Question about Nintendo Wii Console
Will not turn on from time to time.
We keep experiencing problems with turning on the console. We have disconected everything and reconnected it. We have pushed the red reset buttons.
    President:
  • 4,402 Answers
Can you brow row a friends power supply and try that one see if it still happens
Posted on Jan 07, 2008
My xbox 360 is now showing flashing 1 red light on and off
These steps are taken from the support site as always, it's the first website where you should look.
Solution 1: Disconnect and reconnect cables
Here's how:
  1. Turn off your Xbox 360 console.
  2. Unplug all memory units, controllers, and accessories from your console.
  3. Unplug everything from the back of your console, including power and video cables.
    Don't remove the hard drive.
  1. Reconnect your console's power supply.
  2. Reconnect each accessory one at a time, starting with a controller.
  3. After you've reconnected every accessory, turn the console on.
Solution 2: Remove the hard drive
To see whether the problem involves the original Xbox 360 Hard Drive, temporarily remove the hard disk drive. Here's how.
Note Not all Xbox 360 consoles include a hard drive. If your Xbox 360 console doesn't have a hard drive, to go Solution 3.
  1. Turn off the console.
  2. Locate the hard drive on the top of the console (or on the left side, depending on how the console is oriented).
  • Press the release button on the hard drive.
  • Lift the hard drive away from the console.
hdseparating.jpg If these steps resolve the issue, reattach the hard drive to verify that the error occurs only when your Xbox 360 Hard Drive is connected.
Solution 3: Disconnect memory units or USB flash drives
Here's how:
  2. Unplug any memory units or USB flash drives attached to your console.
  3. Turn on the console.
If these steps resolve the problem, reattach the memory unit or USB flash drive to make sure the error occurs only when it's connected. If this is true, order a replacement memory unit or use another USB flash drive.
Solution 4: Request a repair
If the previous steps don't resolve the single flashing red light issue, there are no additional troubleshooting steps. Your original Xbox 360 console must be repaired at our service center. Start the repair process online.
Jan 09, 2015 | Microsoft Xbox 360 Console
Wii shuts down
HI, the power sector has failed in your unit. this will cause the issues you are experiencing at this time. you will need to contact Nintendo at this time. they will issue you a repair ticket so that this unit can be repair. the power sector will need to be replaced(Power component failure).
Jul 28, 2009 | Nintendo Wii Console
Can i get rid of error E 74 myself
This is from the microsoft site...
  1. Turn the console off and on. To do this, follow these steps:
  2. Turn off the console.
  3. Disconnect all the cables.
  4. Reconnect all the cables.
  5. Turn the console back on.
  6. Turn the console off and on without accessories. To do this, follow these steps:
  7. Turn off the console.
  8. Disconnect any accessories that are connected. For example, disconnect all Xbox 360 controllers, all Xbox 360 Memory Units, and the Xbox 360 Hard Drive.
  9. When the accessories are disconnected, restart the console to determine whether the console or an accessory is experiencing the problem.
Jun 22, 2009 | Microsoft Xbox 360 Console
Xbox 360
This problem occurs when the Xbox 360 console experiences a general hardware failure.
You can submit a console-repair request online at Xbox.com. However, before you submit your request, first try the following steps to verify the problem:
    2. Disconnect all the cables.
    3. Reconnect all the cables.
    4. Turn the console back on.
  2. Turn the console off and on without accessories. To do this, follow these steps:
    2. Disconnect any accessories that are connected. For example, disconnect all Xbox 360 controllers, all Xbox 360 Memory Units, and the Xbox 360 Hard Drive.
    3. When the accessories are disconnected, restart the console to determine whether the console or an accessory is experiencing the problem.
If it does not work go here
http://support.xbox.com/support/en/us/nxe/LiveIDSignIn.aspx?redirectUrl=http://support.xbox.com/support/en/us/nxe/registerdevice.aspx?step=repair
May 22, 2009 | Microsoft Xbox 360 Console
First the red ring and now my xbox 360 wont turn on!?!
well you screwed thats what red ring does just try un plugging it and keeping it in some towels
Mar 28, 2009 | Microsoft Xbox 360 Console
Xbox will not reconnect to Xbox live
Please take the time to shut down your modem and router. Turn the modem on first give it like 2 minutes to turn all the way on. Then power up the router. Your setup may just be a little confused about the xbox joining the network. If this does not help let me know.
Mar 17, 2009 | Microsoft Xbox 360 Console
Error code e74... help
Hi! Here are some steps that you can use to try to resolve the issue.
1. Turn off the console, disconnect all the cables, and then reconnect all the cables. Turn the console back on.
2. Turn off the console, and then disconnect any accessories that are connected. For example, disconnect any Xbox 360 controllers, Xbox 360 Memory Units, and the Xbox 360 Hard Drive. With the accessories disconnected, restart the console to see whether the problem still occurs. This can help you determine whether the console or an accessory is experiencing the problem. If you determine that an accessory is consistently causing the error, try borrowing another accessory of the same type and testing again using that accessory.
3. If the steps did not resolve your issue, your console may have to be repaired.
4. Try contacting Xbox Customer Service. For USA or Canada, it is 18004MYXBOX and ask for the Hardware department.
Mar 11, 2009 | Microsoft Xbox 360 Console
Pioneer DEH P6000 screen reads "tuner er"
try disconecting your battery while its on then reconnect
Jan 01, 2009 | Pioneer DEH-P7000BT Car CD/ MP3 Player
Red light on startup
This happened to me 2 or 3 times.I checked the power supply and found that it was loose(the one in the back of the actual 360 console)when I pushed it in properly,is worked fine,i have not got this problem at all since then.So just make sure the power supply is properly connected.
Jan 17, 2008 | Microsoft Xbox 360 Console
Dishwasher shu5305uc
This could be many things, firstly turn of the main feed hose, disconect one end and reconnect it and turn it back on. see if this solves your problem.
Oct 22, 2007 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Nintendo Wii Console Logo
27 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
