Question about JVC MX-GT90 CD Shelf System
FM RADIO DOES NOT COME IN
MY FM RADIO DOES NOT COME IN. ALL I CAN GET IS STATIC. CAN YOU HELP ME?
    President:
  • 4,402 Answers
Either the tuner is bas or the antenna is not hooked up.
Posted on Jan 07, 2008
I need to get a unlock code for my JVC stereo
Posted on Jun 26, 2008
My old unit stopped working;(worked perfect for many years) so I replaced with a new same model and I have bad interference and FM static. Sometimes the FM station overrides the express radio and all you...
The very first XM radios, (SkyFi2, MyFi, Roady2) up until they were put in red boxes, had a VERY strong FM transmitter, so strong, that when Sirius was their enemy, they complained to the FCC and they made the FM transmitters real weaklings. So unless you have one of the first two batches of XM radios, the FM transmitters now are real junk and you're better off using an AUX input on the radio or a cassette tape adapter. Okay? Thanks.
Mar 26, 2015 | Audio Players & Recorders
I Lost FM on my Tivoli Model One. While FM was playing I touched the radio and gave it a static shock (very dry climate) and lost the FM. AM and Aux are fine.
It will need to go to a service centre for repair. Most probably the static electric jolt will have taken out either the FM RF amplifier of the FM mixer, meaning it needs component level repairs :o(
Sep 20, 2013 | Tivoli Kloss Model One AM/FM Radio
The static level is so high I am unable to hear the radio.
Under menu, select FM frequency. Try using different frequency. A nearby FM station could be bleeding its signal onto the FM frequency your unit is using by default.
Jan 09, 2011 | Delphi Roady XT XM Radio Receiver
I noticed static on fm station on my radio. the
i would get the alternator checked, sounds like its leaking ac current which can also kill the battery
May 04, 2010 | 2006 Subaru Forester
I have a lot of static when i'm listening to AM radio on my bose radio
FM reception is good; however there is a lot of static on AM 1000. No problems on other AM stations. Any suggestions or than stop listening to "1000"?
Nov 24, 2009 | Bose Wave Radio
No FM radio; only AM
check antenna make sure its tight and connected.
May 17, 2009 | 1998 Jeep Grand Cherokee
AM radio has constant static -- FM is perfect, as is the sound system. The AM radio has no static when engine is not running. Please help
the cause of this is a defective is due to one of the following:
1. Antenna is defective or Antenna coax lead to radio shield ground
2. Antenna ground is dirty or corroded
3. Poor radio chassis ground.
Apr 21, 2009 | 2003 Kia Sedona
Am radio not working
THIS SOUNDS LIKE YOU HAVE A RADIO PROBLEM. IT MAY BE WORTH YOUR TIME TO HAVE A DODGE DEALER CHECK THE RADIO TO SEE IF INDEED THE RADIO IS BAD, BUT THEN YOU HAVE THE OPTION TO REPLACE THE OEM RADIO WITH A NICE AFTERMARKET RADIO. THESE HAVE COME DOWN IN PRICE DRASTICALLY AND ARE PROBABLY CHEAPER THAN REPLACING THE OEM RADIO. WITH NO SIGNAL OR STATIC ON THE AM BAND SURE SOUNDS LIKE THE AM BAND IS DEAD. IF I CAN HELP MORE REPLY TO: ARCLIGHT1217
Jul 07, 2008 | 2001 Dodge Stratus
Radio set up on samsung j700
FM radio works the same way that AM radio works. The difference is in how the carrier wave is modulated, or altered. With AM radio, the amplitude, or overall strength, of the signal is varied to incorporate the sound information. With FM, the frequency (the number of times each second that the current changes direction) of the carrier signal is varied. FM signals have a great advantage over AM signals. Both signals are susceptible to slight changes in amplitude. With an AM broadcast, these changes result in static. With an FM broadcast, slight changes in amplitude don't matter -- since the audio signal is conveyed through changes in frequency, the FM receiver can just ignore changes in amplitude. The result: no static at all.
For sellecting frenquencies, go to radio, options, set frequency and search...
Jun 13, 2008 | Samsung Cell Phones
Connect sirius fm adapter to 2008 honda civic sedan radio
You should use the direct FM box to get the static to go away. You unplug the antenna from the radio, plug the antenna lead from the box into the radio, the antenna line plugs into the box. You will have a mini jack that plugs into your radio or dock.
This way you can switch it on any station to get rid of the static.
You shouldn't need to take the dashboard out to get to the radio. Usually you have to take the trim pieces in front of the radio to get the antenna line out.
Sometime you can reach it from the back of the radio if there is enough clearance to get cak there.
Jun 12, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
JVC MX-GT90 CD Shelf System Logo
232 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
