Question about IBM ThinkPad T30 2366 Notebook
IBM T30 start up problems! need help
My IBM T30 will power up but nothing will show up on the screen, the hard drive clicks and hums upon power up, their are no weird noises that dont sound normal to me...i was able by luck to get on it yesterday but when i moved the laptop it froze i had to reboot but i haven't been able to get back on it since, if anyone has any ideas i can use to get on it so i can get the contents of my hard drive on to disk that would be great thanks!!
  • 2 more comments
  • pledgeMaster Jan 07, 2008
    nope didn't work thanks for the help anyways appreciate it! cheers
  • Rabbit1 Jan 11, 2008
    Read your posting, I have a T30 and yes when you move the memory card most of the time It starts up. How can you fix this?
  • Brushy Feb 02, 2008
    Have T30 that only recognises one Ram Slot.(Checked by switching Ram and Slots) Whats the cure please Harvester 3 .Hope its simple as am temporary in India and believe me the experts arn't too expert and need the laptop to work.
  • Anonymous Jun 18, 2008
    i droped my camra and it won't start back up again
Bro. my uncle has a software that can retrieve your lost files on your hardrive.. its 100mb i think.. try to search for that then burn it into cd. the software will boot into your p.c in a safe mode.. then u can get your contacts back .. hope it will helps :)
Posted on Aug 11, 2008
HI,
I had the same problem.Dry solder joints on the front memory slot.(One closest to the front edge of Laptop)
Was fixed by this little guy in Powys. [email protected]
The soldier repair job is is really clean and so good that under a glass you can't make out his work .
Updated to the latest bios and now running 1.512GB ram ,
Posted on Aug 10, 2008
I swear to god harvester3. if you were here right now i would make out with you. YOU FIXED MY LAPTOP!!
Posted on Jan 21, 2008
Hi, a have a thinkpad t30, and i had the ram problem, i had to hold it in with a match and it worked, though i would like to know how to correct this problem permenent. can you help
Posted on Jan 15, 2008
Thanks a lot harvester, I had the same problem and everbody tols be that the computer is dead. i did what you suggested and it worked!!!!
can you pls tell me what is the permanent solution.
Posted on Jan 12, 2008
    Scholar:
  • 181 Answers
It's the memory slots. Trust me, I've seen this many times.
Do this.
Take memory out. re-install only 1 piece of known good memory in the slot closest to the rear of the laptop. Now, press on the memory slot itself, as if to push it into the motherboard, while turning the system on. If that doesn't work, try the other slot. I promise, this is the trouble 95% of the time. IF it works get back to me and we'll discuss how to repair it so you won't have to keep pressure on the memory slot.
Good luck
Posted on Jan 07, 2008
  • Anonymous Jan 08, 2008
    Too bad you locked the rating. I can tell you beyond all doubt, the problem is memory slots, if you've provided all the facts.
    But, since it didn't work, want to sell it?
6ya staff
SOURCE:
IBM ThinkPad T30 2366 not start without battery
It is NOT Battery or Power Supply it is your laptop itself has gone faulty... You need to troubleshoot the Motherboard, hard Drive etc, to find the exact problem that will allow you laptop to start. A laptop, will go, with just the power supply, and NO battery, if it doesn't either Power Supply is faulty, regardless of lights, OR the laptop's motherboard or hard drive is faulty, you must isolate problem.
Feb 26, 2010 | IBM ThinkPad T30 2366 Notebook
It dose not runs the hd only power light
If the power light comes on and nothing else works, it could very well be a motherboard problem.
I would suspect this if the hard drive does not start, the fan does not start, and you get no display.
Dec 11, 2009 | IBM ThinkPad T30 2366 Notebook
IBM Thinkpad T30 wont boot up
You have faulty RAM modules. Reseat your RAM modules, to make sure they make proper connection. If this doesn't work take them to your friendly computer shop and ask them to test them for you.
Apr 29, 2009 | Lenovo ThinkPad R51
Ibm t30 laptop has no video at start up
Try doing a hard reboot.
Unplug AC and remove battery.
Press and hold POWER for 30 seconds.
Plug in AC.
Turn on.
Upon bootup insert battery.
If this does not work I regret to say the graphics card is busted.
Apr 26, 2009 | IBM Thinkpad T30 Notebook
PC will not reboot.
Either something has wiped out your operating system and you need to reformat the hard drive and reinstall it, or your hard drive went Since it worked fine the day before and just did this right away, my guess it that your hard drive went bad. But you can try both options though. Hope this helps.
Sep 13, 2008 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad T30 2367
I bet your hard drive crashed on you. You might have to buy yourself a new hard drive and replace your old one with it. Then format it and install a fresh copy of your Operating System on it. Your error condes here indicate to me that you either got a blue screen or similar. Blue Screens and/or the code that you stated here are usually caused by a software issue, and are rarely hardware issues. But in this case, you may have gotten something bad on your computer, such as a virus or serious spyware, that wiped out your Operating System And caused your hard drive to crash/become corrupt. As I mentioned, try replacing your hard drive. Hope this helps.
Sep 07, 2008 | IBM ThinkPad T30 2366 Notebook
Ibm t30
This is not good. It generally indicates that the security chip on the motherboard has malfunctioned. A hard drive failure can also cause this occasionally, but mostly it's the chip. Start by trying a new hard drive, if it works, GREAT, if not then the chip has malfunctioned and locked the system. Your only option is replacing the motherboard.
Jul 21, 2008 | IBM ThinkPad T30 2366 Notebook
IBM Thinkpad T30
Try starting without the battery, and cheking the memory chips.
Jul 04, 2008 | IBM ThinkPad T30 2366 Notebook
Trouble booting up! please help
This could be caused by one of several things. One is a loose memory card another is a bad hard drive. My suggestion is that if you can boot into Windows, that you offload whatever you can to removable media. Then, reseat the memory and unplug and replug in the hard drive. If that doesn't make the problem go away, replace hard drive and use the recovery software to reinstall Windows and your other programs.
Jan 07, 2008 | IBM ThinkPad T30 2366 Notebook
IBM T30 Start Up Problem
see website laptoprepair101.com, sev eral ways to test this problem
Mar 28, 2007 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad T30 2366 Notebook Logo
303 people viewed this question
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
