SOURCE: Cub Cadet 1610 Drive Belt Diagram
Go to Cub Cadet. com and click parts. Type your model number 1610. You will see parts diagram. Click that. It will show a long list of parts to click on. Choose drive and it will show you a diagram of all the pulleys and how the belt looks. Hope this helps. I had the same problem.
SOURCE: cub cadet 1610 rans the battery down went mowing.
Hello bigdave1138:
From your Description it Sounds like the Stator/Charging Coils are Bad or the Voltage Regulator (if Applicable) is Bad.
For Testing the Electrical (Charging) System on Mowers you can Use this Site Addy; http://faqs.custhelp.com/cgi-bin/faqs.cfg/php/enduser/std_adp.php?p_faqid=3438&p_created=1101706364&p_sid=4fQ1f8Xi&p_accessibility=0&p_redirect=&p_lva=3443&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NTEmcF9wcm9kcz0mcF9jYXRzPTAmcF9wdj0mcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1Wb2x0YWdlIGFuZCBTdGF0b3IgQ2hlY2s*&p_li=&p_topview=1 and Use the Link for AC Volts/DC Amps Meter Setting Chart. This is for Briggs Engines and Works Well for Kohler and Other Engine OEMs.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
SOURCE: Just purchased a cub cadet
I am guessing this machine was purchased used. If so take the number off your machine and go to your local Cub Cadet dealer. They should be able to give you the information you need ,plus other info reference, parts, service, etc. GOOD LUCK.
