Question about Sharp AR-5316 Advanced Digital Imager Copier
Sharp ar-5316 how do u reset/restart the memory of the copier,what are the codes needed to restart/reset the counters(total output and total copy counter) to 0 thanks for the assistant and answers to all my problems,they were really helpful Ibidun.
  • Anonymous Feb 09, 2008
    i m faceing one problem on sharp AR 5316 digital copier
  • Anonymous May 09, 2009
    i want to reset total copy countar if know any one i will pay for it
  • 62 Answers
Hi, from memory, the secret test commands are: # I CA #, then 81 to reset main copy count.
Cheers
Andy
Posted on Jan 08, 2008
6ya staff
SOURCE:
How to reset Toshiba Studio 256se Total Counter?
Clearing counter
The counter indicating "current number of prints and driving time" used for the PM display function is
reset by entering "0" in it or clearing it in the PM support mode.
Notes:
Even if "0" is entered in the PM management setting value of the setting mode (08), the
corresponding counter for the PM display is not reset. Be sure to clear the counter in the PM
support mode when the maintenance is finished.
The reset condition of each counter is as follows:
• 08-6194: Current value of PM counter [process unit (K)]
• 08-6195: Current value of PM time counter [process unit (K)]
When the current value of "CLEANER/DRUM" on the main screen or "DRUM" on the sub-screen in
the PM support mode is cleared, the counter is reset.
• 08-5568: Current value of PM time counter [developer material (K)]
• 08-5569: Current value of PM time counter [developer material (K)]
When the current value of "DEVELOPER" on the main screen or "DEVELOPER" on the sub-screen
in the PM support mode is cleared, the counter is reset.
• 08-5576: Current value of PM counter [parts other than the PM parts of the process unit]
• 08-5577: Current value of PM time counter [parts other than the PM parts of the process unit]
• 08-6225: Number of output pages (Thick paper 1)
• 08-6226: Number of output pages (Thick paper 2)
• 08-6227: Number of output pages (Thick paper 3)
• 08-6228: Number of output pages (OHP film)
• 08-6244: Counter for tab paper
• 08-6247: Counter for envelope
When the current value of "FUSER" on the main screen or "FUSER ROLLER" on the sub screen in
Notes:
The following counters are cleared by executing the EPU replacement mode.
08-5568: Current value of PM counter [developer material (K)]
Jun 14, 2016 | Toshiba Office Equipment & Supplies
I REPAIR THE MACHINES IN AFRICA SO I NI THE ERROR RESET CODES
Perform the following procedure to enter the simulation mode.
"#" key Interrupt key "C" key Interrupt key
Main code Start key Sub code Start key
Usual "reset" codes:
14 - Trouble cancel (except for U2)
16 - U2 trouble cancel
20 - 01 Maintenance counter clear
24 -01 Jam total counter clear
02 Trouble memory clear
04 SPF counter clear
06 Paper feed counter clear
07 Drum counter clear
08 Copy counter clear
09 Printer counter clear
13 Scanner counter clear
14 SPF jam total counter clear
42 01 Developing counter clear
There are codes and subcodes.
example if yiu want to clear the maintenance counter , you have to enter simulation mode and then enter 20 / Copy key /01 /copy key.
I hope it helps you.
regards,
Adi
Nov 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
Need to reset the drum counter on the AL 1740 sharp while changing to a used drum
Entering in the simulation mode:press Clear - Interrupt - 0 - Interrupt -Main code - Start -Subcode - Start.
When the clear all key is pressed the simulation mode is cancelled.When the interrupt key is pressed,the proces is interrupted and the screen returns to the subcode entering display.After cancelling the simulation mode be sure to turn OFF/ON the power and check the operation.
Main code 20 subcode 1 =Maintenance counter clear.
Main code 21 subcode 1 =Maintenance cycle settimg
subcode 2 =Mini maintenance cycle setting.
