Question about Food Mixers
Vision 708 mixer amp
I HAVE A STUDIOMASTER VISION 708 MIXER AMP WHEN I TURN IT ON ITS OK FOR A FEW MINS BUT THEN THE RIGHT CHANNEL GO'S OFF. IT FADES AWAY. AND IF I TURN UP THE VOLUME IT SLOWLY COMES BACK ON. BUT WHEN ITS BEEN ON FOR BIT IT SPLUTTERS LIKE A BAD CONNECTION. I HAVE CLEANED ALL FADERS & CANT FIND A FAULT IN ANY FADER OR POT THAT MAY CAUSE THE PROBLEM. WHEN THE RIGHT CHANNEL IS OF. THE METRES LEFT & RIGHT ARE STILL FLASHING. SO I PRESUME ITS NOTHING TO DO WITH THE INPUT. INSIDE THE AMP THERE ARE TWO LED'S THEY ARE MARKED..LEFT FAULT & RIGHT FAULT.. THESE ARE NOT LIT IT HAS A ON BOARD COMPUTER THAT GIVES HELP. I DONT KNOW IF IT DISPLAYS FAULTS IF THERE IS ONE..IT IS NOT DISPLAYING ANY FAULT. PLEASE ANY IDEA WHAT MAY BE GIVING ME THIS FAULT YOURS JIMBO jimbo11757@yahoo.co.uk
  • 1 more comment
  • JAMES TURNEY Jan 08, 2008
    Thanks bbtoast...
    I never even gave the mains input to the amps may be at fault.
    there being x2 inputs for each amp.
    I will take a look in morning and let you know. I may find the dry joint i've been looking for. since it go's off when volume increased a dry joint would tend to arc.
    maybe cause the disstortion?
    i wiil get back to you ..... jimbo
  • JAMES TURNEY Jan 16, 2008
    Hi bbtoast..I have been looking at amp but no joy.
    BUT when the amp is on there is a little sound coming out, and when i turn up volume it try's to work, but this is when you get the cracklin niose. as if there is somthing that will not connect ?
    should i be looking at the output pannel or the pre amp pannel. is there a way i can check the right amp pannel output is ok.
    then if this is ok then it has to be a fault elseware on the amp but not the output.
    dont forget this is a 8 channel mixer amp
    and there is a lot of plug in leads?
    come on get your brain working...
    plus sometimes both channels work fine..
    and the it fades out again...
    what do you reckon it might be..and how can i check the main right output board is OK...
    thanks jimbo
  • JAMES TURNEY Jun 03, 2009
    Helo all. I've been away for quite some time.
    But to update you on the above fault. I found it.
    It was the line input jacks at the rear of amp
    they are make n brake. because there open to the air they dry up dont close & thus it shuts of the signal from the mixer. gave them a clean & a little servisol & now they work fine.
    sorry for the long break but I'm back now.
    please look at my latest problem with a sound lab mixer amp..jimbo
  • 319 Answers
Jimbo
I am not sure about the LED fault lights....but I have a few troubleshooting angles to provide a start:
Try checking the power supply at the output devices and compare with the good (Left) channel.
The distortion you are hearing may be due to
low voltage.
This is a stereo amp, so you have a good (Left) channel to compare with. Use a multimeter to compare resistances (no power applied) or voltages (power on) at the components working back from the outputs of each channel. When you find a difference you have located the faulty area.
If you can get an oscilloscope it can also be used to trace the path back from the output of each amp. Good Luck Be careful!
Posted on Jan 08, 2008
  • Brian Berndt
    Brian Berndt Jan 08, 2008
    I did find some info on the LED Protect lights:
    One or Both Amplifier channels stop working briefly…
    (one or both Protect LEDs illuminate briefly)
    1. Check the ventilation holes both front and rear for good air flow.
    2. Check that the speaker load on each channel is not less than 2 ohms.
    3. Check that the amplifier is not being over driven - red peak LEDs should not be illuminated
    'continuously'.
    This info is for a newer Amp, but should be relatively comparable to your situation.
I have a kitchen aid stand mixer. model #rkt2651x. it goes very fast when turned on then shuts off. it will go again but turns right off again. age?
That is indicative of worn motors brushes or a speed regulation circuit board problem. It is worth getting it fixed.
I just checked and my diagnosis is sound :>)
I have a kitchen aid stand mixer. model #rkt2651x. it goes - Fixya
www.fixya.com/support/t26909658-kitchen_aid_stand_mixer_model
52 mins ago - i have a kitchen aid stand mixer. model #rkt2651x. it goes very fast when turned on then shuts off. it will go - Food Mixers question. SOLVED: Mixer goes really fast then stops
29 Dec 2007
Questions, Troubleshooting Help & Support Page 3
28 Jul 2006
More results from www.fixya.com
KitchenAid Classic Mixer K45SSWH Troubleshooting - iFixit
https://www.ifixit.com/Wiki/KitchenAid_Classic_Mixer_K45SSWH_Troubleshooting Make sure the KitchenAid Mixer is firmly plugged into a working outlet and the cord is not twisted or split. ... If your mixer still will not turn on, it might be a problem with the motor brushes. If the brushes are worn down ... The most common sign of a failing hall sensor is if your mixer increases to top speed and then shuts down. Missing: rkt2651x
Stand Mixer Shuts Off During Use - KitchenAid Product Help
producthelp.kitchenaid.com > ... > Stand Mixer Assembly and Operation Jul 12, 2017 - Once the steam has dissipated, the unit should turn on again (about 3 minutes). Resolution: If the mixer could have overheated during use let the mixer cool for at least 30 minutes and try to re-start. If you were making mashed potatoes when the mixer shut off it's possible that with excessive steam the unit ... Missing: rkt2651x
images for kitchen aid rkt2651x stand mixer goes very ...
