Question about Sony PFM-42B1 42 in. HD-Ready Plasma Television
Sony PFM-42B1E fault diagnosis
I know this query has cropped up before, but I would like a little clarification on the subject if anyone woulkd be kind enough to help :-)
I have a Sony PFM-42B1E and would like some insight into the diagnosis of the fault it is suffering with. This is what happens.....
"Pressing the ON button causes the unit to attempt to start up 4 times ( the fans come on, the screen flickers but nothing happens) and then it stops trying to start and the red standby LED flashes 6 times, after which this 6-flash sequence is repeated. Pressing the ON button turns the unit off and the standby LED stops flashing"
Does this "6 flash" sequence indicate that a particular board has failed ? If so which one would it be? The screen is good, as on the odd occassion it will fire up, but then goes off again.....onto the 6-flash red LED standby light.
Any help on this matter would be highly appreciated as would a source for a copy of the service manual for this model.
Thanking you all in anticipation,
Regards,
Roger
  • 1 more comment
  • Anonymous Jan 08, 2008
    Have exactly the same problem today. Would be very interested to find out what the problem is if you diagnose it. Four start ups with flashing red led. Then flashes red led in groups of six.
    Found this on another site...
    Reverts to st/by at sw on with 6 flashes from LED:
    over-current protection circuit (Q600, 602) is operating, usuallyprobs in LOP. To identify the cause, first dis FOP chip (IC501). If set switches on with frame collapse, replace IC501. If set fails to switch on, dis HT feed to LOPTx. This should give 4 flashes of st/by LED (no horizontal fly-back) showing that problem is in LOP. Check LOP comps before condemning LOPTx. If st/by LED continues to flash 6 times even with LOPTx disd, check R620 (270K) & R622 (470K) in over-current protection cct.
    I'll try working out what this means!
  • g1of4 Jun 20, 2008
    I've got the same problem too! Did you get a solution?
    Sony PFM-42B1, fuzz then 6 blinks.
The same problem what is the final solution for this?
Posted on Aug 27, 2008
  • NISMAS Aug 27, 2008
    i have the same problem what is the final solution for this? thanx
    my email [email protected]
    thanx
  • 20 Answers
Six flashes from standby light after 3 attempts to start up with a flash from the screen 100% means the PDP panel is duff - I AM A SONY ENGINEER AND THIS IS CORRECT.
Hi. i was wondering if anyone can help. My dad just recently got this Plasma and i noticed it doesnt have a HDMI slot. I read about it and research it, it does support HD but i was wondering if it supports the FULL HD 1080p. Also, can i play my PS3 using this plasma tv........mine is called the PFM 42B1E sony plasma.
Thanks 4 the help.
Posted on Feb 24, 2008
Hi, i need some info into this plasma. My dad just got it recently and i was wondering if this supports HD, i know that it does, but i was wondering if its the FULL HD 1080p. And i noticed that there is no HDMI slot, therefore, how do i play my PS3 in HD??
Thanks alot.....
please email me if u can help
[email protected]
I HAVE A SONY PFM-42B1. NO IMAGE, THE SCREEN DON'T TURN ON ,STANDBY LIGHT BLINKING CONTINUOUS. I SELL THE TV FOR PARTS , MAKE ME AN OFFER.
E-MAIL: [email protected]
Posted on Feb 22, 2008
I HAVE A SONY PFM-42B1. NO IMAGE, THE SCREEN DON'T TURN ON ,STANDBY LIGHT BINKING CONTINUOUS. I SELL THE TV FOR PARTS , MAKE ME AN OFFER.
I HAVE A SONY
I am the guest with the same problem that posted messages above. The TV needs a new Fujitsu plasma panel - see here http://www.eserviceinfo.com/download.php?fileid=33421 for the service manual. Looks like it'll be sold for parts on ebay!
Posted on Feb 09, 2008
  • 22 Answers
LOPT refers to CRT based TV, not plasma (unless the author is confusing it with the SUS or Drive circuit)
Posted on Jan 11, 2008
6ya staff
SOURCE:
I have a Sony PFM-42B1E, I switch it on and it powers up for a couple of seconds with a flash of snow on the screen then power light flashes 3 times, I opened it up and disconnected the ribbon power cable...
ok,..if originally u were having some image problems of a snow like flash on the screen,..then i would advice u to replace that DMD board,..the board u disconnected the ribbon power cable from.
Apr 02, 2010 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Scan lines missing
wow..that's most definitely a video drive error. 1. Check to see your settings are good still. It's not out of the realm of possibility that something glitched in the settings. 2. Missing information is a video drive issue, period. I'd suggest that you have a video board that's truly unhappy. Is this still under warranty? Hope so, since these service calls can run some serious dough.
Feb 11, 2008 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Tip
SONY PFM-42B1E FLASHING ERROR CODES
Ok i have here the problems that occur when the red standby led flashes on these sets which is an error code.
2 FLASHES ( PAUSE ) 2 FLASHES = X SUS TEMP (DD CON)
3 FLASHES ( PAUSE ) 3 FLASHES = Y SUS TEMP (I/O BLOCK)
4 FLASHES ( PAUSE ) 4 FLASHES = CENTRE TEMP
5 FLASHES ( PAUSE ) 5 FLASHES = DIGITAL 5VOLT
6 FLASHES ( PAUSE ) 6 FLASHES = PDP PANEL FAULTY
I hope that helps you cheers.
on Nov 11, 2007 | Sony PFM-42B1 42 in. HD-Ready Plasma...
SONY - PFM-500A2WE 16:9 42-inch Plasma fault 22-12
The error code tyo which you refer was truncated off of your posting. Could you please enter that code again? That code will assist us in determining the problem circuit.
Thanks,
Dan
Feb 09, 2009 | Sony PFM-500A2W 42 in. Television
Sony Tv PFM-42 V1 doesn't show any picture or tv menu
This is a common problem with plasma tvs You did not mention whether you could generate any sound like through your dvd player or something like that. Whether you have audio or not makes a difference on which board may be causing you the problem. Just because it does not have a picture for tv viewing does not mean it won't produce some type of sound through your av1 input. Try it and I'll try to be more specific.
Jan 06, 2009 | Sony PFM-42V1 42 in. HD-Ready Plasma...
I have a sony pfm-42b1 plasma tv with 2 vga inputs an 1svideo input.. i want to connect my ps3 hdmi cable to the vga input. i purchased the cable but nothing shows.. thanks for your help
you should change it from hdmi to cable. You can do it only on a hdmi tv when you do that you can use it for the pfm-42b1e because i had the same problem too. when you plug your ps3 to a hdmi tv you go to settings-display settings- video output settings than you change it to av multi. After you do that you can use it on pfm-42b1e
Dec 16, 2008 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Sony PFM-42B1E plazma screen
Does the red standby light flash ?? If so count the flashes and see my error code section.
Jul 05, 2008 | Sony PFM-42B1 42 in. HD-Ready Plasma...
PFM-42b1e LEd flashing 6 times... 1 sec. picture with green stripes... and then it turned to standby
I have a sony tv PFM-42B1 when I turn it on it go to standby an a red light flash I count count 14 time but I heard that it only support to flash 1 to 6 time how do count the flash
May 06, 2008 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Sony PFM-42B1 42 in. HD-Ready Plasma Television Logo
2,988 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
