Hard drive not being recognised by laptop
I bought my hard drive about 6 months ago and it worked fine.
I lost the power cable for it and for about 4 months have been unable to use it.
I then found a power cable which I thought worked but was the wrong one, and then I managed to find the correct one.
However, now when I connect the hard drive to my laptop, it is not detected, and I cannot see it in My Computer.
The green light on the side flickers when connected to the power. I can also hear a whirring sound which sounds like something is spinning, I'm not sure if this is normal.
I don't mind losing the data on the drive but would like to get it working ASAP.
I'd be grateful if anyone know's how I can get it to start working again.
Thanks
  • 1 more comment
  • Zeeble Jan 09, 2008
    The cable seems to be working fine. How would I check it though?
  • bgreoqirfg May 26, 2008
    I am having the same problem, the drive will not show up on the computer screen, though the light lights up and it whirrs.  I have tried on two different computers, a laptop and a desktop, both macs.  I have tries different firewire cables, firewire 400 and 400 and USB cables and a different power cable. None have worked.  I would like to know if there is any way to fix the problem and/or get the information off the drive
  • Anonymous Dec 23, 2008
    i had double check on the cable . but yet my harddisk still can't be read by computer
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 175 Answers
Double check the cable.
drive get the power and spin too there is a problem with the Cable.
Posted on Jan 08, 2008
  • Waqar Khurshid
    Waqar Khurshid Jan 11, 2008
    well check the cable with other Drive.
Hi i'm from greece and i bought a hitachi simple drive external hard drive 1 tb about 4 months ago it worked fine but now suddently it stopped . i tried to take it of the power and i also removed the cable...
you must have short in the wire hooked up to external try jiggling the base of wire pluged up to port on the external see if you see the light on hard flicker on off if thats the case its your wire for right intell you get a new wire prop something underneath wire intell you see the light stay on.
Feb 24, 2011 | Hitachi 1TB External USB 2.0 Hard Drive
I bought a WD5000BEV harddrive in december 2009 and within 6 months it has started giving me problems. Sometimes the computer recognises it and some times it does not. Even thought it appears on the...
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked (with the computer and hard drive plugged in). I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 16, 2010 | Western Digital External USB 2.0 80 GB...
Iomega 320 external hard drive computer wont recognise
Jun 15, 2010 | Iomega Portable Hi-Speed USB 2.0 40GB,...
HARD DISK NOT RECOGNISED BY MY LAPTOP
try with changing the data cable and the power connector.
Have a nice day and do not forget to rate please...!
Apr 12, 2010 | Western Digital Elements powered by WD 320...
Verbatim 1tb external hard drive malfunction error message
Try changing the USB cable that connects the hard disk to the computer, this message usually comes when the cable is damaged.
Dec 14, 2009 | Computers & Internet
Laptop suddenly stopped recognising my external USB hard drive
I had the same exact problem with a WD2500xms passport. The problem was the USB cable. I went to the store and bought a 6' USB cable ( $26 at Radio Shack) with the same specs and now, no more problems. Also I called WD technical support (800.275.4932) and asked for a new cable. The WD customer serverice was very helpful and said it would sending me a new cable for free. When it arrives I'll return the 6'er.
Aug 13, 2009 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
My Dell laptop does not now detect my Maxtor external hard drive, even though it worked fine for a month. Power is getting to the hard drive, the lead to the laptop is fine but the computeer just does not...
ok i have found that this can happen sometimes, there should be 2 usb connectors on the end of the hard-drive, try the other one, hope this helps, let me know if it doesn't
Sep 07, 2008 | Computers & Internet
External hard disk and pcmcia cardbus
There may not be enough power from the cardbus to run it. That bus is very low current to power it up so you will need the power cord.
Try reinstalled the card drivers.
Aug 04, 2008 | Computers & Internet
Toshiba Hard Drive Crash
if the datas aleady deleted, then you have nothing to lose. Right ?
What you need is a 2.5 to 3.5 inch IDE ribbon cable connector.
this will enable you to put the drive into an IDE slot on the PC internal motherboard ( primary/secondary )
Unless it,s already 3.5"
boot the computer, see if it recognises the drive. And format it.
then you may be able, to re-fit back into the external casing, and use as an external again.
Mike @ compurepair.
Feb 25, 2008 | Toshiba 120GB USB 2.0 Portable External...
Maxtor 3200 320GB Not being detected
if you plugged in an incorrect power cable it is very possible it could be damaged if the voltage from the incorrect cable exceeds the drive. try hooking it on another PC, to verify if it's the drive or PC
Hope this helps
Jan 07, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Computers & Internet Logo
506 people viewed this question
Alun Cox
David Payne
David Payne
