Question about Samsung SH-S182D DVD RW Dual Layer Burner
Can't complete Burn process
Hi, My Drive won't copy discs and gives the message; Cannot write track at correct position with this recorder.
Would appreciate any advise please, thanks,
  • petergft Jan 08, 2008
    Hi, Thanks for your reply. My hard drives have 226gb free on 'C',
    128gb free 'F' and 172gb on 'G'. I've removed the drive from my PC and put an 'Old' NEC x12 drive in there and that works fine. I have taken the Samsung back to the store and they have sent it away fro test. Under the terms of the UK retail laws I can only have a repair or replacement if faulty beacause, I bought the drive in November although I never tried 'burning' with it until, yesterday!
    Thanks for your help.
    Problem Solver:
  • 14 Answers
Hey I Think You Should Check Your Space in UR Windows Drive
If Its Less than about 500MB This Usually Happens With Burner Programs Like Nero ,Roxio Like
Let Me Know If this Fixes Your Problem
Solution: Make Space About at least 2.5GB In Your Windows Drive (HARD DISK)
Posted on Jan 08, 2008
To Determine CD recording problem: Track1 records and plays back O.K. Upon completing track2, display window flashes continously "Now PMA" (Updating disc contents) NO playback or sound on track 2.
It is possible that until you finalize the disc, the only track that will play is the first one. Unfortunately, once you finalize the disc, you cannot record additional tracks to it. You can verify this by finalizing after recording the second track and seeing if they then both play. If that works, you can safely burn additional discs with confidence that they are burning correctly even if you cannot play each back after burning and must wait until finalization to test full burn.
Sep 26, 2016 | Denon CDR-W1500 2-Disc CD Recorder
DVr randomly stops
The alignment head is set to read/burn disks that are true and in line with the laser beam. Some Disks, especially ones burned on other equipment may not line up correctly. Tracks may at times burn incorrectly and thus they tend to skip, very much like a phono record. Commercial discs generally are true and correct, and rarely have that problem.
Dec 29, 2013 | Philips Phillips Lite-On Replacement DVD...
If I want to record let's say someone speaking for 90 min and burn 2 cd's , one 60min and the other 30 min from the one 90min recording , each one divided into tracks , how would I do this ?
If you want to burn a CD you have to make a master. For 2 cd's you have to make 2 masters, one for each recording.
The best way to handle this is to "create a song" for each speech giver and give each a name.This is because you can make only one master copy of a song before burning a Cd.
But another way is to :
1. Make a master of the first speech giver (who is on one track) and record to the Cd.
2. Make a new master of the second speech giver (on the other track) and record to Cd.
As long as you don't mind, the second mastering will overwrite the first one that you did, but then you already have burned a copy of that Cd!
Nov 02, 2010 | Tascam Dp-02cf Digital 8-track Recorder
I have a Marantz CDR632 and I am recording sermons for a church. After I am finished and completed the finalization process I try to use in a duplicator and it gives an error message that it is a problem...
We have the same problem with our CD duplicator at our church. When the duplicator finishes it always shows 'fail' but the copied CD-R appear to have copied correctly and play on other players.
Feb 26, 2010 | Marantz CDR632 CD Recorder CDR-RW with...
Cant make a back up of my dvd's for the kids to use. with shrink and decripter. when i do now it says, when i play it, it says no menu.
Step 1
Be sure to erase all data on the disc, if media is rewriteable, by going up to the "Recorder" drop-down menu and clicking "Erase Rewriteable Disc." A box will pop up on which you need to choose the correct recorder from the top menu, quick or full erase (best option), and a maximum erase speed is fine.
Step 2
Choose your recorder drive on the top right drop-down menu on the main screen. The drive icon next to this menu allows you to set advanced options. (Not needed here.)
Step 3
Click on the "Burn" icon in the middle of the main toolbar. This opens up the "Burn Compilation" box.
Step 4
Click on the "Multi-session" tab on the "Burn Compilation" box. Choose "Start Multi-session disc", if the disc is to be added to later. Choose "No Multi-session disc," if the disc is to be completed with the current burn. The other options are good at the default settings.
Step 5
Click on the "Label" tab on the "Burn Compilation" box to give the disc a title that will be seen in the drives list, such as Windows Explorer, when the disc is loaded. Choose "Automatic Disc name" and enter the desired name without spaces. For spaces, add underscores (shift+hyphen).