More images for kitchen aid rkt2651x stand mixer goes very fast when turned on then shuts offReport images
FAQs - KitchenAid
https://kitchenaid.com.au/faqs Explore our range of frequently asked questions to get the very most out of your KitchenAid product. Missing: rkt2651x
[PDF]Classic Stand Mixer Speed Control - KitchenAid
https://kitchenaid.com.au/sites/.../stand_mixer_service_manual_speed_control_6-12.p... KitchenAid®. Classic Stand Mixer. Speed Control. Theory of Operation. And. Troubleshooting Guide. (revision date 6/19/2012). D. Pahl ... Mixer Does Not Shut Off page 6. Mixer Does Not Turn On page 7 ... the motor is not running (OFF) the governor ball plate is at its farthest forward position and when the motor is running at ... Missing: rkt2651x
How to Replace the Speed Sensor and Control Board on a KitchenAid ...
? 6:28
https://www.youtube.com/watch?v=41qTqTWQkMI Jan 15, 2013 - Uploaded by eReplacementParts.com
This video tutorial will show you how to replace the speed sensor and control board on a KitchenAid Pro 6 ...Missing: rkt2651x ‎turned kitchenaid rkt2651x stand mixer goes very fast when turned on then shuts...
Mar 10, 2018 | Food Mixers
What size fuse is needed for a 600b mixer?
I am guessing you have an older Peavey mixer amp. I believe these mostly used 8 amp fuses although older earlier ones may have used different. It should say on the back at the fuse holder. You can get these at Radio Shack, at better hardware store in either auto electrical or electric sections or on line.
Oct 05, 2014 | Food Mixers
Kitchenaid mixer motor quit , I dont really see any thing wrong with the brushes.
Obtain a copy of the Repair Part List for your model from Kitchenaid.com.
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
First, you may want to adjust the mixer's speeds:
1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Second, if the mixer won't run:
Remove the Control Plate Assembly (36), the Phase Control Board (39)
and the motor Governor Assembly (35). Inspect for loose connections,
burnt or damaged components. If they seem to look OK, re-assemble
them and test the mixer. If the motor still won't run, then I might suspect
a defective Phase Control Board (39).
Aug 01, 2011 | KitchenAid K45SS Classic Stand Mixer
I was grinding some meat and my mixer got very hot. I let it cool down and now it only operates at one speed.
I am not sure what has happened to your mixer but, select
different speeds from Stir to 10. If it runs OK, then there is
nothing to worry about, otherwise do the following to re-adjust the mixer's speeds:
Get a copy of the Repair Part List of your model from Kitchenaid.com
Remove the screw holding the End Cover and locate the three screws from the Control Plate.
All three (2 top left and right, and 1 bottom) must be adjusted.
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 18, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Where does the speed control spring go on a kitchen aid k5ss
Hi NG345, Merry Christmas and Happy New Year! It sounds like you’ve got the right part to fix your mixer, now you just want to install it correctly. The good news is that your replacement spring can be installed quite easily (OK, maybe a little effort) by yourself, if you are a DITY type person and feel adventurous, and your mixer is not under warranty. Be sure you have the Parts List manual on hand, too. If you're lacking one, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM50P (Your K5SS mixer falls within this manual), and select the first file KSM50P.pdf (438.31 KB) listed under Parts List (4) and then check to verify this matches your mixer model.
Turn to pages 6 & 7, titled “Motor And Control Parts”, which provides an exploded view for the disassembly and reassembly of your mixer’s electrical components, along with all the parts. You’ll want to focus on Illus. Nos. 1, 2, 3, 4, & 5; Pivot screw, Spring washer, Speed control assembly lever, Control plate spring, and Speed Link & Cam, respectively. Your speed control assembly is attached to the bottom of the top part of the mixer’s head (or Illus. No 1, Gearcase Motor Housing, on pgs 4 & 5).
Finally, here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer. The mixers displayed in the links are different KA models, but the principles are the same.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer, should you decide to go that route.
If you feel this repair is beyond your capability, then I would seek out a local small appliance repair shop in your area. KA Customer Care can give you names of local KA authorized repair shops in your area, but you can also do an online search to supplement what KA may provide you. Call to explain your circumstances and find out their hourly rate and get an estimate of what they think it would cost to repair your mixer. Also, always obtain three or more estimates – do some comparison shopping.
