Question about Fisher and Paykel DEGX1 Electric Dryer
F&p dryer issues
Are there other lint traps to empty besides the one I remove manually after every load?
Yes, there is a filter inside of that one. You are just emptying a receptical. Unplug the machine, remove the screw inside of where you remove the lint trap. remove that cover and vacuume out the area, you can use a blower to get more out (canned air). The two metal bars below the receptical are sensors, sometimes the back side of these become packed with lint and must be cleaned out as well. If the wires from the sensor comes off one must attach to the bottom bar and the other to the top. NOTE: On mine It is possible to connect the wires to the same bar, at opposite ends, this can cause damage.
Posted on Jan 15, 2008
Hi, the dryer keeps stopping (the timer jumps), only runs for about 10 mins at a time AND the part that worries me the most is that I haven't had to empty the lint trap which I usually do after e
sounds like the vent tubing is not hooked up as it should be and that can cause a lot of lint buildup inside of the dryer parts. take it apart again and clean out all of the lint because this is a fire hazard. make sure that the vent is connected to the lint trap and try working it again. it sounds like maybe the buildup of lint is making the drying hard to do.
Aug 27, 2012 | Whirlpool 8579123A DUET DRYER DR REVERSAL...
Tip
Dryer Taking too Long to Dry Your Clothes?
A very common issue we deal with on FixYa is clothes dryers that are taking too long to dry clothes. Here's a few tips on keeping your drying time to the minimum.
1. Check and empty your lint trap before each load. If air flow is restricted, your dryer will need longer to get the job done. A clean lint trap will allow for maximum intake air to the dryer blower.
2. Check the exhaust ductwork for lint buildup. If the 4" ductwork that carries your warm, moist, lint-laden air to the exterior of your home is blocked with years of lint and moisture, chances are pretty good your dryer is taking longer than it should to get your clothes dry.
  • Disconnect the dryer power cord (and gas line if a gas unit), slide the dryer forward far enough to access the 4" ductwork clamp at the back of the dryer. Disconnect the ductwork at the dryer and separate to inspect both in the dryer exhaust duct and the ductwork as well.
  • Remove all built up lint. You may need to access under the floor, or in the crawlspace, or basement to get at all the areas that lint may be built up. Remember that when there's an elbow (turn) chances are pretty good there's lint in there, so take the time to separate the ductwork where needed to give it a thorough cleanout.
  • Long straight sections of ductwork can be easily cleaned by purchasing a "webster" style pole brush.
  • Clean the exhaust duct of the dryer but be careful not to damage anything inside your dryer
  • Reconnect and turn the dryer on air fluff to blow the rest out.
3. Remove lint build up from inside the machine
  • Turn power off again
  • Remove the front cover of your dryer
  • Remove the front drum support/air duct from the front of the dryer
  • Carefully vacuum the lint out of the dryer with soft brush attachment on your vac. Be careful not to damage any ignitor or electrical items.
  • Clean the inside of the lint trap duct of sediment/ buildup
4. Make sure your washing machine is spinning the water out of your loads correctly. This one is pretty obvious, but it bears mentioning.
If your clothes feel wetter than normal, it's definitely going to take longer to dry. Be sure to wash "like" items. A medium/large load of towels is better than a towel and 5 cotton shirts ( that towel will throw the load off balance and your machine won't spin as fast to get the water out).
5. Medium-sized loads dry faster than mega-large-cram-it-in loads.
The idea of getting all you can into a dryer (or washer) to save time and money will end up costing you both time and money. I've seen this played out many times in my laundromats: You will find that a medium, loosely packed load will dry faster and with less wrinkles and less ironing needed.
Using these guidelines will help keep your drying times to a minimum and also allow your machine to work for many years to come.
on Dec 03, 2009 | Dryers
I have a kenmore elite model 110.8586 or 8587 anyway I cleaned my lent screen put it back as I always do after every load and know it say check lint screen
Possibilities
The sensor is dirty..remove the lint trap and clean the orifice with a Swiffer duster. Dryer sheets can clog the lint trap use a tooth brush and detergent to clean the lint trap. Alternately see if it presents the same issue operating it without the lint trap. If you have an air compressor blow out the slot too. Make sure the main exit hose is cleared also *vent duct*. Tip the unit and blow the air in too.
Or a melting type fuse mounts on the blower housing and is tied into the same circuit as the door switch. When it melts it shuts down everything and this keeps the lint from catching fire.
Also check the belts.
