Question about Frigidaire GLTF2940ES Front Load Washer
Dryer door problem
My frigidaire gallery series front load washer GLFT2940ES3 is giving me error code dr. Do you know if I can fix this myself ??
Comment by erniep32, posted on Jan 05, 2008 the code is
dr it looks like
  • tntaylor53 Jan 15, 2008
    I have the same problem. I get a dr code. I checked all of the connections and they appeared good. I have removed the Door Lock Switch Assembly and will replace.
  • 125 Answers
Most likely the door lock is bad, check the wire connections to make sure thay are connected. If so replace the door lock assembly.
Posted on Jan 13, 2008
I'm getting a door error "dr" on my ATF6700SF0 washer. How can I determine whether to replace the door lock assembly or the control board?
Hi Curt, this is AP
I understand you are having trouble with an error code on your Frigidaire front load washer. On your particular model, ATF6700FS, the error code "DR" indicates that the door is open or there is a problem with the door. If you know the door is not open you should check the door switch and wiring. If you need assistance with replacing the door switch I would recommend contacting an authorized technician in your area. I hope this information proves helpful to you, thank you for the post.
Mar 29, 2014 | Frigidaire ATF6700FS Front Load Washer
I have a frigidaire gallery series front loading electric dryer model # start and it beeps with a dr code.any idea what is causing this?
dr is door error
this generation of dryer has alot of control board failures(the relay for the heat burns the terminals for the wires you can inspect these relay connection visably by removing the front control panel you might want to try setting the machine to the fluff/air dry setting and try starting the dryer, if it starts in air fluff you need to check the connections on that relay this is not a factory taught test.its just something a customer pointed out one time and i have tried on many after the fact, and for whatever reason these machines will still run in fluff mode when the board is fried
Oct 22, 2011 | Frigidaire Electric Dryer
How to disable buzzer from frigidaire gallery series stackable washer/dryer?
Here is a site showing all of the steps to disable both buzzers on the Frigidaire Gallery series stackable washer/dryer.
Nov 19, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
Error Code "dr"
Dr means door problem, either some clothes is keeping it from shutting or the door switch is bad 1ff09a4.png
Mar 05, 2010 | Frigidaire Affinity ATF7000ES Front Load...
E10 error code
1 beep and E10 is listed as the dispenser door is open. Try reclosing your soap dispenser door tight.
Jan 18, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
I have a Frigidaire Gallery front load washer with E10 error code
When ours does that it is because of the hard water build up. We have to un-hook the hot water clean out the minerals and it stops doing it.
Jan 10, 2009 | Frigidaire ATF6000ES Front Load Washer
Error code
'dr' is an error code that indicates the door is not closed. If closing properly the door lock may have to be replaced.
Jun 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity/dr error
dr code means door not closed
get some crc spray and spray into lock on machine
that will lube the workings and should fix problem
Mar 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
246 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
