Question about Nintendo DS Lite Console
Nintendo DS (F2 blown)
I blew F2 on BOTH of my son's units while trying to troubleshoot for an inop upper display on one unit.
I was in the process of changing the shells on both units because of broken hinges and thought I could find out if the problem with the inop upper display on one of the units was because of a bad display, ribbon cable or the main board. I guess I wasn't careful enough when I tried to connect the ribbon cable from the good unit into the the main board of the defective unit and then holding the battery in place while pressing the power button. I must have somehow allowed the metal case of the lower display to come in contact with the main PCB artwork.
I have ordered some new fuses from Mouser Electronics and hope there was no circuit damage caused by the short. I did check the resistance of F2 and found they were both open (yes, I tried to do the same test again with the other main board).
Since I can't continue to troubleshoot until the new fuses arrive and I replace them and test to see if the units power up when reassembled, do you feel it is more likely that the ribbon cable failed because of the broken hinge or do you think the problem is more likely the upper display is bad? I did notice that the upper display will sometimes flash a white screen before going black again when powered up with certain games installed.
  • 5 more comments
  • abdus107 Jan 08, 2008
    Hey i was wondering did i do the same thing?
    My bottom screen was broken so i decided to replace it. and when the new one came in i did just that and now it wont power on. the original screen had a black rubber on the back and the one i replaced it with did not... so is that the reason why my ds wont work anymore? because i let the metal touch the motherboard? if thats the case that means that i have blown a fuse? and if yes where can i by it and is it expensive and is it complicated to replace?
  • David Benson
    David Benson Jan 09, 2008
    abdus107,
    If you have a DVM or multimeter, check the resistance of F2, if it is open, you probably touched the LCD case to the main board and it is possible that replacing the fuse alone, will fix the problem. I read on websites when I was looking for information regarding the replacement of a broken shell (broken hinge), that you really must be careful not to short the main board out with the lower LCD touchscreen case.
    I bought 10 fuses (Littelfuse 0.5A surface mount in a 0603 package) from Mouser Electronics. I posted in another thread here the link to them, or I could send you one if they work for me and charge you $5 for the part and shipping (Paypal). Let me know by posting here.
  • David Benson
    David Benson Jan 18, 2008
    I have received my fuses and replacing F2 on both units fixed them. I also swapped just the upper displays and found out that the display isn't the problem. I will try to replace the main boards next and if the upper display still works in the good unit, then I will assume the ribbon cable was damaged from use with a broken hinge.
  • KidUncommon Apr 19, 2008
    I also had a broken hinge, and i got a new shell. When I put it back together, the bottom screen turned on and works but the top screen "turns on" but remains black.
    I ordered a new display unit, but I then saw this. Do you think, with my circumstances, that my old display unit is broken or the fuses are blown?
  • tuabiht May 16, 2008
    >I bought 10 fuses (Littelfuse 0.5A surface mount in a 0603 >package)
    I also need to replace the fuse of my DS lite. Can you give the exact reference of the Littlefuse 0.5- when I make a search (for example on Farnell), I get different types of fuse which are all from Littlefuse, with 0.5 limit.
    NB : I am no electronic expert, so sorry if my question sounds stupid
  • David Benson
    David Benson Jun 24, 2008
    Sorry about the amperage error... I got the info regarding 0.5 A from another website while I was googling for a solution. I can tell you thay my son's Nintendo worked fine with 0.5A fuses, but a 1A fuse certainly will prevent a simple surge in power from blowing the fuse,but also allows for an additional half amp of current to flow in a shorted circuit before blowing, which could allow for a component to fail, rather than just a fuse.
    My son's upper display problem wound up to be the ribbon cable. I found one of the traces on it was open and a new one restored the upper screen operation.
  • Anonymous Dec 17, 2008
    dddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddlllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddxxdddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddssssssssssssssssssdsdsddsdssdssddsdsdsddsdsdsdsdssdsddsdsdsddsdsdssdsdsdsdsdsdsdsdsdsdssdsddsdsdsdsdsdsdsdsdsdsdsdsdsdsdsdsdsdsdsdsdsdsdsdsdsdsddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddsssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiillllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllhhhhhhhhhhhhhhhhhhhhhhhhhhhh
STOP!!!!!!!!!! Read This first!!!!!!!!!!!!
Do not buy 0.5Amp fuses.
please read the marking on the fuse before you order your part.
(Picture below: zoomed in snapshot of "F1" for a DS LITE
Notice the Letter "H" right there in the middle?)
The 0603 size is the appropriate size ... on that you are all correct.
IEC has standardized the markings on SMD fuses!!!!! They are as follows:
Amepere Marking
Rating
500mA F
750mA G
1A H
1.5A K
2A N
2.5A O
3A P
3.5A R
4A S
5A T
Cooper/Bussman, Littelfuse, Panasonic, Shurter, Vishay/Beyschlay have all standardized their markings on their SMD fuses (IEC compliant).
so if you order please make sure you get one from any of these manufacturers or that their SMD fuses are IEC compliant. Their markings will be the same for the rating of the SMD fuse you want to replace.
