Need part I am looking for a hitachi part #2370542 for an older rear projection t.v. Please let me know if you happen to have one in stock. I believe this part was no longer available as of 2006
  • bkair Jan 07, 2008
    the part number is 2370542 it also has the following number M701. it is for a hitachi rear projection tv model #CT 4555
    President:
  • 4,402 Answers
What is the part? does it have a number on it?
http://www.mouser.com/index.cfm?handler=home
http://www.mcmelectronics.com
http://www.bdent.com
http://www.electronix.com
Posted on Jan 07, 2008
6ya staff
SOURCE:
Hitachi 60 inch rear projection TV sometimes it has lines going through screen, sometimes it shuts off on its own and sometimes it will come on but has no picture or sound. What could the issue be?
It sounds like a lot of stuff for a diagnosis, is it an older projection TV? Don't believe it would be the bulb with the fact the sound is affected. May be time for an upgrade!
Dec 04, 2016 | Hitachi Televison & Video
Hitachi 61sbx01b will not power on
Its a older set and may have a classic issue--first to know how technical are you? You know what a pico fuse looks like or a 1,000 pico farad blue ceramic cap?
I ask as telling you where to look may do no go if you cannot find what needs to be looked at.
May 20, 2012 | Hitachi 61SBX01B 61" Rear Projection...
Need a lower rear board Part #H512264
No one has it in stock--board should be repairable unless lost etc.
http://www.partstore.com/Model/Hitachi+Ltd/Hitachi/53SDX01B.aspx
You might also contact PTS Electronics who repairs boards and may have one of these rebuilt as well.
If its the board with the RCA jacks it may be fixable.
May 02, 2012 | Hitachi 53SDX01B 53" Rear Projection...
Can i optimize my grainy picture on my Hitachi projection tv
Unfortunately, without me seeing it I can't tell all what you will need to put it back into optimum performance. Older projection sets are pron-ed to having the coolant replaced for the 3 picture tubes. I don't know the quality of the tubes themselves, so it's really tough to make a call on your set. If it's just fluid, I would say you would invest $300.-400. in work. I don't believe it's worth putting that much into it if that's what it needs. Of coarse this is only if you have a projection set, you didn't state what model of set so I'm assuming it is one. Hope this helps......
Apr 21, 2009 | Hitachi 46UX50B 46" Rear Projection...
Hourglass shaped picture on rear projection Hitachi 48 inch older
you will need to take the TV and have them diagnosed it for you.
Dec 05, 2008 | Sprint Hitachi P300 Cellular Phone
Where to buy parts
From what I believe, Mitsubishi is no longer supplying parts for their home entertainment products. They may have some older stock. I would suggest calling their tech support to find out for sure.
If they do no longer have the part, start doing a google search to see if you can find one on the net. Sometimes there may be someone with a scrapper set, and they are willing to sell parts.
Jerry G.
Apr 28, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Hitachi 60 in rear projection tv
If the picture is jumping from top to bottom this is a vertical issue. The common cause on older Hitacjis is loose connections on the vertical output IC.
Jan 28, 2007 | Hitachi 60EX01B 60" Rear Projection...
Jumpy Picture on Hitachi 55FX48B
On older Hitachis the most common jumpy picture is loose connections on the vertical output IC. If you can tap on the main board and get it to act up then this is most likely the situation. I believe the location is IC401 and is located toward the front of the set on the signal panel. Not too tough to repair if thats all it is.
Jan 29, 2007 | Hitachi 55FX48B 55" Rear Projection...
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