Good Luck. I hope this helps. Howard, Burke, VA
If this solution was helpful, please rate it, thanks! – hslincoln
Dec 30, 2009 | KitchenAid K5SS Heavy Duty Commercial...
I have a kitchenaid stand mixer & the top is wobbly & hangs lower than it should & the plastic coating on the beater is starting to come off. How can I fix this?
Hi TH1754, you don?t mention your KA mixer model, but you can easily download a PDF version of your Owners Manual from the KA website: (http://www.kitchenaid.com/flash.cmd?/#/page/home). Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number (for this example, I?ve used a KSM90P mixer) and select the last file listed that appears under Owners Manuals: KSM90PSWW0.pdf (2930.74 KB) and save that file to your PC. You?ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the mixer head height. I have extracted the instructions below: Beater to Bowl Clearance Your mixer is adjusted at the factory so that the flat beater just clears the bottom of the bowl. If for any reason, the flat beater hits the bottom of the bowl or is too far away from the bowl, clearance Tilt-Head models ? Unplug mixer. ? Lift motor head. ? Turn screw (A) SLIGHTLY counter clockwise (left) to raise flat beater or clockwise (right) to lower flat beater. ? Make adjustment with flat beater, so it just clears surface of bowl. If you over adjust the screw, the bowl lock lever may not lock into place. I hope this helps! ?Howard, Burke, VA If this solution has helped you, please rate it, thanks! - hslincoln
Nov 30, 2009 | KitchenAid Food Mixers
I have an almost 12 year old mixer, and in the last year it seems the head (for lack of a more technical term), is a little lower so that the paddle attachment grinds on the bottom of the bowl. The...
Tegan, sorry to hear you tilt mixer head is drooping and causing rubbing problems with the mixing bowl. This should be pretty easy to fix, if you?ve got a small blade screw driver and a small hex driver (or jewelers screw driver). First, do you still have the K45SS Parts List? If not, you can download a PDF version from the KA website. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number (in your case, use KSM90P) and select one of the files that appear under Parts List. Turn to page 4 - Case, Gearing and Planetary unit, which shows the exploded view diagram and locate Illus. Nos. 29 & 30. Page 5 lists the parts as Adjusting Screw and Set Screw respectively. What?s probably happened is that over 12 years of operation, the vibrations from your mixer has caused the set screw to loosen and drop, hence the lower mixer head. Both screws will need to be ?adjusted? to move the head back to its original position. Now the problem is removing the head from its pedestal. Turn to page 8 and gently remove Illus. No. 7, Hinge Pin, with a hammer and pin driver. With the hinge pin removed the mixer head and pedestal can be separated and you should have access to adjusting and set screws. I would inspect them for wear and tear, and replace them, if you deem appropriate. It may take a few trial reassemblies to get the mixer head back to the original factory position, but once there, everything should be OK. I hope this helps! Howard, Burke, VA
Nov 02, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Kitchenaid mixer motor makes loud grinding, squeaking noise.
lgardash, Are you sure it's the motor or could it be the transmission?
It 'sounds' like you've got some transmission gear issues, and a situation similar to my wife's mixer, which we got new in Dec 2006. (Within a week of her first using it, she contacted KA Customer Care and the only 'care' they offered was an explanation that the new KA Pro Mixer gears are all metal and to expect it to be louder than previous models that used a plastic gear (to fail). Well, there's an acceptable level of noise, and an unacceptable level (you don't need to be a mechanical engineer to know when something doesn't sound right) and it seems that my wife's new mixer's operating noise level was always unacceptable. It finally 'died' this past October.) OK I've vented enough on KA... now what might be your problem(s)?
It could be as simple as thorough normal use the gears have shifted slightly in the transmission and the gear teeth are making different contact, hence the grinding/squeaky noise. The higher the speed, the louder, higher pitched sound you'll get. Alas, the noise may also be indicative of a potential gear failure (after our mixers increasing noisiness, the bevel gear broke and the mixer 'froze').
If your mixer is under warranty, contact Kitchenaid. If it's out of warranty, then take it apart and do a diagnostic exam of the gearing. Whatever you find you should be able to fix yourself. Be sure to have the Kitchenaid Part Manual (Part No. 8212278 Rev D) on hand if you attempt to disassemble yourself. It also lists all the parts so that you can determine, which parts, if any have failed. You'd think that the Kitchenaid name would warranty their mixers for a lifetime... So much for quality in America today!
I hope this helps, and good luck! - Howard, Burke, VA
Oct 13, 2009 | KitchenAid KP2671 Professional 6 Series...
My mixer just started smoking while i was mix some
Your mixer may still be good, let it cool down and then check it out, If it runs OK then there is no problem. The motor in your mixer probably over heated from trying to mix bread dough which will make any mixer work hard. These mixers will get warm when over worked but unless heavy smoke was coming out and you were getting a burning enamel smell it is probably OK. Let it cool and try it but I suggest you not use it for bread any more.
Oct 08, 2009 | KitchenAid KT2651X Epicurean Stand Mixer
Food Mixers Logo
457 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
