Question about Lite On LVW-5005 DVD Recorder
No discs inserted
MY LVW-5005X DVD Writer does not recognize any discs I put in it! Help!
  • 31 Answers
This is a common problem with the Lite-on LVW range of DVD recorders due to changes in the construction of more recent DVD R media. It can be solved with a relatively simple firmware upgrade.
Goto : http://r00.liteonit.com.tw/DC/english/download/index.asp
You'll need to have a blank CD and a CD/DVD writer in the PC you use to download the file.
Follow the instructions to upgrade your firmware, this should then allow you to write to DVD's once again.
Posted on Mar 06, 2008
    Problem Solver:
  • 12 Answers
You rated that suggestion 'inappropriate' after the guy took the time to try to help you out for free. You know, Frankie has met some real ungrateful S.O.B.s in his time (and fixed a few too) but most of even them didn't tend to crap on people who were trying to help them... for free! (and these are the types that would k-ll you as soon as look at you.
Good luck to you getting any help, on here or anywhere. With your attitude you really don't deserve any.
Posted on Jan 31, 2008
    Novelist:
  • 189 Answers
Sounds like a media compatibility issue. If you are using high speed DVD+R discs you may wish to try a lower speed +R or even try -R. I had a similar problem with a DVD writer a while back and although the documentation for the unit said it supported +R I couldn't get it to read or write to anything but DVD-R discs.
Posted on Jan 07, 2008
6ya staff
SOURCE:
Sony vx-515 dvd tray won't open
Mine was a Sony TS-P532 DVD in a Model GX315 player. A BLU-RAY disk got inserted and won't eject. Remove the player cover and on top of the drive is a 3 X 3 (approx) metal plate with a plastic wheel visible in it. Un clip the two sides of the metal plate and it will pivot up and the disk can be removed.
Mar 26, 2014 | Lite On LVW-5005X DVD Recorder
Manual for LVW-5005X CD/DVD need copy Have the Player need manual to hook up to TV
The user's manual is available from Lite-On as a .zip file. http://us.liteonit.com/us/index.php?option=com_wrapper&Itemid=153 Select Audio/Video and then your model number in the two drop down menus; then click Search.
The direct link is http://www.liteonit.com/DOWNLOADS/DC/LVW-5005X/user_manual/en_us/LVW-5005X_US_English.zip .
You will need to unzip the file to read the document. With Windows, right click on the file after downloading and select "Extract All".
I hope this helps.
Apr 30, 2011 | Computers & Internet
I have a DVD Recorder, Lite-On LVW-5005X. I have been having sporadic problems with the disc tray not opening for some time. But usually after repeated attempts, it would open. I have recorded and...
You need to replace the disc tray belt,it streches with age.It is called a square belt,size 1.9.To open try tapping on TOP of cabinet with your knuckles just above the disc tray door.While you are doing this press the Open button.Once again this must be done at the same time,the door will open 90% of the time.When you get it open you will see the little black square belt,this can be removed and replaced with a twizzers.Make sure belt is in the track if not it will jam and door won't close.
Dec 10, 2010 | Lite On LVW-5005X DVD Recorder
Liteon DVD recorder LVW-5045 has disc inside and won't open tray
Use your knuckles to knock on top of cabinet just above disc tray door while at the same time pressing open button,99% of the time disc tray will open.The problem you have is caused by a worn out belt drive or the tray is out of alignment.The disc tray belts only cost $2,when tray is open you can see the minature belt that controls door to the right.Use twizzers to remove and replace.Belt size 1.9
Aug 02, 2009 | Lite On LVW-5005X DVD Recorder
Liteon Dvd VCR Recorder tray has a disc in it but I cant open
CLICK ON START
CLICK ON COMPUTER
RIGHT CLICK ON THE DRIVE IN QUESTION
CLICK ON EJECT
(MAY HAVE TO DO MORE THAN ONCE)
Mar 11, 2009 | Lite On LVW-5005X DVD Recorder
Doesn't recognize disks anymore
i would try lens cleaning cd 1st ok might be dirty lens just cant read it if not that try firmware update to the unit thx nick
Feb 04, 2008 | Lite On LVW-5005 DVD Recorder
No Discs
Does this happen with all discs?
Jan 07, 2008 | Lite On LVW-5005 DVD Recorder
Follow the instructions on the website to upgrade your firmware, this should then allow you to write to DVD's once again.
Dec 29, 2007 | Lite On LVW-5005 DVD Recorder
LVW-5005X DVD Recorder setup tv tuner
You have the wrong firmware,or cd is corrupted.These Liteon recorders have had some issues with the timers.The 5005xa can actually be transformed into the Ilo R04.Look on internet the Wizard has free firmware for your unit, look for iLO R04 which is almost identical to your unit.
If the remote is broke they are easy to replace ,if the recorder is a 5005xa the remote is a clone to ones used in the iLO RO4,used ones can be bought on Ebay for $10 to $20.If it is 5005XSA use the Liteon Rm 51 remote.The Gateway AR 230 recorder and some of the Akai remotes are clones to the Liteon5005XSA remotes.
Jul 10, 2007 | Lite On LVW-5005X DVD Recorder
Lite On LVW-5005 DVD Recorder Logo
129 people viewed this question
Top Lite On Televison & Video Experts
Ekse
Damen Wong
Damen Wong
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
