Question about Dishwashers
TempStar 10 AC
Model # NHP036AkA1.
I need wiring diagram &/or Schematic drawing for this unit.
It pulls to much amps--Unit 15.6 + Heatstrip 40.1--blows breaker.
Unit calls for 45Amp. breaker Max.
Thank you for your assistance.
W. L. Smith
Email [email protected]
  • 4 Answers
Visit www.gotempstar.com for the schematic on this unit. Coincidentally, your air handler unit should not draw 15.6 amps with an additional 40 for the heater.
Posted on Mar 26, 2009
6ya staff
SOURCE:
Gen set blows fuse
no
a fuse is there to protect the circuit and the genset
check why the de-icer is pulling so many amps as the problem may be in that unit
a 10 amp outlet has a maximum current capacity of 10 amps as that is the current allowable from the gen set and wire capacity
even if you had an outlet with 15 amp rating , it would still be blowing fuses as the 16 amps is above the allowable current draw
you would need a 20 amp outlet ( difficult to get unless it is in a house power board and are normally reserved for hot water systems , stoves and other high current usage units and are normally then not outlets but hard wired in to a circuit breaker
Aug 10, 2016 | Kohler Electrical Supplies
Need schematic diagram for philips ba21p6f0102 1 power board
Hi I need the wire diagram or the schematic for my Philips/model/42pfl7403d/f7. I am trying to replace some capacitors on the ac power unit. I made the mistake of removing the two,and forgot where the went. Please help. Miller
Jan 17, 2013 | Philips Televison & Video
Recently purchased a 4400W generator to operate travel trailer primarily and on occasion my ac unit. Connected the generator to the travel trailer, then ran the a/c, everything going well, then the circuit...
What size circuit breaker is on the generator that is tripping? You'll need a 20amp for AC alone, then consider other things that are drawing current when RV plugged in like , converter, fridge etc that may be drawing current at same time. Make sure fridge is on propane, as well as water heater if you have electric element option on water heater. AC may only draw 12-15 amps when running if good and clean and wired properly, but will draw 17-18 amps when compressor kicks in. Perhaps generator not designed for that surge?
Aug 28, 2011 | Dometic Rooftop RV Air Conditioner
Hi!i have old model window-mounted a/c frigidaire FRGFAB067W7B what's power consumption of this unit (kw) ??? haw strong power line I need?
Look on the front left or right side. It should show on
the nameplate how many volts and how many amps
it draws.
Typically if it is 120v and draws 10 amps, then you should be ok with 12awg wire and a 15 amp breaker
Jul 03, 2010 | Heating & Cooling
I have a coleman model 8333A8664 a/c unit on a fleetwood camp trailer and was wondering what watt generator would be needed to run it properly?
Because it won't be powering just your AC, I would recommend 5000W. It's that big amp draw when compressor kicks in that will pull it way down, if not strong enough. Take for example the fact that a dedicated 20 amp breaker and cable are the norm for RV's to use for AC now. Double check also that the generator your purchasing will take a momentary surge draw of up to 20+ amps without tripping breaker on generator. I say 20+ because once RV is plugged in or wired to generator, it will be powering any other hydro operated appliances, lights, converter etc that the trailer has on board. I bought a cheapie rated at 4000W, and 3000 running watts, but it kicks out the breaker just trying to start my portable air compressor, rated at 15 amps.
Jun 10, 2010 | Heating & Cooling
My Coleman Powermate Pulse 1750 generator shuts down
Your generator should run a power tool rated at 10 amps. The 15 amps you mentioned for the PM1750 is for the DC rating. The AC rating is 11.6 amps.
May 28, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Weed eater pulled out red & white wires from thermostat at a/c unit. Red went to yellow and white to ?. Unit is an intertherm unit, model unknown but schematic #703909b
White will usually go to white or blue, you can go to your furnace to verify which wire is connect to the common terminal (c)
May 07, 2009 | Heating & Cooling
Dishwashers Logo
798 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
