Question about Sony Grand WEGA KF60XBR800 60" Rear Projection Television
Double image lately the images have a black like shadow like. say when watching hockey the image always has a shadow following it . looks like i have double vision. can u help
  • 6 more comments
  • ainee1 Jan 07, 2008
    will paid for if the problem is fixed
  • ainee1 Jan 08, 2008
    tried all that but nothing work
    i have look around and they say there is some service manual that i look into.
  • Anonymous Jan 09, 2008
    My is almost the same the blue and red are off. Can you help me how to adjust the convergence or focus? Thanks, Chris
  • nautique89 Jan 15, 2008
    I have the same problem and have lived with it for a about a year. I've tried all of the revison adjustments with no luck. Sony service came out and wanted to replace some chip. He said the chip is cheap but the labor is not. $500.00. Can you help me?
  • jetsfan69 Jan 25, 2008
    Same problem here. Have the Sony KF60XBR800 and it started throwing a red ghost image on all video sources (cable tv, DVD, games, etc.). Tried the setup menu option to adjust the image but no notable fix. Called Sony an thier crack service department acertained pretty much out of the gate that the set needs to be reapired. Hopefully the extended warranty will cover this. Would be recepttive to any feedback from the forum on other alternatives for trying to fix this.
  • fbamfo Jan 27, 2008
    I have the same ghosting problem described on this borad. I started experiencing this problem about a year ago and it appears to be getting worse. I've tried the image revision adjustment off the menu and no luck.
    Is there a fix for this problem? I am OK if it needs to be serviced but want to no if that is the fix. Assumimg there isn't anything one can do with the set.
    Please contact me if anyone has a solution,
    Thanks
    email: fredbamfo2yahoo.com
  • LeeJr Mar 26, 2008
    I have had the same ghosting problem for over a year now. It is slowly getting worse. Is there a solution. Is it expensive?
Jehill,
Would appeciate the procedure for ghosting on my Wega.
Thank you
Joe
Posted on Feb 29, 2008
Jehill,
Please email me the procedure for ghosting.
Thanks,
rr@suddenlinkmail.com
Posted on Feb 04, 2008
    President:
  • 4,402 Answers
Have you done convergence? and is there a auto focus?
Posted on Jan 07, 2008
  • 3 more comments
  • Cary Farah
    Cary Farah Jan 08, 2008
    Do you see the double images with the OSD? Did you try each of the
    manual Image Revision settings? the following TIP is available that
    takes you into the service menu to make adjustments that may correct
    the problem without the need to replace the optical assembly:
    Document Reference/Event ID: E20256050
    Model: KF50XBR800, KF60DX100, KF60XBR800
    Subject: Image Revision adjustment for Double Image. Ghosting.
    SYMPTOMS
    Double
    image. Ghosting. I have tried E19763341 (service bulletin that tells
    you to try the manual adjustments) but the double image still exists.
    Is there something else to try rather than swapping the Optical Block?
    RESOLUTION
    Yes. Try the attached procedure. This has proven to be very effective.
    The procedure is lengthy and complex enough that I can't include it here. However, if you want it, go to your Inbox
    at the bottom of the left column and send me (jehill) a private message
    with your request and your e-mail address and I will send it to you. YOU ARE COMPLETLEY ON YOUR OWN IF YOU ATTEMPT THE PROCEDURE!
  • Cary Farah
    Cary Farah Jan 10, 2008
    Send me your email address i have a fix 4 u
  • Wbacik Apr 27, 2011
    Can someone help we with fixing the ghosting on my 60" Wega? Is there a service bulletin and another fix? pls reply to
    Wbacik@Rogers.com
  • Cary Farah
    Cary Farah Apr 27, 2011
    check this link out http://www.agoraquest.com/viewtopic.php?...
  • Cary Farah
    go here:
Shadows/ ghost images...
i'm also had the same problem and don't know how to solve it. anyone can help?
Apr 03, 2012 | Wacom Cintiq 21UX
Blue tint across screen and black shadow of sort
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Apr 02, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
There is a double or ghosted image now while watching the TV. It seems to be shifted to the left, almost like a shadow. Is there an adjustment that can be made?
Look on Menu for convergence adjust thier first if this does not help you may need to replace convergence ICs they are Big Black ICs will have part number on them STK-392-110 example. for Pats call Mats 1-800-628-1118
Nov 12, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Red shadow to left of main image InFocus LP750
You have to open the LP750 and check the alignment of your color lenses. You might be needed to adjust, also check your lamp too.
Jul 23, 2009 | InFocus LP 750 Multimedia Projector
Shadows and text curved. Double images
The convergence IC's need to be replaced. The generic part # on them is STK392-110. This is not easily done by yourself.
Apr 09, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Blue shadows on my philips projection tv
You have possibly contaminated fluid in your blue picture tube if it has a hazy look.Blacks and whites look bluish and whites have a blue bloom to them.The other problem could be bad convergence amps.This would be double image around letters on the screen.
Jan 13, 2009 | Philips Magnavox 51MP392H Rear Projection...
Picture is distorded.it shows a shadow of the image in different
Hi,It sounds like the convergence is out on your tv if it has been moved recently this can cause this problem but it really needs a technician to examine it.
SUPER8
Jan 02, 2009 | Philips Magnavox 51MP392H Rear Projection...
Double Images / Shadows on the monitor screen
Hi..there,
Have you guys...try to open your OSD on your monitor and blanced the colors or adjust the WB (white blanced) settings....
Jun 30, 2008 | Gateway FPD2275W LCD Monitor
Panasonic PT-51HX41 rear projection tv showing shadow/double images.
Unplug the TV from the ac wall outlet for about 4 minutes then plug it back in and turn it on. If it still has a double image then tell me if it's affecting the menu screen from the TV (not the cable menu). And is the double image in red and blue?
C-Dog
Feb 18, 2008 | Sony KP-41T65 41" Rear Projection...
Picture shadow on rear projection Sony big screen TV
OUR TOSHIBA HAS A DOUBLE VISION/BLURRIE PICTURE. THIS PROBLEM IS ALWAYS THERE. SOMETIMES THE PICTURE IS GREAT, BUT MOST OF THE TIME ITS BLURRIE/DOUBLE. LOOKS AS IF IT ALWAYS ON 3D!! ANY SUGGESTIONS? WE WOULD REALLY APPRECIATE ANY HELP WE CAN GET FROM ANYONE. THANK YOU!
Mar 03, 2007 | Toshiba 55H70 55" Rear Projection...
Sony Grand WEGA KF60XBR800 60" Rear Projection Television Logo
802 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
