Question about NorStar T7316E Corded Phone
Change time on display
How do i change the time on the display? i've looked thru the manual and was not able to find anything.
Feature **time
and feature **date
Posted on Jan 08, 2008
6ya staff
SOURCE:
How do I change the setttings in my phone to ring more times before it goes to voicemail?
look it over many have a button that slides to change that or look thru the setup menu.or manual
Jan 26, 2016 | RCA ViSYS 25423RE1 4-Line Telephone, Blue...
I have a Honeywell CM921 thermostat. I stupidly let my young daughter play with it but shes now changed something on it and i haven't got a clue how to change it back as i don't know what the problem is TO...
Press the time button once. The display will show 'RESET PROGRAM'.
Press the or buttons to select the preferred setting (0=user program,
1=factory program) and the display will flash, indicating a change has been
made. To confirm this change press the green button.
and don't let your kid play with it again until next year when her grasp on technology exceeds the current model smart phone... LOL
Dec 13, 2014 | Heating & Cooling
L40fhd41 overheating?
likely the panel (screen or display unit)
Apr 19, 2012 | RCA L40FHD41 40. in HDTV
My Wi-Fi on Lenova Think Pad T60 is not working. I tried to update the drivers. Still not working.
What is it doing? Still not working could mean a lot of things!!! Is the computer connected to the wireless network? You've got to connect to the network before you can do anything. And most times the problem with connecting to the network is people key the network key or password wrong so the wireless just keeps on polling trying to connect.
Do you have the wireless turned on on the notepad? Sometimes there might be a wireless switch somewhere that you have to turn on. Also most times you can toggle the wireless On and Off by hitting the FN Function key and the corresponding F1 thru F12 key that toggles the wireless. Most times the correct F1 thru F12 key will have a wireless icon signal on it sorta like ))))) or it may show a tower with the signals. Once you find the correct F1 thru F12 key to press then Press and Hold the FN Function key then hit the correct F1 thru F12 key. If you look at your screen most times it will let you know if you've toggled the wireless by displaying Wireless On or Wireless Off.
Mar 29, 2012 | Computers & Internet
How do I change the time display on Norstar Startalk 180 - can't find anything in manual relating to this?
the startalk takes does not store the time, it takes the time and date from the phone system. to change the time on the phone system try feature **TIME (8463) password CONFIG (266344) from a phone with the 3 soft buttons under the display it does depend on the model and software level as to whether this will work and also presuming nobody has changed the default password
May 19, 2010 | NorStar Startalk Flash 2 Phone
Changing the time
you can go to http://www2.oregonscientific.com/assets/manuals2/bar338pa.pdf to see or print the user's manual.
If you don't want to get the manual, here's what you do to fix it. . . . .
*note: you need to do this anytime you change the batteries.
1) open the battery cover
2) on the left side you'll see 3 little buttons labeled a)zone, b)C/F c)reset
3) push the reset
4)push the zone button until your time zone is highlighted on the front display
5) look at the front display & if you see a blinking "radio signal" icon at upper left of time numerals
don't do anything else. The time, date, etc. will automatically synchronize your clock with the US Atomic Clock. This could take up to 10 minutes. As long as the "radio signal" icon is blinking, it's working on it. When the icon doesnt' blink, it's set. Cool, huh?
6) if the area you live in can't receive the signal from the Atomic Clock, instead of a blinking "radio signal", you'll see just a bare antennae. Since you probably set your clock manually, that's what it shows now before you do anything.
7) after you push reset & set the time zone do NOT touch any other buttons to set anything!!! (I know it's difficult to leave things alone, but just sit on your hands). Pushing the "clock" button or the up & down arrows will stop the radio signal & change to manual functions. Look at the signal icon mentioned in 5) and 6) above. If you only have the bare antennae icon. . . . . go ahead & set the time/date yourself. You have no signal.
Enjoy your clock!
debkresh
Jan 25, 2009 | Oregon Scientific FM Weather Projection...
Eclipse 5440 Manual Needed
I had the same problem until a minute ago:
1) press and hold the display button
2) using buttons 1 thru 4 set the time while holding the display button down. ( buttons 1 and 2 adjust the hour, buttons 3 and 4 the minutes...
Good luck
Jun 12, 2008 | Eclipse 5440
The clock time is off, how can i change it?
The only way to change this is going thru the menu and you need the control remote. I had the same problem until I found my remote control to fix it
Jan 26, 2008 | Cyberhome DVR 1600 DVD Recorder
Changing language dell 922 printer
To change the language on the Dell 922's display, turn on the printer, then press and hold the Power and Cancel buttons at the same time for about 10 seconds. The language choices will then scroll across the LCD press the up or down arrow key till english appears, then click Menu.
Sep 15, 2007 | Dell 922 All-In-One InkJet Printer
NorStar T7316E Corded Phone Logo
187 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
pbxinc
martin hogg
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
