When does this error message come? Does it come while clicking the pictures? Try replacing the memory card of your camera and then check, as usually it is a memory card related problem.
Please rate this solution in case it works for you, it helps us in assisting users like you. In case the problem is still not resolved, do not rate thesolution, leave a comment instead and we shall assist you further.
If you have upgraded your memory card recently, you will probably find that the firmware in the camera will need updating as well (version 1.22) is the latest. To find your current version,with the camera turned off, push the on and disp/back buttons at the same time.If it's not 1.22 go to the fujifilm support site and follow the steps, mine now works with a 2Gb M+ card
SOURCE: fuji finepix a340 digital camera problem
Maye be faulty Camera May be faulty Card. Check by putting another card in.
SOURCE: fuji finepix a340-card error
Storage cards can go bad, but usually this happens only after a long period of
time (years), or if exposed to a magnetic force of some kind.
You can try a few things to resolve it:
1. Try reformatting the card, if the device can process data on it.
2.
Insert the card into a card reader on a PC to see if the drive can be
read. If you can read the card, remove all data and empty the trash,
then reformat it.
3. If you get an error on that as well, replace it.
It's not worth risking that you might lose your valuable pictures to unstable media.
Good luck.
