Question about Kenmore 25614 / 25615 Progressive Bagged Canister Vacuum
Beater bar The beater bar stopped I think the product no is right
  • figment114 Jan 08, 2008
    Thanks............actually there was a belt rest button that I hit a few more times and it worked.
  • drgit2000 Dec 17, 2008
    Do the bearings come off to clean the beater bar or do you just pick at it with them on. I can't seem to figure out how to remove the bearings
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 184 Answers
Also don't forget to clean the bearings on each side of the brush. dirt goes in there and slows the brush down.
Posted on Feb 07, 2008
    Filmmaker:
    Uploaded 5 video answers.
  • 152 Answers
On the bottom take out 2 screws they are closer to the back wheels pull off cover there is a plastic cover over the beater bar take off there is a belt if it broke or wore out change the belt that should fix your problem
Posted on Jan 07, 2008
I was told by a previous repair man that there is a fuse in the beater bar that needed to be replaced.
Up to my experience in my Panasonic vacuum cleaner, if the beater bar is not working this could be because the 'Carpet/Floor' selector switch is in the 'OFF' or 'FLOOR' position. In both of these positions the beater bar will not rotate. Move the selector switch to the 'CARPET' position. When in this position the beater bar will rotate once the foot pedal is pressed.
If the selector switch is in the 'CARPET' position and the beater bar is still not rotating it could be that there is something entangled in the beater bar, or the belt is worn or broken.
To check this first unplug the vacuum cleaner
Inspect the beater bar and belts to ensure that there is nothing entangled in the beater bar and that the belts are intact and are not excessively worn. If the belts are excessively worn they may slip resulting in the beater bar not rotating.
The vacuum cleaners often have an overload protection system inside the nozzle, which stops the nozzle motor when the beater bar jams to prevent belt breakage. After clearing any lint build up or jamming you may need to reset the overload protection, by pressing the reset button on the top of the floor nozzle.
May 04, 2015 | Vacuums
Dyson DC15 beater bar
I am sorry to hear you are having difficulty with the brush bar on your DC15. It is possible that the brush bar is obstructed. Please visit: http://www.dyson.com/support/help.asp?article=866&product=DC15-SY-STD for step by step instructions on how to locate and remove any blockages from your brush bar.
However, if this does not resolve the problem a repair may be needed. Please contact us at 1-866-693-9766 US or 0800 298 0298 UK for further assistance.
Best wishes,
Jessica
Mar 18, 2012 | Dyson DC15 All Floors - The Ball Bagless...
Windtunnel first one used 6 times beater bar stopped working, took apart cleaned and belt was fine. this one had a reset switch for beater bar. had insurance at best buy so returned for a new one. used...
Sorry, you feel like that. I have rentals and 6 windtunnel's (I prefer the bagged ones) and have never had a problem such as you have described. I think Hoover makes a great vacuum.
Sep 14, 2011 | Hoover U6630-900 WindTunnel Bagless...
BEATER BAR WILL NOT WORK. I ACCIDENTLY RAN VACUM OVER SMALL THROW RUG WHICH GOT CAUGHT IN BEATER BAR AND IT STOPPED AND I COULD SMELL BURNING. I SHUT IT OFF RIGHT AWAY. WHAT DO I DO?
remove the bottom of the machine, and if your lucky re attach the belt, if not replace it , you need to remove the beater bar to do this, so prior to taking it out, look at the ends so you know where they are and the positioning before you remove it for easy reattachment
Jul 03, 2011 | Miele Vacuums
The beater bar will not turn
Hello rebh. Generally when the vacuum beater bar will not turn it is because the belt that turns this beater bar has broken.
That said, most of the dyson's require you to buy a beater bar assembly which includes the belt. Any vacuum cleaner repair shop will have this part. OR go to this link http://www.searspartsdirect.com/partsdirect/brands-products/Dyson-Inc-Parts/Vacuum-Parts
Joe
Thanks for choosing Fixya!
Jan 17, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
My beater bar makes a noise and has a crack in the motor on the beater bar and is discolored--me thinks I need a new motor for the beater bar
Sounds like you're right. New motors are available at your nearest Aerus Electrolux store. They used to charge the same amount for selling the motor and letting the buyer install it, or for installing it in the shop. Worth checking in to.
http://www.aerushome.com/storelocator/
Nov 08, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Beater bar not working on newer ball pet unit
HighnTools posted this solution some time ago. I think it can help you solve your issue.
I have finally fixed my sister's dyson dc 15 beater bar problem. It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
Aug 29, 2010 | Dyson DC15 All Floors - The Ball Bagless...
Beater bar on singer central vac stops beating
try cleaning the ends of the brush roller. thread gets caught in there and jams it
Mar 07, 2009 | Singer Vacuums
Beater bar has stopped turning
All beater and rotating brush bars are fairly easy to get to with a couple of screw on the bottom of your wan. They are driven by a belt and these belts come off, break, or the bar itself is stuck with rug material. Unplug your vacumn and get our screwdriver. It;s easy to figure out once inside the wan.
Mar 02, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Kenmore 25614 / 25615 Progressive Bagged Canister Vacuum Logo
171 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Marvin
Marvin
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