You can turn off the beeping if you would like. Instructions are in the manual. By Pressing the buzzer button it has Loud medium low and off positions.
Remove the rear vent and try the unit...
I'm thinking that your sensor is probably the issue here.
Jun 10, 2011 | Kenmore Dryers
Dryer taking to long to dry
Overloading
1. One of the simplest problems to remedy could simply be that you are putting too many items inside the machine during the drying cycle. Avoid overloading your dryer, as this might cause your dryer to work extra hard to dry your clothing, extending the length of the dry cycle.
Wrong Heat Setting
2. A common issue with clothes dryers could be the wrong heat setting. Most home dryers feature several settings, from low heat settings to high heat and permanent press. Be sure the setting you choose is right for your needs. Another setting to check is the load size of your dryer. If you are drying a large amount of clothes, be sure the setting for large loads on high heat is selected. Choosing the wrong heat setting or load size can cause your clothes and linens to take longer to dry.
Lint Trap
3. One of the simplest fixes for drying issues might just be that your lint trap is clogged. Each time you use your dryer, lint will form in the trap. If the lint trap and vents are full, this could block air going into your dryer and slow down if not completely stop the drying process. After you use your dryer, remove this lint trap and empty it fully. Even if the lint trap is full, your other dryer vents might be clogged as well.
Clogged Vents
4. If your clothes are in the dryer for a long amount of time, but still not drying, the reason for this could be a clogged vent. A sign that your vent is clogged is if your clothes are warm or hot to the touch after sitting in the dryer, but still damp. To unclog your dryer vent, you may need professional assistance. This is especially necessary if your dryer vent leading out of the house is particularly long.
Heat Source
5. If the dryer is not getting enough heat to dry your clothes,something could be wrong with the heating system. After the drying cycle, touch your clothes to see if they are warm. If not, this means that the heating mechanism is malfunctioning. It will need to be repaired or replaced by a professional.
Feb 28, 2011 | GE Profile Harmony DPGT750GC Gas Dryer
THE DRYER IS NOT DRYING THE WASH, CAN I FIX IT MYSELF?
Two easy things to check and fix, even if you are not handy with tools, is the lint filter and the air flow discharge.
If the lint filter isn't emptied after every load, it will diminish the dryer's ability to dry clothes which means higher costs in electricity and / or gas.
Also, the air flow discharge hose attached to the rear of the dryer with a clamp that can be loosened with a screw driver can fill up with lint and reduce or stop air flow; also diminishes the dryer's ability to dry the clothes.
Besides making it more expensive to dry a load of clothes, lint build-up in the lint trap and / or the discharge vent is a serious fire hazard.
Aug 03, 2009 | Zanussi TD4212W Electric Dryer
Lint fell back into lint trap. how can i get it out? already looked in back.
An appliance store can sell you a brush that is attached to a long wire. It is made specifically for removing lint from dryers. I have seen them at walmart and other places but for sure at an appliance store. Good luck.
Apr 20, 2009 | Whirlpool WED5100SQ Front-Load Electric...
Frigidaire dryer, lots of lint getting past screen.
Here is a link to an exploded view and parts list for your dryer. http://www.pcappliancerepair.com/model-display.php
If you are certain that the filter is not compromised or damaged and is properly seated into the housing , you may have a problem with the housing itself whereby lint is getting into the blower thru a break in that housing.. I would examine that area for damage.. and make sure when you reinsert the filter, it is seated all the way down.. Hope this helps you... BTW: over time, it is not unusual for lint to build up in the duct since some of that lint is smaller than the filter media and will work its way thru.. If you are getting that degree of lint build up very quickly then you may have a problem as mentioned above..
Regards,
Rick
Dec 03, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Dryer
forget dryer ck vent to outside look for kinked or flatened hose behind dryer find out side vent hood and ck air flow to verify vent problem try drying load without hose connected to dryer may get warm and a little dusty in room but worth it to verify fix
May 02, 2008 | GE WSM2420T Top Load Stacked Washer /...
Roper dryer by whirlpool- gas dryer
You have a severly blocked vent, its not removing the moisture to the outide but instead getting trapped in vent.reccomned reventing unit with solid duct pipe, not the vynyl flex tubing and mke sure the outside exhaust port is totally free of obstruction a well
Feb 24, 2008 | Dryers
Fisher and Paykel DEGX1 Electric Dryer Logo
286 people viewed this question
Top Fisher and Paykel Dryers Experts
Craig Butler
Craig Butler
Virgil Watts
Bill Eager
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
