect it to the main souce of link. open a browser and enter 192.168.1.1 (which is the default modem address). when asked for a password enter admin, username is also admin(this is for most device and if it does not work for you refer to the device manual for its default username and password).
Guess you should find your way out in the configuration. For more help refer to the device manual like i said and also find out more information from your isp.
good luck
Jul 04, 2010 | GigaFast Ethernet WF719-CAPR Wireless-G...
Wireless Router suddenly stopped working.
Try resetting the Linksys back to the factory defaults and configure it again.
Power up the router and press the pinhole RESET button on the back of the router for 30 sec
Connect a LAN cable to the wireless router and open a browser and enter to router's configuration IP address and configure the wireless settings, remove the LAN cable when configuration is completed.
You need to configure then wireless card in the computer/laptop with the router's wireless settings.
Dec 10, 2009 | Linksys Wireless-G Broadband Router
I need to set this router up. I don't know how to make the connection secure with a password. I am not technically savvy, so if you could "Dummy it down" I'd appreciate it.
You are tying to set up the router .
It is very easy !
first make sure that your main computer will be able to go online when connected directly to the modem, without the router.
Once you are able to go online through the modem, that means the modem is working. you can set up the router manually.
Click Here for step by step solutions
Nov 12, 2009 | GigaFast Ethernet WF719-CAPR Wireless-G...
Router not working
Check the adapter definitions on your PC
Jul 13, 2008 | NetGear WGT624 Wireless Router
GigaFast Ethernet WF719-CAPR Wireless-G 4-port Broadband Router Logo
217 people viewed this question
Top GigaFast Ethernet Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a GigaFast Ethernet Computer and Internet Expert? Answer questions, earn points and help others
