Question about NetTV PDP42V Television
No picture but sound
The tv is a Grundig thaurus(but a pdp42v5 chassie)
tv turner ok, sound ok but no picture!!!
signal to y and Z seems ok but X-signal i almost zero.
one gren diod is flashing on the controll board.
where can I get help!!!
    President:
  • NetTV Master
  • 749 Answers
Here's what you need:
1) General guide - very similar TV, same main issues and troubleshooting process:
http://blog.coppelltvrepair.com/2011/02/hp-pl4260n-suddenly-lost-picture-how-to.html
2) Most common repair for the pdp42V5 chassis:
http://www.coppelltvrepair.com/p/227/viore-pdp42v18ha-ysus-6871qyh053b-repair-service
Hope this helps!
Posted on Apr 15, 2013
There is a lot of good info here:
http://www.forums.hcsd.com.au/Blah.pl?b-plas/
Posted on Aug 30, 2008
I found a burnt spot on the primary board and i was wondering if thats the case for not having sound or picture?
Yes,that the problems.The tv main logic tv Tuner signal can't complete it circutries paths.Tries websites like Shopjimmy.com,Ebay.com to buy the tv main logic Turner signal for the replacement.
Aug 26, 2011 | Protron PLTV3250 32 in. LCD Television
Thomson 21"tv, with TX91 chassi, having picture
sounds like week signal. try on another aerial and retune.
Dec 22, 2010 | Thomson 21DC320 TV
I have a Sharp 32" Standard TV ... picture will get fuzzy either due to someone walking by or sometimes if sound coming from tv is vibrating. If we shut tv off and turn it back on it is clear again. The...
Hello: Your problem seems to be in or around the tuner of the television, More then likely you have cold solder joints on the turner that needs to be resoldered. Also check the coax end protruding from the back of the set where u connect the cable and make sure it is not loose, a bad ground on this connector to the turner shield will cause this symptom. My professional diagnostic is that when the television is cold the solder connections are making contact with the board, and as heat builds up in the television while watching these connections tend to seperate and make limited contact, causing fuzzy picture and in most cases no picture just snow...
Sep 06, 2009 | Sharp 32C-240 32" TV
My Vizio 32" Flat Screen suddenly turned blue and "no Signal"
Check the cable connector. If it is OK then the turner has gone bad. Replace main board will fix it.
Feb 06, 2009 | Vizio L32 32 in. LCD HDTV
SANYO TV MODEL CM20SP8S CHASSIS AC3-A20
try to fine tune your tv using the remote control, or, if you had knowleged in electronics adjust the sound IF transformer using a wood stick or plastic don't use a metal in adjusting the IF
Sep 01, 2008 | Sanyo AVM-3259S TV
PDP42V5
Hope this helps!
Jun 13, 2008 | Televison & Video
No signal on digital TV
If you are talking about over the air digital channels I would lean toward ant problems
Apr 26, 2008 | Televison & Video
Repair grundig 960
CONTACT BROADWAY TV SERVICE THEY FIX MINE FOR
LOW COST:$25.00 FOR ESTIMATE APLIED TO REPAIR PLUS H&S(APROX TOTAL ON MY REPAIR WAS $95).
BROADWAY TV SERVICE
potterstvcr@sbcglobal.net
685 BRODWAY AVE
SEASIDE CA 93955
(831)394-2349
Dec 05, 2007 | Grundig Classic 960 Shelf System
Grundig Xentia - sound but no picture
in your tv is malfunctioning high voltage, the audio is generated without the help of high voltage sistem how happens commonly in many other tv
Aug 07, 2007 | Grundig GF70-600 TV
NetTV PDP42V Television Logo
628 people viewed this question
Top NetTV Televison & Video Experts
Are you a NetTV Televison and Video Expert? Answer questions, earn points and help others