Step 6
Click on the "Burn" tab on the "Burn Compilation" box to set desired burn and writing actions. "Determine maximum speed" lets Nero determine the recorder and disc speeds, if they are unknown. "Simulation" performs a test virtual test burn to see if all goes well. "Write," of course, burns the disc. "Finalize disc" means that the disc will be burned, so that no more can be burned on it. (For the example, check the boxes for "Write" and "Finalize disc," which is probably already checked.)
Step 7
Set "Writing speed," if known, "Writing method" as "Disc-at-once" and "Number of copies".
Step 8
Click the "Burn" button at the bottom on the "Burn Compilation" box to begin the actual burning process and the "Writing to disc" window will open.
Step 9
Check the "Verify written data" box on the bottom left of the "Writing to disc" window. This will have Nero read the disc, after it is done burning, to verify that all of the data has been properly burned to the disc. This is an important optional step, especially with really important data. If all goes well, a box will pop up stating that "Data verification completed successfully."
Step 10
Run the disc in a drive or DVD player to make sure it runs correctly. If it does, the original files on the hard drive may be deleted, if desired.
Dec 11, 2009 | Computers & Internet
Cd burner makes blank cds
try isolating the problem by plugging an external cd/dvd drive via the USB. use this to burn CD/DVD if the process works, replace your laptop dvd drive.
Jul 07, 2009 | Dell Dimension 4600 PC Desktop
CD Burning gets stuck
Try this: : Decreasing the burn speed If the drive is not recognizing the disc at all, skip to Step 4. Decrease the CD writer's burn speed by half to increase the likelihood of a successful burn. Decreasing the burn speed is a quick, easy way of increasing successful disc burning sessions, at the expense of taking more time to create a disc. The following steps are for Windows XP only. For Windows 98 and Me, decrease the write speed from within the software that you are using to write discs (RecordNow, Easy CD Creator)
  1. Click Start , and then My Computer .
  2. Right-click the drive icon, and select Properties .
  3. Select the Recording tab and reduce the Current Write Speed by half (for example, from 16x to 8x).
  4. Click OK and close the My Computer window. Try burning a CD. If the drive fails to create the CD, go to the next step.
Step 4: Setting up disc recording in Windows XP If the computer does not have Windows XP, skip to Step 6. If you are using Windows XP, use the following steps to ensure that native burning is enabled:
  1. Place a blank disc into the drive. NOTE: If the error <drive letter> is not accessible. Incorrect function. " opens, close it and continue using these steps to correct this problem.
  2. Click Start , and then My Computer .
  3. Right-click the writable drive icon, and select Properties .
  4. If a Recording tab is shown, select the Recording tab, select Enable CD recording on this drive , and then click OK . Try burning a disc again. Continue to the next Step if you are unable to burn a disc. If a recording tab is not shown, continue using these steps. Figure 2: Enable CD recording on this drive c00368150.gif
  5. Look for a Recording tab: If the Recording tab is not shown, Windows XP has not detected the drive as a recordable device. Use the following sub steps to enable the Recording tab:
    1. Click Start , Run , and type regedit in the Open field.
    2. Backup the registry: Select My Computer from the list, click File , Export , type a name that you will remember, and click Save .
    3. Click OK , and browse to the following registry key: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\CD Burning\Drives
    4. Click the Volume key that matches the CD/DVD drive that is capable of writing discs. If only one drive is installed, one volume key is listed. If you have more than one drive, examine the data values (by double-clicking them in the right pane) to find the correct drive.
    5. With the volume key selected in the left pane, double-click the Drive Type value in the right-pane. Figure 3: Drive Type registry value (CDRW) c01367502.jpg
    6. Type the number 1 in the Value Data field if the drive is capable of recording to CDRW discs (including CD-R discs). Type a 2 if the drive cannot write to CDRW discs but can burn CD-R discs. NOTE: A value of 3 indicates that the drive is only capable of reading discs. Changing this value to a 1 or 2 enables Windows to view the drive as a recordable drive.
    7. Click OK , and close Registry Editor.
Jun 20, 2008 | Dell Dimension 4700 PC Desktop
Need user manual
I have the CDR-200 and did not have the manual either. However, I did discover the same problem and found the solution. There is a "confirm" button on the front of the unit under the display area. After you press the record button "Record" will begin to flash in the display area and then you press "Confirm". It should start recording. Note however the following:
Before starting this procedure make sure you have an AUDIO recording CD in the RECORDER tray of the CDR-200. A regular CD-R type of disc for computers is not going to work and may cause an annoying message on the display which does not go away until you put the right type of recording CD in the unit. It must be either an AUDIO CD-R or an AUDIO CD/RW.
1. When copying from an external cassette deck, you should set the source (press source button) until the setting is "Analog".
