FixYa.com
Tags:
Washing Machines
Generic problem for all Washing Machines
MOLD IN WASHER (by 3 users)
posted by dwekace1969 on Jan 07, 2008
FRONT LOAD WASHER GALLERY SERIES.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by ksethney, posted on Mar 29, 2008
Lots of black mold visible in door gasket. There's probably a lot more out of sight. Maytag basically blows us off, because we bought out machine after the date included in the big lawsuit settlement... early 2005. They won't even talk about a possible solution. Sounds like they are simply willing to let customers go away rather than work with them to solve the problem.
Comment by Guest, posted on Jan 07, 2008
I've
Solution #1
posted on Jul 23, 2008
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I have never closed my washer door between washings and my towels smell moldy, t shirts are starting to smell also
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
BostonDave
Rank:Guru Guru
Rating: 88%, 88 votes
This is a typical problem with most front load washers and is due to moisture inside the washer being unable to dry out because of the air tight rubber gasket. The only consistent soultion I've seen for this problem is to leave the washer door ajar in between washes which will allow the moisture to air-dry as the conditions for mould growth are thus prevented.
This Problem Also Relates To: GE WJSR2070B Top Load Washer Bosch Classixx WFC 2465 Front Load Washer Electrolux EW1000i Front Load Washer Kenmore 3.8 cu. ft. HE4t King Size Capacity Plus Front Load Washer Kenmore 22622 Top Load Washer Kenmore 22642 Top Load Washer Kenmore 22062 / 22064 / 22066 Top Load Washer
Can you Help with these Washing Machines problems?
Washing Machines
fluff left inside the door...
After a dying cycle a lot of... Answer This...
Washing Machines
Washing machine Hoover AM120...
whatever program I use, machine... Answer This...
Washing Machines
Zanussi Progress 1200 isn't...
Zanussi Progress 1200 isn't... Answer This...
Washing Machines
PROBLEM FOR LG MOD.WD-10150FB...
problem for lg mod.wd-10150fb... Answer This...
Washing Machines
no drive between motor and
no drive between motor and... Answer This...
Repair Service
Find Washing Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
