Question about Samsung V25 CXTD 2000 Notebook
Samsung V25 Laptop When it is powered up nothing is showing on the screen although the power light is on and you can hear a noise. This has happened before and it just came on.
  • jcking82 Mar 31, 2008
    se perdieron los contrladores de sonido
Whilst trying to update memory i found that if the memory didnt make a good connection the screen didnt show anything (as though it couldnt boot properly)
Posted on Mar 28, 2008
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
The screen's connector has worked itself loose from the motherboard. disconnect keyboard, remove screws holing the long blue plastic section just above keyboard; on the left you'll see screen connector, just push it firmly home.
Posted on Mar 27, 2008
  • ameeman Mar 27, 2008
    the screen's connector has worked itself loose from the motherboard. disconnect keyboard, remove screws holing the long blue plastic strip just above keyboard; on the left you'll see screen connector, just push it firmly home.
One way to make sure the system is still working, remove the Batery, then plug the power adapter only and turn the computer back on, normally if the laptop goes into Hybernation mode and the battery is low on power this can happen. If that fixes the system then you can do a safe shutdown and re-install the battery and turn your laptop on and it should come on, the fact that you mentioned this has happened before makes me believe it is Hybernation issue. Good Luck.
Posted on Jan 08, 2008
Problem with Samsung R530 laptop screen.
Laptops do not fair well if liquid was spilt, and it does not take much. Remove main battery and turn on, if okay! battery needs to be replaced, next remove ram one at a time and power up making sure you always have one in the laptop, last! hook a spare monitor to the video output usually on the back, if okay! the LCD on the laptop has a bad inverter board, or defective backlight behind the LCD. Now if both show the same symptom it is the Video Graphics Card usually built into the motherboard.
Mar 19, 2012 | Samsung R530 Notebook
Nothing comes on picture blank
A few things to try
1.) Check the laptop on an external monitor, do you get a picture
2.) Is there power to the laptop from the battery and the charger? Try to see if the charger indicator lamp is blinking green rather than steady green
3.) Can you hear hard drive / fan noises and are there any lights on the laptop?
If the charger is blinking, indicates that power is not making the circuit, check tightness of charging port, if tight, assume fault on motherboard / blown main fuse
If picture on external monitor and not on laptop, assume backlight on screen dead or possibly the inverter
If no noises from HDD or Fan and No lights on laptop, then fault with motherboard
If you do get fan noises etc, but get BLINKING lights on laptop, assume possible fault with graphics chip, repost with details of blinking lights / colour and specific model of laptop
Jan 12, 2011 | Samsung Computers & Internet
My laptop did not start it only show black screen
that happened to my mates laptop he had to go and get it repaired so goodluck:) please rate this solution...
Jun 06, 2010 | Samsung V25 XVC 2800 Notebook
Need to know how to wire the power socket at back of v25
Have you determined the problem correctly?
The fault maybe the power adapter or the power plug that connects into the laptop's power socket rather than the power socket on the laptop.
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. The power socket is soldered directly onto the motherboard, there is no wiring required.
If you cannot DIY then I suggest you get a quote first.
Dec 02, 2009 | Samsung V25 XVC 2800 Notebook
Have a samsung v25 had a problem with power outlet .had it in bits cured that problem but now the screen lights up but nothing shows . can hear it starting up etc
check with external monitor whether there is display or not. if there is display in your external monitor check lcd or lcd cable.
Nov 20, 2009 | Computers & Internet
Laptop screen too dark when used with battery
Are you using vista or xp?..The laptops to conserve power will dim the screen , you can , however, change it to brighter by pressing the "fn" key which stands for "functions"key. while pressing that, you should have another set of keys either to your right or obove your left finfers with the symbol fo a sun with arrows pointing up and the fn and tap the up arrow key to increase the brightness.
Let me know if that works
Apr 10, 2009 | Samsung V25 XVC 2800 Notebook
Dell monitor blank. nothing appears on screen. light is blinking by minitor power button, but nothing at all on screen. I hooked up to my laptop, still nothing. Checked power/ tried new power cable. No...
Make sure you set up your laptop to display to a second screen. Depending on your Operating system, go to your display properties and go to the settings tab. Then click on the second monitor and enable it.
Apr 08, 2009 | Dell E773C 17" CRT Monitor
Blank screen
Might be the VGA connector to the motherboard.
Turn upside-down. Remove screw in the centre marked KBD.
There are 4 screws running along the back. Remove the 2 inner ones.
Lever up the keypad with a small screwdriver - Careful not to disconnect the ribbon underneath.
Undo the 3 screws along the strip above the keyboard and remove the strip.
VGA connector is next to the power button. Check it is pushed down firmly.
Dec 03, 2008 | Samsung V25 XVC 2800 Notebook
Samsung v25
Try to diagnose the problem first...
1. Turn it On your Laptop
2. If you have CRT Monitor? connect it to your Laptop if they have screen appears.
3. If they have display your LCD have a problem.
Aug 09, 2008 | Samsung V25 XVC 2800 Notebook
Samsung V25 fan replacement
It may not be the fan, I have a V25 and it was the motherboard, it wouldnt power the fans anymore when the CPU required it so would crash lots.
If the fans twitch or run for a second or two when you first turn the laptop on then it's the motherboard that is faulty.
Careful with the monitor to motherboard plug as I damaged mine and the screen is now a permanent shade of blue.
Jun 25, 2008 | Samsung V25 XVC 2800 Notebook
Samsung V25 CXTD 2000 Notebook Logo
176 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
