Whirlpool RBS305PDS Electric Single Oven
Problem for Whirlpool RBS305PDS Electric Single Oven
I have a whirlpool electric
By oh2bnol on Nov 11, 2009
I have a whirlpool electric (slide in) oven and the panel controls are all working, but when I turn on the oven the oven says it is preheating but when I open the door it is cold inside. model # RBS305PDB16
Comments:
Nov 11, 2009
- I have read your response but now I am trying to figure out how to remove my oven from the cupboard it is sitting in. I cannot seem to find out how it is put in there. Is there anyway you can help me with this problem?
Nov 11, 2009
- Hello,
I have the oven out of the wall and I am looking around it. Can you tell me how you tell if the "oven temperature sensor" is bad or not? The control pannel does not look fried and there are not fuses.????
Solution #1
posted on Nov 11, 2009
Not Rated)
super_guy
Rank: Guru
Rating: 97%, 8209 votes
I'm afraid you may have a blown Electronic Oven Control (EOC) board. The EOC controls all the functions of the oven. A replacement EOC can be purchased on line for around $200.
This is a very simple repair that any do-it-yourselfer can accomplish if you wish to perform this on your own. All you have to do is UNPLUG the appliance and remove the back panel of the console to access.
Before assuming the EOC is defective, however, inspect the board to see if it has a fuse on it. I do not have a wiring diagram to confirm. Some of these boards do have fuses and that's all that it may take to repair it. However, if the board shows signs of burned components, replace it. NOTE: Check for any loose connectors to the board as well.
Comments:
Nov 11, 2009
- http://shared.whirlpoolcorp.com/product_literature/search.jsp should have a copy of the manual to show you how to remove and install the unit....
I haven't worked with your particular model before.
Solution #2
posted on Nov 12, 2009
Not Rated)
justaskjoe
Rank: Wiz  Whirlpool Ovens  Expert
Rating: 85%, 2876 votes
Fuse/circuit breaker Check to see if power is getting to the range/oven. Does anything turn on--even a light? If not, check for a blown fuse or tripped circuit breaker. Main wiring Often the main wiring connection from the house, at the range/oven, gets burned and so breaks the connection. Then you may have to replace the power cord to the range/oven, and the terminal block that the wire is attached to. Range/oven wiring There may be a broken or burned wire at the back of the range/oven. If you repair any of the wires, use only proper appliance-grade wire and wire connectors. It won't bake Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it. It bakes poorly Here are two instances of when food "bakes poorly:" When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out. You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results. If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component. When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly. If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem
Popular Solutions for Whirlpool RBS305PDS Electric
Questions and Unsolved Problems for Whirlpool RBS305PDS Electric
Do you recommend Whirlpool RBS305PDS Electric Single Oven?
Answer
Answer
code state FSE 1 and was beeping
Answer
We just moved into pre-owned home in December, and I used the self-clean feature on the oven on... (More)
Answer
I have an 8 year old Whirlpool Gold Accubake system self cleaning oven. When I set it to broil the... (More)
Answer
Our oven will not heat up. Wife did used the self cleaning this afternoon and now it will not heat... (More)
Describe your Ovens problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Oven Experts
Top Range & Oven Repairmen
(800) 555-9987
All the services you need in order to get your...
Home Blue
(443) 304-2116
A Leader In Kitchen Equipment Sales,...
Allegro Restaurant Repair
Chat Now
Insert Link
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Step 2: Select a product and click on add
I can't find my product
select
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
