Question about Nintendo DS Console
Calibrate when i try to calibrate my nintendo nothing hapens when i tap the little sqaures and the touch screen will not work at all!!!
    Champion:
  • 268 Answers
If you havnt had the ds for very long the place you bought it from should sent it out for free
Jack
Posted on Apr 22, 2008
When i am trying to take my dogs on a walk on nintendogs, it doesn't work Or on pictochat when i try to color the bottom of the page, that doesn't work either. please help me, i don't have te money to go out and buy a new one...
Posted on Jan 20, 2008
    Novelist:
  • Nintendo Expert
  • 127 Answers
If the units touch screen dont work properlly or dont work at all then you need to change your nintendo DS touch pad or send it to service to do it.
If you are technically inclined you can buy a replacement in any online store and replace it by yourself but its a bit complicated as you practically need to carefully dissasemble all the unit to do that and would need at least some skils, a special thomson 3 windings small screwdriver (sometimes the same store sells it) and small blade and philips screewdrivers. You can find a video and instructions to do that over the web and decide if too difficult for you.
Here is a guide on how to dissasemble the NDS, though you can find videos about that in youtube:
How to dismantle an Original Nintendo DS.
Good Luck...
Posted on Jan 18, 2008
The calibration on my samsung impression was way off so i used the unlck code *2767*3855# the phone shut down and restarted and at the calibration screen tapped the center of cross many many times cross...
OK..your touch screen was jammed or not working and you did reset via code *2767*3855# then the phone restarted with the calibration cross....you tapped the cross but nothing is happening.......what to do? first shutdown the phone remove the battery for 30 sec also remove the simcard put the battery again start the phone when the calibration screen pops up tap on the cross here you must feel the tapping is working by feeling a light vibration of the phone.....then tap on the lower bar of the screen which has color (light gray) different than the calibration screen the cross will move to another corner......repeat this for all four corners then you should see and OK on the bar to save and exit to the normal screen........done
Jan 03, 2011 | Samsung SGH-A877 Impression Cell Phone
The touch screen isn't responding very well, sometimes it will react to a tap but mostly the screen is non responsive, the keys work ok when scrolling on a menu screen. any ideas?
first try to calibrate the touch screen.Take all games out turn on then go to the very small ds on the bottom touch screen. If you can't touch it move it with the cross down then hit a. Then select the option all the way to the right it looks like cross hairs that's the calibration screen fallow instructions. If that doesn't fix it it could be a broken screen or a loose ribbon.
Feb 24, 2010 | Nintendo DS Lite Console
My little girl was playing with my htc and put a 3" wrapping tape on the touch screen. when i was taking it off, the clear cover was coming. I pull it about half way before I took the tape off. then the...
Try calibrating the device again.To recalibrate:
Tap Start >> Settings. Go to System tab and tap on Screen. Now select to Align/Calibrate screen from there and follow the instructions. Tap Ok after the calibration is complete. Soft reset the mobile and then check again,
Nov 11, 2009 | HTC Touch P3450 Smartphone
Ds tough screen wont work (not the lite(the old kind)
try the calibration in the options. try tapping or if not working, use your buttons. tap or use the button to make the origin at the center of the screen.
Feb 11, 2009 | Nintendo DS Lite Console
Ipaq 3715 tapping problem
have you downloaded any viruses? if not try another hard reset is the screen cracked?
Jan 07, 2009 | HP iPAQ RX3715 Pocket PC
Nintendo ds
when u go to settings in the main thing when u turn it on you have to hit the buttons percisely like bulls eye on the dot or nothing will happen.there is another chance that your touch screen may be broken from taping it to hard or doing somthing to it so it may be harder to tap it but if ur screen is broken well.........then if it goes completely out like when u touch it then its broken for sure but that may solve ur problem
Oct 26, 2008 | Nintendo DS Lite Console
Mynintendo ds promblem
call nintendo and see if they will fix it. bet it has something to do with being dropped. like the things in the touch screen lost its sense and wont work. if they fixed my gameboy when i was little and got alot of water in it, theyll fix your DS
Jun 06, 2008 | Nintendo DS Lite Console
UNABLE TO CALIBRATE TOUCH SCREEN
The only possible fix is to try to clean the edges of the screen in case any particles are trapped between the screen and the case, this can confuse the touch screen.
Do this with a soft toothbrush, it will not damage the screen.
If that doesnt work then in all likelihood the screen is broken, it can be replaced but this is not trivial. There are guides on the internet on how do do this.
Dec 30, 2007 | Nintendo DS Console
Touch screen problems
Hi penny_od.....The following excerpts has been extracted from the Nintendo Help Site. If you would like to view the entire document, please click on the URL below....Please update your post of any progress, whether positive or negative so that I may learn from this too.....good luck my friend. http://www.nintendo.com/consumer/systems/ds/trouble_screen.jsp#touch ============================================= Touch Screen doesn't respond or is inaccurate when touched * Be sure that you're using only the bottom screen of the Nintendo DS with the stylus. The upper screen is not a touch screen. * Use only licensed Nintendo DS styluses and screen protectors. * Unlicensed screen protectors can lower the sensitivity of the touch screen. If the problem you are experiencing started happening after you attached a screen protector, you may want to remove it. Please note that some screen protectors can leave behind a residue that may be difficult to clean. If you are planning on removing a screen protector that has been placed on your Nintendo DS, click here for tips on cleaning your screens. * If the touch screen is not responding when touched, or the accuracy of the screen is off, you may need to recalibrate the touch screen. Click here for help recalibrating the Touch Screen. * If recalibrating the screen didn't solve the problem (see above step), hold the Nintendo DS at an angle so that you can see where the edges of the Touch Screen meet the housing of the system. Look around the entire edge of the Touch Screen for any foreign material (such as crumbs, etc.) that may be wedged in between the Touch Screen and the housing of the DS. Foreign material in this area can cause the Touch Screen to work incorrectly. If there are any visible particles, please follow these steps for cleaning the screen. If the above steps do not solve the problem, your system will need to be repaired. Click here for repair information.
Jul 20, 2007 | Nintendo DS Console
Nintendo DS Console Logo
153 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
