Question about Dell Latitude C640 Notebook
Dell C640 powers off when lcd is plugged in
My Dell C640 works fine when plugged into an external monitor, but only with the lcd ribbon cable unplugged from the motherboard. When the lcd is plugged in, the computer powers off within seconds of being turned on. I bought another lcd, inverter and ribbon cable, but the same thing still happens. The only other problem is a battery that will not hold a charge (I have ordered another one). I don't know if the battery issue may affect the lcd problem but I mentioned it anyway.
I have the same problem... if you remove the bios chip and then reseat it, it will work untill u leave it off for more then a day!
Posted on Jan 26, 2008
    Scholar:
  • 32 Answers
There is a possibility that the socket for the lcd ribbon has shorted somewhere, either the socket itself, or the tracks on the motherboard leading to the power supply circuit or video card. If this happens then there is no DIY fix, unless you have PCB cutting equipment or a micro trace pencil. If you are desperate, you can also look into replacing the LCD's power inverter chip. They only cost about $30-40 and may fix the issue if it is blown and trying to pull way too much current.
Posted on Jan 08, 2008
Laptop monitor bad color and flickers continuely, but when attached to external monitor, works fine
I'm going to take an educated guess here, because it sounds like the monitor's interface controller is bad. I forgot the name of the thing, but it's a small circuit board that's normally located at the bottom of the panel frame, between the flat ribbon cables and the round hinge cables.
"Inverter Board"
Mar 19, 2013 | Dell LATITUDE Computers & Internet
Problem with Dell 2100FP LCD monitor
Unplug monitor form AC outlet, wait for few minutes and plug again.
Check cable attache to PC.
Hope this trick will work.
Sep 30, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
XPS M1530 video issues
Check out the ribbon and other connectors that are powering/connected to your screen. It appears you may have an intermittent wiring situation.
Or the circuitry or keyboard switch that switches the video back and forth from screen to external output may be the culprit.
Mar 24, 2017 | Dell XPS M1530 Laptop
Dell laptop not detecting external display
Usually the external monitor and laptop screen toggles in one of three states.
LCD only
External monitor only
Both LCD and external monitor
Wait a couple of seconds between when you press Fn F8
This model laptop may not allow ectended display.
May 29, 2012 | Dell Latitude D830 Laptop Computer PC...
I have a B130 that has a monitor problem. When I start the computer the screen flashes but will not stay on. It works fine hooked to an external monitor. I replaced the inverter. I was not paying close...
If the display works fine on external monitor your video circuitry on the motherboard is fine. Since you replaced the inverter brd and you still have the same problem it has to be either the LCD display panel or the LCD I/O cable or the connector on the motherboard that the LCD I/O cable plugs into.
Jul 24, 2011 | Dell Inspiron B130 Notebook
Hp pavilion dv4 screen will not work. everything
Few trouble shoot solution when it comes to these HP Laptop from 08-09.
1). Remove battery and ram. Plug in AC Adapter and insert only ONE RAM into a slot. Boot up and see if this will turn on display (it work on a HP Dv4-1225dx) IF it works then shut down and re insert the two ram and should be good to go :)
2). If your tech savvy remove keyboard and gain access to LCD flex ribbon cable to check if cable is loose (or go on a limb and replace the lcd flex cable ). I would detach it and re attach the ribbon back to motherboard. ( This happen sometimes by chance)
3). Your LCD is shot dead so it will need to be replaced. Current used LCD can range from $40-$50 and new ones with warranty $60-$100. HP is set up for easy LCD removal so shouldn't take more then 30mins to replace, just be careful when handling the ribbon and inverter cables.
GOOD LUCK
(Fix many HP Laptop for friends and family)
Apr 04, 2010 | HP Computers & Internet
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Oct 05, 2009 | Acer AL1714 17" LCD Monitor
Dell Inspiron 1501
If the laptop keeps working, and you can use it on an external screen, then it is likely an hardware fault.
First perform a complete system recovery, like probably already instructed by the Dell support helpdesk. This will practically exclude the possibility of a driver or system problem.
If the problem is hardware , then you may have a faulty inverter board , a bad LCD display/LCD ribbon connection, or a faulty video adapter (integrated with motherboard).
If the problem is the inverter, then the screen will go dark, and the laptop will keep working on external display. This is probably your case.
If the problem is LCD display or ribbon cable, then the display will be blank with light on , and the laptop will keep working on external monitor.
Fault concerning video adapter usually cause the the system not to work at all, and it is uncommon under conditions described.
Sep 04, 2009 | Dell C3039 Inspiron 1100, 1150, 5100,...
Dell Laptop E1705 Screen goes Blank
If your video output works fine when connected to an external monitor, then the issue is with the LCD display panel. I’m afraid the only way to fix this is have the LCD panel replaced. The ribbon cable that plugs the LCD panel into the motherboard could also be the culprit. Here's a link to the display assembly for 1501: http://support.dell.com/support/edocs/systems/ins1501/en/sm_en/display.htm#wp1022270
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Jan 09, 2009 | Dell Inspiron 1501 Notebook
Dell Latitude C640 Notebook Logo
Alun Cox
