Question about Hitachi 43UWX10B 43" Rear Projection Television
CONVERGANCE REPAIR KIT FOR HIT 43FDX01B
ANYONE KNOW THE PART NUMBER FOR KIT WITH 2 IC'S AND RESISTORS. THANKS
  • Hitachi Master
  • 3,459 Answers
Yes - But Ddent will not provide any instructions or support with your repair. If you need that goto sites such as www.TVRepairKits.com instead.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
e87380c.jpgcONVERGANCE REPAIR KIT FOR  HIT 43FDX01B - 69189a5.pngmi
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
Posted on Apr 19, 2011
    Problem Solver:
In this repair kit, which RK##'s are they supplying you to replace? they list the ohms but not which ones they expect you to replace. (there are 13 total on the board..)
Posted on May 28, 2008
It is the stk 392-110 ic chips. You need to repalce both of them along with a resistor. I believe it is the RK 54 1/2 watt-1-ohm.
Posted on Jan 14, 2008
    President:
  • 4,402 Answers
Bdent carries kits for this tv
http://www.bdent.com/kits/repair_kits.jsp
Posted on Jan 07, 2008
6ya staff
SOURCE:
Screen looks like 3-d how do you fix problem?
Ur tv have a problem call convergence problems.The tv convergence board,require changing 2 STK convergencve ICS and some or all it resistors to solved the convergence problems.U know how to solders?Have soldering tools and solders?Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
May 28, 2010 | Hitachi 43FDX01B TV
Hitachi Model# 43FDX01B is doing a double image.
You have a convergence problem, you will need to change the convergence IC's STK392-110, there is also 12 6.8 1w resistors that need to be changed, there is also 2 fusilbe resistors that may be open. You can probably Google the IC's as a kit and find them all in one kit.
You can fix this yourself and save about $300-$400 in repair bills.
Feb 23, 2010 | Hitachi 43FDX01B TV
There are green and red waves on the top and bottom of my screen and the shapes in the picture are distorted. This is on a Hitachi 43FDX01B
Ur convergence it dead.U know how to solders?Buy a convergence kit at Tv repair World.com,Tvrepairkits.com.Replaced 2 convergence ICS,and all it resistors.Shop will cost u $300 for parts and labors.
Jan 27, 2010 | Hitachi 43FDX01B TV
Convergence issue; red 3D effect. In grid convergence mode blue will converge w/green fixed lines and red horizontal will but the verticle red will not adjust far enough left to converge. has ajustment...
Convergence is dead.Must know how to solders?Must replaced ICS and all of it resistors.Tries Tv repair World.com,Tvrepairkits.com for a convergence kit.The shop will cost u $300 for parts and labors.
Jan 24, 2010 | Hitachi 43FDX01B TV
I have a 43" ultrascan 43fd01b the horizontal red and blue are not in sync convergence dose not help
Must change convergence ICS and all it resistors.Must know how to solders?Tries Websites Tv repair World.com,Tv repairkits.com for the convergence kit.
Jan 17, 2010 | Hitachi 43FDX01B TV
Red and green waves...double vision ...how old...how valueble...hitachi 43FDX01B
Try adjusting the convergence. If it won't move see below- (or hitting Magic Focus for some Hitachi’s)
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 05, 2009 | Hitachi 43FDX01B TV
I Cannot get the red to center on the convergence adjustment.
This is a convergence output IC problem. convergence board would have to be removed -than remove and replace 2 STK IC's and check the surrounding resistors.
Sep 26, 2009 | Hitachi 43FDX01B TV
JVC AV-56WP74 Convergence part #'s
(2) STK392-110 Convergence Amp ICs
(3) 220 ohm 2watt metal film resistors
(3) 150 ohm 2watt metal film resistors
(2) 1.5 ohm 1watt metal resistors
(2) 2.2 ohm 1watt metal film resistors
(1) 1.8 ohm 1watt metal film resistor
(1) 3.3ohm 1watt metal film resistor
You can get the entire convergence repair kit which contains all the parts listed at the following link its called the AV48WP30 Convergence repair kit , but it applies to your model as well, and they include free installation instructions.
http://servicemanuals.vstore.ca/
Aug 18, 2008 | JVC AV-56WP74 56" Rear Projection...
Hitachi 43FDX01B (convergence) problem
Convergence IC's must be changed to start repair..original...
STK392-110 sub to Hitachi upgrade STK394-160E.....PART #
CZ 01341...you need two....
Next, take a critical look at the B+ feed resistors near the IC's..
check for over-heat / damage......usually 2.2 ohm 2 watt......
Let me know....................T.
Jan 03, 2008 | Hitachi 43FDX01B TV
Re: 43FDX01B blue convergence issues
Ditto CTF1800's comment....Check RP-41 1.5 ohm 2 watt and
other low value resistors near IC's mounted on large heatsinks.
STK392-110 original convergence IC's can be upgraded to
Hitachi # CZ 01341 new number STK394-160E for greater reliability.......Hitachi also has an IC / resistor kit # X480295,
but I don't change good resistors, only the bad one(s).
Practice good visual acuity technique and ask questions!.....T.
Jan 02, 2008 | Hitachi 43FDX01B TV
Hitachi 43UWX10B 43" Rear Projection Television Logo
290 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