Maincode 22 subcode 1 = Maintenance counter display
subcode 2=Maintenance preset value display
subcode 3=Jam memory display
subcode4=Total jam counter display
subcode 5=Total counter display
subcode 6=Developing counter display
subcode 7=Developing preset counter value display
subcode 9=Paper feed counter display
subcode 12=Drum counter display
Maincode 24 subcode 1 =Jam counter clear
subcode 2=Trouble memory clear
subcode 7=Drum counter clear
subcode 8=Copy counter clear
Maincode 26 subcode 22=Language setting
Maincode 42 subcode 1=Developing counter clear
Maincode 43 subcode 1=Fusing temperature setting
Maincode 46 subcode 1=Copy density level adjustment
subcode 19 AE mode picture quality change
Nov 20, 2009 | Sharp AL-1641CS Laser Digital Copier
Toshiba e-studio 230 call for service
Call a Service tech
Have him reset yor Counter AFTER he over checks your copier and inspects the Drum,.Transer Unit, and Fuser Unit chances are the previous tech may not have reset the counter
but call for Service to verify those parts are good first ok. I would not want a counter reset to occur if a fuser unit is bad or something. At that low copies it maybe time for corona's to be replaced.
http://www.copierspluswwllc.com
Sep 08, 2009 | Toshiba Office Equipment & Supplies
MY CANON PHOTOCOPIER SHOW EO30
E030 (The total copy counter fails to operate.)
1)Turn OFF the power, and remove
J104B from the DC controller
PCB. Set the tester range to
x1KW, and measure the
resistance between J104B-2 and
J104B-1. Is it about 500W? NO
Check the wiring from
the DC controller PCB to
the total copy counter; if
normal, replace the total
copy counter.
2)Connect J104B to the DC
controller PCB, and turn ON the
power. Set the tester range to 30
VDC. Does the voltage between
104B-2 (+) and J104A-6 (–) on the
DC controller change from about
24 to about 0 and then to about
24 V when the Copy Start key is
pressed? YES =replace the totalcopy counter.
NO =Replace the DCcontroller PCB
Apr 03, 2009 | Canon NP 6035 Copier
I have a wrench code on my EStudio28 & machine went down-for days it has said periodic maintenance, can this be reset
Periodic Maintenance will appear if the PM counter setting is reach.
Normally, it wouldn't affect your machine, just that the message will shown at panel.
U can enter setting mode 08-252 to, set "0" to clear the counter, or 08-251, set "0" to disable the PM counter.
If your machine having problem, totally cannot run, u can enter 08-253 to display the last 8 error codes.
Mar 11, 2009 | Toshiba e-STUDIO 282 Black and White...
Afficio 250 SC900...copier will not operate
Is the SC just 900 or is it SC900-01? If it is 900 then it is a total counter error stating that the machine exceeded 9,999,999 copies. If the machine does not have this many copies then the NVRAM is defective. If the SC is 900-01 then the total counter is not working properly. Causes could be .... the mechanical total counter defective, mechanical total counter disconnected, or a poor connection at the total counter. Hope that it is the latter of the 2 codes.
Jan 03, 2009 | Office Equipment & Supplies
Imaging unit warning led
First enter into tech mode by pressing clear stop/exposure contol«/clear stop/exposure control» . Select the service mode function using the copy quantity and the zoom key and then press the start key.(The functions are shown in the order of d,c,A,and F.)
Now code c2 is(0) change to(1) press start.
Also to reset the counters, go code c6 and change it from (0) to (5) and all counters will be reset as soon as the machine is switched off and then on again.
good luck.
Oct 21, 2008 | Minolta EP1030/1030F CS/PRO Copier
Thoshiba E studio giving the Total Counter 220320 number and display call for service. You are requested to advise.
The machine needs a PM which is a preventive maintenance overhaul. Contact a technician in your area or restart the machine holding down the 0 and 8 key and input code 252 and hit 0 and enter, then power down and restart to reset PM counter.
However, I HIGHLY RECOMMEND that you get a full PM done if you want to avoid future copy quality problems and parts ware-down.
Nov 16, 2007 | Toshiba e-Studio 350 Copier
Sharp AR-5316 Advanced Digital Imager Copier Logo
823 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
