Question about Microtek SCANMAKER I900 Flatbed Scanner
Calibrating Scanner I'm trying to calibrate the scanner and when it brings me to the page where I save the profile, it gives me an error message saying "Profiling process has failed! Input characterization library error."  What do I need to do? Thanks
  • Anonymous Feb 11, 2008
    same problem. running 10.4.11. connected via firewire.
I had the same problem but have solved it. What i think you might be doing wrong, is that you have the scan material the wrong way round. The womens face should be on the right side of the scanner with the colour input target centered against the ruler. Once i did this it worked first time
Posted on Jun 12, 2008
Brookstone iconvert not saving getting errors
On iPad goto Settings -> Privacy-> Photos
Turn on iConvert Scanner
Dec 30, 2012 | Brookstone Scanners: iConvert Photo...
Model mfx 1950 "calibrating scanner"
Refer to your "users guide" that came ith the machine... in particular refer to pages 1-14 thro 1-17 of the guide and ensure you have the date and time set correctly.
On page 1-17 you will see reference to "energy save interval" and sleep periods for the lamp. If you do not have these programmed correctly you will experience the condition you are describing.
This is a relatively new model...if you have already lost the manual you can download it from Muratec's Web site www.muratec.com.
Apr 09, 2010 | Muratec Copier
My 3330 says scanner bulb is warming up then it gives me a error 79 message no ,matter how many times i restart it
The error 79 on that machine means that the scanner assembly has failed to align/calibrate. Could be due to a bad calibration strip on the scanner glass, have you ever sprayed glass cleaner directly onto the scanner glass? If so this can stain the calibration strip and render the scanner useless. It is probably best to have the machine serviced by HP.
Feb 05, 2010 | HP LaserJet 3330 All-In-One Printer
HP 4600 printer with error message 51.2M and loud noise when calibrating. Any solution?
Replace your magenta cartridge first. If the problem persist I strongly recommend a service tech. Error 51.2M is an magenta scanner(laser) error or DC controller.
May 08, 2009 | HP LaserJet 4600 Printer
Start up problem with printer
Your scanner glass is get dirty and all scanners make a self diagnostic program when we turn on the printers.
At this point, you will hear a little noise from the scanner carriage lamp, witch is doing self calibrating. In this calibrating time the scanner unit "read" the white and the black levels, and the white (in your case) is not white, is quite gray because is dirty.
The solution is a very simple, but require much skill.
You must disassembly the scanner unit, remove any screw you see (you need an no. 2 phillips screwdriver) and very gently remove the upper side (with glass) from the rest of scanner unit. Please note that is several plastic fasteners to be disposed.
after you remove the glass (with a plastic frame) you get a small tissue of cotton and soaking with an windows cleaner solutions. Gently clean the BOTH surfaces of scanner glass.
For assembly follow the reverse procedure.
Beware to the glass, it has only 3 mm thickness. Don't broke!
Like I sad: simple problem, but require much skill. If you think is to difficult for you, please go to the service.
Sep 21, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Microtek ScanMaker 8700 - 'kdsinput internal error'.
try this:
http://support.microtek.com/knowledgebase_1/kbdtl.php?request=KB-00007EP&vw=1
Aug 04, 2008 | Microtek SCANMAKER I900 Flatbed Scanner
Msg
I'm not that familiar with your model, however, the ##324 error is a scanner failure. On some of the Canon models, there is a provision in the menu for re-calibrating the scanner. You try this but I can't guarantee it will fix your problem. If I'm thinking right, your model corresponds to the Hp LaserJet 3100 series (but then again, why should I start thinking right now?). They where notorious for that problem. You'll need a blank sheet of white paper, look through the menu to find "calibrate scanner". I'm still trying to find more information on this, but I don't have it yet Hope it helps Ed
Jun 10, 2007 | Canon CFX-L4000 Plain Paper Laser Fax
Microtek SCANMAKER I900 Flatbed Scanner Logo
705 people viewed this question
Top Microtek Office Equipment & Supplies Experts
Alun Cox
Tony
Are you a Microtek Office Equipment and Supply Expert? Answer questions, earn points and help others