In summary, for a DS Lite with F1 and F2 with an "H" marking buy an
0603 size, 1amp, fast blow fuse
Lead free? or not? ... thats up to you.
Happy fixin :)
Posted on Jun 20, 2008
Thanks gauss for your precious informations, but there are some motherboards that has diferent F1/F2 fuses. They are labeled as "32".
Please, see the photo below:
Is there anyone that can confirm they work exactly like the "H" fuse ?
Thanks
Posted on Sep 17, 2008
    Sniper:
  • 64 Answers
If you're technical (can handle a soldering iron in a tight space) take a look at http://www.m3wiki.com/index.php/Nintendo_DS_Lite_:_Repair_a_broken_console_(blown_fuse). It'll tell you where the fuses are and which one is which but they don't tell you the values.
Posted on Jan 08, 2008
  • 3 Answers
Is the 32 Votage Rating on the fuse DC or AC?
Posted on Aug 04, 2012
Hi -- my sons DS had a 750mA Fuse for F2 -- it's symbol is two small squares touching on the corner. See this data sheet for confirmation: http://www.farnell.com/datasheets/48464.pdf They are about 80c each from Farnell...
Posted on Oct 20, 2009
Max1981... I am pretty certain the "32" on the fuse is the voltage rating. Although I agree the H on the fuse in Guass' unit is what se claims, my son's unit worked with the 0.5A fuses. Certainly a lower fuse value will not damage the Nintendo, it would just blow faster.
Posted on Sep 19, 2008
My son had not used his nintendo DS for some time but when he went to charge the battery, the light shined orange for a short while and then cut off.
I think its the fuse thats the problem. Try testing both the f1 and f2 fuses with a multimeter, chances are that one of the fuses have blown. Instead of replacing the fuses you can buy
a battery charger for the ds lite. search "Battery Charger for Nintendo dsl" on ebay It should
cost about $5.49
Feb 26, 2011 | Nintendo DS Lite Console
Ds not charging
the mainboard has 2 fuses nown as f1 &f2 it could be they have blown you can get them on ebay
Jul 26, 2009 | Nintendo DS Lite Console
Ds lite comes on for a sec when charger plugged in then it goes of unit does not come on or charge
Hi three things come to mind, you dropped it but usually they wont admit it (dont go mad they usually all break when you do) if it rattles the capacitor under the power switch just fell off (common you have to solder it back on) if not that you replaced the bottom screen and forgot to insulate the metal of the back of the screen against the circuit board and blew either the f1 or f2 fuses (Replace them if you did) last thing i wont go into if you havent pulled it apart if you have reply and i will tell you Good Luck
May 20, 2009 | Nintendo DS Lite - Onyx
My sons ds lite won't turn on - the screen flashes
hey there Mike to me it sounds like one of the ribbons inside became loose or there is a blown fuse in your unit both are fixable you can check the ribbons and also the fuse can be bridged as well if your unit is under warrenty please contact nintendo about this and get a RMA for the unit if it is not under warrenty then there is two solutions to this either get a repair tech to look at it "can be found in the fixya repair directory" or we can work it out together if you need to know the steps required to fix the unit.
Nov 28, 2008 | Nintendo DS Lite Console
DS Light Power Problem
sklind2,
You have a defective screen (probably the upper). Replace it with a new one or send it to Nintendo for repair.
Mr. Teacake,
Never...never..put a wet cartridge in the DS Lite. Even when it is left to dry. Water is funnest for avery electronic device. You made for almost 99% certain a short circuit and blown out the microfuse (F1 or F2) on the mainboard. It could be much worse but check F1 & F2 first. See Google for their locations
John
Nov 03, 2008 | Nintendo DS Lite Console
Nintendo DS lite
Baakie,
You turn de DS Lite on, the green light flashes and the unit turned of. Is that correct?
The DS Lite checks some things before he starts-up. One of these things are the screens. the DS sends a signal to it and expect an answer back. When this answer is not received, it shuts down.
The most common problem in these cases is the flatcable of the upper screen.
Question is, did you replaced the housing? If so, you might dammaged the flatcable of the upper screen. If not, the flatcable might be defective because of using the DS Lite a lot (open /close the unit).
So first check the flatcable of the upper screen (google and you will find manuals how to open the DS Lite but be carefull!!!!)
Second, on the mainboard are two fuses (F1 and F2) . Check these! One of them might be defective
Success
Jul 19, 2008 | Nintendo DS Lite Console
My ds lite its doesnt power up...
Bummer. Sorry to hear this. Your console is broken and needs to be repaired. Contact Nintendo and arrange to have it repaired (or replaced if under warranty.)
Dec 19, 2007 | Nintendo DS Lite Console
Orange light stays on...
sorry no but call nintendo at : 1-800-255-3700 mon-un am to 7:00pm ur welcome!
Dec 13, 2007 | Nintendo DS Console
DS Card Not Recognized
the card slot may be dusty, blow gently into it (making sure no spittle gets in) or get a clean cloth and wipe the outside of it. On no account must the slot get wet, or it will probably get damaged and will not work.
Dec 02, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
14,938 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
