Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
Hitachi HD big screen won't turn on. It was on, turned itself off and now won't power back up
This tv was bought in 2002. I think it is a 2001 tv. Just won't turn back on.
Help
  • renees47 Feb 04, 2008
    My Hitachi 50" was on, I was watching a movie and then it went off and I have not been able to turn it on since. Tried unplugging it and placing into a new outlet red power light came on just for a second then went back off. When you unplug it and then plug it back the red power on light wil come on then go back out.
  • navarre09 Feb 05, 2008
    I have the same problem. It won't turn on, same as described. I do not understand the solution
    President:
  • 4,402 Answers
Check IC601, C603 for leakage, I601 and vertical pulse detector QN05
for poor convergence check RK42 for open circuit.
Posted on Jan 07, 2008
I have a 2006 Hitachi Ultravision 42 inch plasma
plasma tv units use a lot of power ,well into the hundreds of watts 9 some big screens use up to 800 watts to work)
I suggest that you consider a new led unit which uses barely any power and you will get a remote with it
Jun 24, 2017 | Hitachi UltraVision 42HDS52 42 in....
Hitachi Big Screen projection TV. turned off , wont turn back on
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com///
Sep 30, 2017 | Hitachi Televison & Video
Have sound but no picture
Sounds like what happened to my hitachi. Power voltage regulator on the main pwr board.
Jan 24, 2009 | Mitsubishi VS-50609 50" Rear Projection...
TV turns itself off then back on
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Capacitors are very inexpensive but require some soldering skills to repair.
Hope this helps
Dec 15, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
TH ETV TURN OFF ITSELF
the cooling fan could be going out
Dec 13, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
TV Won't Come On...
My Hitachi Model 50V500 led's ligths temperature and lamp blink when power is turn on.Have no picture or sound, followed the reconmended procedure disconnected power
for 30 seconds and reconnected.
Mar 18, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 50" big screen TV
You have a defective light engine and Hitachi is aware of it. Here's what you need to do...recently went through this. Call Hitachis customer relations department at 800-654-7013 and tell them you have a defective light engine. At first, they will act like they've not heard of this problem but they are all too familiar with it. They will give you the names of some certified dealers in your area. Once the tech comes out and confirms the problem, call Hitachi back at the 800 # I listed and they will call and confirm with the dealer that you have a bad light engine. They will send a brand new light engine to the dealer (Hitachi will cover the cost $1500) and the dealer will call you to come out and install.
Here's the kicker, if you're not still under warranty, Hitachi will cover the expensive part but you will have to pay the install. Our install was $400 but others on this site have paid around $200. If you're still under warranty, Hitachi will cover the part and install.
Please do not let any dealer tell you that you have to pay for this part. Hitachi has not recalled this part but they are replacing it to you for free...you just pay the install. Also, deal only with their customer relations at the 800# I listed.Good Luck:)
Feb 12, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Tv turns off and on by itself
Here is the link for the manual if you need it http://merchant.satisfusion.com/library/manuals/owners/50_60V500.pdf check page 57 - see if there is a timer lock activated somehow or a ratings lock check that the button on the remote is not malfuntioning by taking the batteries out and see if the problem persists check page 63 about screensavers !!!check page 67 about the on-off timer check page 75 - power issue troubleshooting check that there is not a problem with the bulb or the cooling fan - maybe an overheat safety device switching your screen off and then back on again. Hope this helps :)
Mar 09, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
232 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
