Question about Lite On LVW-5005 DVD Recorder
No Discs Does not recognize discs when inserted.
  • 4 more comments
  • pgruok Jan 07, 2008
    Yes...with all discs. I tried using a lens cleaner but it doesn't recognize it either!
    It goes through the regular process. I see the digital read-out saying 'loading discs' then at the end of that it says.."No discs"..all a matter of secs. I have tried store bought discs, discs I copied, you name it.
    I have ...for days.
    Tried restore...nothing changed. Still tries to load then says...no disc
    IN one of your solution helps you mentioned pressing "U" on the remote? My remote does not have a "U"
    Would you please copy and paste for me? Thanks.
    Scholar:
  • 135 Answers
It doesn't need to recognize the lens cleaner, you should try leaving it in there for a few minutes even after it tells you it doesn't recognize it.
Posted on Jan 07, 2008
  • 2 more comments
  • Yonatan Horan Jan 07, 2008
    The connection between the disk drive and the board might be faulty, you can try tightening it. Otherwise, the disk drive itself is probably faulty.
    If the problem is a faulty drive, which I assume it is, you can replace it with one of the following drives:
    Liteon SHW 160P6S
    Liteon SHM 165H6S
    Liteon SOHW 1693S
    Liteon SOHW 1673S
    Liteon SOHW 832S
    Liteon SOHW 812S
    Liteon DW1670
    Liteon LH 20A1P
    Liteon LH 18A1P
    Sony AWQ170A
    Sony DRU-120C
    Sony DW-G120A
    Sony DRU-820A
    Sony DRU-830A
    LG Electronics GSA-H42N-BK
    If you're comfortable enough opening the drive (if it's under warranty it'd be better for you to just have it serviced), you should open it and try to clean the laser yourself (unlikely it'll work but it's worth a try). Then, if that fails, you can replace the broken drive with an SHW-160P6S or the SHM-165H6S and it should work just fine. You can read instructions on how to do this here (you need to sign up to view them, I can copy\paste for you if you wish).
    As requested, here's the post I linked to:
    "I had the often reported problem of a dodgy DVD burner ... and I didn't
    want to send it back under warranty because the HDD is full of my
    valuable recordings. As I understand it there is a risk of getting an
    empty hard disk back.
    So I read the forums and decided to buy a 165P6S ... as far as I can see no one else has reported doing this yet.
    Interestingly
    as well as being able to read/write everything I can throw at it now
    ... it can also read the DVD-RAM disks from my camcorder. I haven't
    tried writing to them ... I've no need and why risk a good disk?!
    Reading them is really useful though.
    The new burner stays
    sealed, no need to open it up or leave the innards exposed like the
    original unit. It's nice and quiet too. Incidentally cleaning the
    original lens with alcohol didn't work.
    So, how do you do it?
    You
    need to be prepared to bend a couple of brackets and cut a few bits of
    plastic with a stanley knife ... but it's not too hairy, nothing I did
    would have stopped me putting the old drive back in.
    First, read these - they give details/photos on how to do some of the following steps:
    http://club.cdfreaks.com/showthread.php?...
    First,
    I put the new drive in a PC, updated the firmware and made it region
    free (all this is described elsewhere on these forums).
    Take the old drive out, you don't need the metal cage for the new drive.
    Take the front plate and bezel off the new drive.
    Put in the new drive.
    It
    won't quite go through the front hole, there are several things
    stopping it going far enough forwards ... so carefully deal with them
    one at a time:
    - bend the 2 metal brackets right back
    - unclip
    the front panel of the 5045 (don't yank it off, there are trailing
    wires), cut the obstacle plastic pillar off (it doesn't seem to have a
    purpose) and then cut another plastic bit off that is in the way (hard
    to see this one). Only cut something if it is in the way and doesn't
    have an obvious purpose! All the bits I cut were small and (seemingly!)
    insignificant ... this is not a big job.
    Swap back the old drive
    and check that both drives come forward the same amount (I had to bend
    2 more metal tags out of the way).
    Finally you will have a
    snug/tight fitting new drive. You can't screw it down, but the fit is
    easily tight enough to hold it. I also used some sticky pads to hold it
    just in case I transport it one day and forget that the drive could
    come loose. Not really necessary though.
    If the drive isn't
    forward enough then when you put the original bezel back on the drive
    won't close properly ... just go back and move the obstacles. I cut the
    bottom two plastic tags on the front bezel so that it slides on nicely
    ... I also had to trim the middle one of three other tags on the bezel.
    Obviously
    I can't guarantee success and you will undoubtedly invalidate your
    warranty, but it's worked for me with no downside. Unplug before doing
    anything. Take antistatic precautions and if something won't budge then
    don't force it! Proceed at your own risk.
    Finally, take some photos and post them here or cdfreaks ... I wish I'd done that.
    Great forum guys ... glad to add my bit to the knowledge pot.
    BTW I'm running 2.03, not sure what will happen if I try to go to 2.04!"
    President:
  • 1,944 Answers
Does this happen with all discs?
  • 5 more comments
  • Damen Wong
    Damen Wong Jan 07, 2008
    Did you try using a lens cleaner?
