Question about Jensen CD4610 CD Player
Car radio I installed a aftermarket radio in my 91 dakota. I didn't buy a wiring harness and wired it straight. One problem though. Had an extra orange wire that works the dash lights that was in the original wiring harness. What can I hook it to, to make my dash lights work? Tried hooking with the switch wire for the radio and it blew the fuse for my tail lights.
  • 3 Answers
That wire is an unused spare
Posted on Jun 08, 2009
1997dodge Dakota stereo install pioneerDEH-2300ub
Pretty straight forward, just get a wiring harness from ebay, amazon, best buy, autozone, or any stereo place. It's a 2 part harness, one is black and one is grey, just like the ones in your truck already. Connect the wires from the radio to the wires on the harnesses. Soldering is best, crimp on connectors or small wire nuts are good enough, or even just taped up if you are good at twisting wires in a way they won't come apart. Tape them up good. Then just snap the harnesses into place with their corresponding colored harness in the vehicle and you're ready to go. No need for an antenna adapter in these. And you will want a plastic mounting kit so it's not just sliding around in the void. Only 2 bolts/screws will be used to hold in this bracket the top right facing up and bottom left facing left. The plastic mounting kits are like 10-20 bucks. If you get a universal, just snap off all the extra tabs you don't need. It's self explanatory once you look at it and see how it goes into the truck. If you need more help let me know and I'll post some pictures. I have a 97 and a 99 sitting out in my yard.
Apr 05, 2017 | 1997 Dodge Dakota
Can i hook up a parakeet model number PWM 16 to my factory stereo in a 98 Ford Expedition
About 3,970 results (0.89 seconds) Search Results
    Ford Bluetooth® Wiring Harness - Crutchfield
    www.crutchfield.com/.../Ford-Bluetooth-Wiring-...
    Crutchfield Corporation
    Rating: 4.5 - ‎16 reviews - ‎$19.99 - ‎In stock
    Reinstall the factory radio and mount the Bluetooth kit, and you're ready to go. ... 16Reviews ... harness so that I could hook up an aftermarket amp to my factory radio.... works like it's suppose to. says it doesn't work on an 09 Escape but had no .... I purchased this harness to install a parrot ck3100 in my 07 Ford Edge.Missing: pwm
    70-5521 wiring harness for ford with 6 CD premium sub amp ...
    ? 4:30
    https://www.youtube.com/watch?v=0jqNafnki0o
    Aug 9, 2013 - Uploaded by codieraji
    Metra 70-5521 Radio Wiring Harness for Ford 03-Up Amp FordPremium stereo radio 6 CD changer with sub amp inputs. ...16:47. How to wire an aftermarket radio / I Demo install with metra harness and antenna ... How to hook up stock amp/sub to aftermarket head unit "ford sport trac" - Duration: 3:01. Pat.Missing: parakeet ‎pwm ‎98
    Car Stereo Wire Harnesses - Radio Wires for all Car Audio ...
    www.installer.com/main.php?page=harness
    Car Stereo Wire Harnesses - Car Stereo Installation Wiring - Stereo Harness ... If you
Feb 09, 2016 | Ford Cars & Trucks
05 grand what do i need to install a aftermarket radio
Get a wiring harness adapter kit (about $10) from a stereo shop. It has harness plugs that will plug directly into your harnesses in the dash, and has color-coded wires that you will color-match to the wires on the aftermarket deck's harness. You may need an antenna adapter as well. If your stock stereo face is taller than the aftermarket one, you'll need a dashboard adapter kit to take up the extra space.
Dec 10, 2009 | 2005 Pontiac Grand Am
What color is what when installing a car stereo in a 91 Grand Marquis?
you can go to your nearst car audio shop and buy a harness that will plug into your factory plug, which will allow you to wire directly into it with your aftermarket radio harness which is color coded to match. the reason i recommend this is b/c some of the marquis are factory amplified. although i have included some wiring info for your car, be sure to test all wires with a digital meter first.
Battery BLUE/YELLOW (+) RADIO HARNESS Accesory GRAY (+) RADIO HARNESS Ground BROWN (-) RADIO HARNESS Illumination GREEN (+) RADIO HARNESS Power Antenna BLACK/RED (+) RADIO HARNESS LF Speaker (+) PINK LF Speaker (-) VIOLET RF Speaker (+) LIGHT GREEN RF Speaker (-) BLUE LR Speaker (+) BLACK LR Speaker (-) YELLOW RR Speaker (+) RED RR Speaker (-) WHITE
Sep 15, 2009 | JVC AM FM CD DET FACE CAR STEREO
Broken wire in wire harness clip
i'm not sure what part is broken from your description but i will try to help...
you can purchase something called a reverse harness that looks identical to your vehicle's OEM harness that plugs into the factory radio. the only difference will be the wiring color on the new harness will be standard aftermarket wiring (ie 12volt yellow, ign red, ground black, etc.) and if you cut each wire from the OEM harness and solder it to the reverse harness location for location then the new harness will be good to go. i would personally do this as a single wire at a time so you are not staring at 16 cut wires going to the new harness. check at Best Buy and see if they carry the 71-1770 Metra wiring harness and that will be the one you need as the reverse harness and if you are installing an aftermarket radio get the 70-1770 also. if you aren't comfortable with all this your local installers should be able to do this job for you pretty reasonably.
Aug 18, 2009 | Pyle PLTDN71 Car Video Player
Installing newer radio in older truck
Hello zachary_reed,
What you need is an aftermarket wiring harness. These are made by Metra, Scosche, and others and are made to plug directly into the OEM radio harness. It appears that the one you want is the Scosche FB02B available from SonicElectronix. You simply connect the wires from your new receiver to the harness wires and then plug it into the factory radio plug. Another online retailer that sells aftermarket harnesses is www.crutchfield.com. Your local car audio shop or perhaps Best Buy may also have the wiring harness.
Be sure to match up the wires from your new radio harness to the aftermarket harness by FUNCTION, not by color. For example, most newer receivers will use Yellow as the 12V constant (hot) wire. The wiring color code for your F150 is shown here. Make sure that the pin on the aftermarket harness is connecting the yellow from your new receiver to the green/yellow of the OEM plug and so on.
Hope this helps.
Jun 09, 2009 | Pioneer DEH-1100 CD Player
Installing an aftermarket stereo, spliced the wires and have everything connected including the remote wire to the factory amp wire but still no sound.
There is no remote wire on these newer trucks....03 and up....u have to buy the harness....although i didnt....i have an 03 gmc sierra and just pulled the schematic and matched the wires. And there is no programming to do on an aftermarket stereo.....I work for GMC and we cant program aftermarket stereos......if u buy the right harness ...and its over $100 then everything should work just fine.....and this does not disarm ur alarm system either....mine still works fine....hope this helps
May 08, 2009 | 2003 GMC Sierra
New Radio Extra wires & No Power
the solid black wire goes to earth on the steel sub structure of the dash and if you plug the aeriel in and it should power up what sort of radio is this
Dec 29, 2008 | 2001 Dodge Dakota
will it power up at the moment blck wire is always an earth to dash what sort of stereo is this
Hi, I am installing a new head unit into my dads 98' Buick LeSabre and the factory harness has been cut and I'm not sure of the color code and not sure how to run the extras thru the new head unit and how...
Metra makes wire harnesses for your problem. If your wire harness is, 70-5555 the part that goes into the OEM radio will be 71-5555
Try www.metraonline.com and put in the car info. The harness will come with wire codes for splicing the new plug.
Dec 17, 2008 | Car Audio & Video
Jensen CD4610 CD Player Logo
304 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