2. The "Dual" button should not be in effect. In the lower right portion of the screen you should only see a small number "1" with a circle around it. This indicates the CDs currently being used by the burner. In "dual" mode you can copy from the Playback CD of the CDR-200 to the Recorder CD. In dual mode you see "1" and "2" with circles around them. The active CD tray will flash on the display.
3. When copying from an external cassette unit, you use the "Record" button to start the recording. At the end of the cassette track you MUST press the STOP button by the CD Recorder tray. After you press STOP the unit will say "Update" which indicates it is closing out the track on the CD-R. You can continue to write tracks by pressing RECORD again, then CONFIRM when the tape is positioned at the right PLAYBACK track. It is usually helpful to have a few seconds of blank tape at the start of the PLAYBACK track before pressing RECORD. Press play on the cassette deck, then RECORD followed by CONFIRM on the CD burner.
4. When the track has finished burning you must press STOP to close the track on the CD-R. After you press STOP, the unit will display "Update" to indicate it is updating or closing the track. When the process completes, the unit will display the tracks it has written to the CD-R and will be ready for you to copy another track or FINALIZE the CD-R. When the unit is waiting after the STOP, you can change the cassette tape, reposition to a playback track and ready the playback tape for more recording. When the PLAYBACK tape is ready repeat STEP 3. Repeat steps 3 and 4 until you have about 14 or 15 tracks on the CD-R.
5. When you have finished recording about 14 or 15 tracks onto the CD-R, you will want to finalize the CD-R. Press the FINALIZE button, and then press the CONFIRM button. You will see the the unit start to display the progress of the finalize by advancing the level meters of the left and right channels in the display. When the unit is finished finalizing it will return to the number of tracks display for the CD-R. After finalizing the CD-R you can play it back to make sure the burn was successful. Be sure to wait for the tracks display before removing or playing the CD-R after the finalize is done. Removing before the finalize is done may damage the unit and may render the CD-R bad.
1. Set the unit to "Dual" mode. As described above, you will see "1" and "2" with small circles in the lower right portion of the display.
2. Make sure the "Source" mode is set to "Analog" by repeatedly pressing the SOURCE button until it shows "Analog".
3. When copying from the PLAYBACK CD tray you will not use the RECORD button by the CD Burner tray. You will use the 'DUB" button just to the right of the display.
4. Put an audio CD in the PLAYBACK CD tray and press the skip track button ">>" until you arrive at the track you wish to record from. If the track you want to start at is track 1, then you don't need to skip tracks.
5. When positioned at the correct playback track, press the DUB button. The unit will show "CDR" and then "DUB" on the display. When it says "DUB" press the CONFIRM button. The unit will start recording. You can adjust the record level during the first few seconds to make sure you don't have the recording volume level set too high.
6. When the track is finished, you should see the unit indicate on the display "Update". This indicates it is closing the track and it should do this automatically. If it does not do this you may have to press STOP near the RECORDER Tray to force closing of the track. Usually the unit indicates "AUTO" in the display area and I believe that is what controls the automatic track numbering feature. I am not sure how the AUTO feature is turned on. I noticed on the CDR-200 it is on by default.
7. After the UPDATE is complete, the unit will display the number of tracks it has written to the CD-R. You can at this point change the PLAYBACK CD to another one or advance to another track for continued recording. When at the correct track simply go back to step 5 and continue.
8. When you are all done copying tracks from one or more CDs, and you wish to finalize the CD press FINALIZE and then press CONFIRM to start the finalize process. I noticed on the CDR-200 if you wait too long after recording a track the unit may start the finalize process automatically. This happened after at least 5 minutes. It is best to try and stay with the copy process to monitor what is happening. The finalize can also start if you have written to many tracks to the CD-R and it runs out of space. Typically, your safe if you burn about 14 to 15 tracks to a CD-R at a time. You might be able to fit more if the tracks are very short (2-3 minutes each).
One last note about the connections on the back of the unit. Read the labels of the connections on the back very carefully. The CDR-200 and probably the 201 have separate outputs for the PLAYBACK CD (CD) and BURNER CD (CDR). You will want to connect these to seperate inputs on your audio amplifier. Or you might also wish to merge them using adapters into one input on your audio amplifier. If you keep them separate you will need to change sources on the audio amplifier to hear each tray. For example, you might need to switch to "CD/TAPE" for the CD, and "AUX" for the CDR. It is probably easier to merge the two using audio adapters which can be readily obtained from RadioShack.
I hope this helps!
May 08, 2008 | Classic Electronics CDR201 CD Recorder
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Samsung SH-S182D DVD RW Dual Layer Burner Logo
98 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