  • Damen Wong
    Could you please tell me what exactly happens when you load the disc. Do u hear the disc spin and does your unit try to read the disc? After how long does it tell you that there is no disc inserted?
  • Damen Wong
    Did you try a system restore?
    Press on the remote:
    SETUP, right (cursor), down (cursor) 6 times, right (cursor), then press ENTER
  • Damen Wong
    Reset by pressing [u], “5,” “0,” “0,” and “1” on
    the remote control and then press [ENTER].
  • Damen Wong
    I would suggest a firmware upgrade but your drive doesn't read any discs.
    You can also try if you want, disconnect the unit from the power for a few hours and then reconnect and try to operate (this resets the unit).
    Chances are that your unit has developed a hardware failure and needs to be serviced but I would try reseting anyways...
  • Damen Wong
    sorry...U = play triangle
  • Damen Wong
    Did you try the restore in the setup menu?
MY CONSOLE KEEPS SAYING CAN'T READ DISC
The most common reason for the games not reading discs is a bad drive. The following website sells the drives and does installs:
store.richspsxparts.com/wiiredvddr
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your game including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your game going again!
Take care.
Aug 20, 2010 | Nintendo Wii Console
Games discs purchased in the USA do not work on the UK model? Message on screen "could not read Disc"
The Wii console is designed to only recognize the disc in that region.
If you insert a disc from another region, the Wii can't read it.
You live in the UK, for example. If you insert discs that aren't purchased in the UK (like the USA), the Wii can't read it.
Apr 24, 2010 | Nintendo Wii Console
I have a Sony Psyc CD Walkman D-Ej010 and I will have a cd in there at it will play for a few minutes and then stop and say no-disc. What could be the problem?
There may be a couple of reasons why a NO DISC , DISC ERROR or INSERT DISC error may appear in the display of your CD player. Try doing the following steps to troubleshoot why the error is displayed:
  • For disc players with a HOLD switch, make sure to move the switch to the OFF position.
  • Verify that the disc being used is supported by the CD player. NOTE: CD players do not support VCD or DVD discs. In addition, some CD players do not support CD-R or CD-RW discs that are created by a CD burner. For information regarding disc compatibility with your player, refer to the operating instructions supplied with the product
  • Ensure a disc has been inserted into the player. Make sure that the disc is inserted correctly, with the playback side of the disc facing down on the disc tray.
  • If the disc still does not play, attempt to play a different, commercially-produced disc.
  • NOTE: If more than one of the commercially-produced discs do not play, verify whether the discs are extended-length discs. Some players are not able to play discs where the recording exceeds the standard 74 minutes. If the recording of the disc is longer than 74 minutes, it is possible that some of the specifications of that disc were compromised and therefore, the CD player will not recognize that disc.
  • If the disc is dirty with fingerprints or smudges, or if the disc is scratched or broken, the CD player may not recognize the disc.Clean the disc using a soft, dry cloth.
  • Properly reinsert the disc into the player.
  • Attempt to play the disc again.
  • Only press the PLAY button once. If the PLAY button is pressed more than once, the disc may stop playing.
  • If the disc is still not recognized, remove the disc and leave the CD player powered on for approximately one hour to resolve the possibility of moisture condensation inside the player.
  • Please use a Lens Cleaning disc and check if that helps.
If the issue persists, please click hear to locate the repair facility near your area.
Thanks for understanding. Please let me know if you require any clarifications.
Jan 29, 2010 | Sony Walkman D-EJ010PS Personal CD Player
Disc inserted for recording, "no disc"?
Have you tried other discs? Are the ones you are trying to use supported by the recorder? If so, see if a DVD burner in a PC will recognize the discs. You may want to try a different brand as well in the recorder.
Jan 03, 2010 | Panasonic DMR-ES10 DVD Recorder
My cd-dvd drive does not recognize discs, so movie discs are not played when I use Win Media player. I insert a disc and there is no automatic recognition of inserted disc.
You should clean your CD-Drive lens with Disk cleaner Cd that will work or move anticlock wise and your problem will be solve after cleaning the lens.
Good Luck
Nov 30, 2009 | Fujitsu Siemens LifeBook® S7110 PC...
My Initial DVD player does not recognize discs at all
replace the optic lens and the spindle motor or if you do not have time try to purchase a optic assembly so that its easily to replaced.you have to purchase is the same model as your unit brand.
Sep 24, 2009 | Televison & Video
Disc drive stopped recognizing discs
This is fairly common, it means the actual DVD drive has failed. You will need to call Nintendo. There is a good chance it is still under warranty and they will fix it for free. Their number is 1-800-255-3700
Aug 08, 2009 | Nintendo Wii Console
Ps3 will not recognize discs of any type when inserted.
Call sony or take your ps3 apart and clean the lens
Jan 05, 2009 | Sony Playstation 3 (PS3) Console
I get the same error
Are you trying to play HD-DVD with out the XBOX HD Player?
Aug 18, 2008 | Microsoft Xbox 360 Console
hey try the first move of this web or the 2nd good luck http://support.microsoft.com/kb/320553
Apr 07, 2007 | Memorex (32023292) DVD±RW Dual Layer...
Lite On LVW-5005 DVD Recorder Logo
142 people viewed this question
Top Lite On Televison & Video Experts
Jaime Hernandez
jason
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
