Question about Acer AL2216WBD LCD Monitor
No signal box
Computer comes on. all cables hooked up but get no signal.
  • 2,427 Answers
If you got a video card installed on your pc, you might want to take it out and try the on board video port..
If you dont have an onboard video and you dont have a video card, OR you have a video card but no on board video the follow these steps
1.) open you computer system
2.) locate the jumper labled jp1 (you can use you manual for quick referance)
3.) the jumprer is currently set to 1 and 2, set it to 2 and 3
4.) set it back to 1 and 2
5.) try start your system now
If you unable to do the above or it did not work then
1.) unplug the system
2.) remove the the memory
3.) remove the battery on the computer circuit board
4.) press the power button 5 tmes to discharge the capicators
5.) wait ten minutes
6.) press power button 3 times to ensure discharge
7.) replace memory, battery
8.) try booting now
Posted on Jan 07, 2008
  • 233 Answers
Do you get any video on the LCD like a menu or something? if the screen has power and you are sure your computer is putting out a video signal it may be the inverter board on the LCD, this board feeds hi-voltage to the lamps that displays a screen and is a common problem with all LCD screens.
Hope this helps
thanks for your rating
How do you hook up cords to cable box & television
WELL IT SEEMS U HAVE TWO PROBLEMS :
1ST YOUR rF SIGNAL IS NOT GETTING THRU , THIS IS A ROUND CABLE WITH A SCREW ON END TO IT , THIS ONE MUST 1ST COME INTO YOUR HOME AND GO TO CABLE BOX , THEN LEAVE OUT OF CABLE BOX AND ENTER VCR THEN LEAVE OUT OF VCR AND GO TO RF INPUT OF TV ( HAS TO BE HOOKED THIS WAY WONT WORK ANY OTHER WAY) SET OUTPUT OF VCR TO CHANEL 3 SET OUTPUT OF CABLE BOX TO CHANNEL 3 SET TUNER OF VCR TO CHANEL 3 , AND LAST SET INPUT OF TV TO rf CABLE ,CHANEL 3 , NOW YOU CHANGE CHANELS ON CABLE BOX only
2ND YOUR DVD PLAYER HAS NO RF OUTPUT SO YOU NEED TO CONNECT BY ONE OF THESE MEANS (HDMI, RGB, COMPOSITE) ALL THESE REQUIRE A DIFFERENT CABLE YOU DECIDE , THERE HOOK UP IS PRETTY MUCH ONE WAY SO I WONT ELABORATE ON EACH METHOD , BUT TV NEEDS TO BE SET TO CORESPONDING INPUT TYPE YOU DECIDED ON
Nov 11, 2015 | Magnavox DV220MW9 DVD Player VCR
I have my small cable box that used to be hooked up to this tv hooked up to it again and cable box not responding tv turns on and no signal comes up
If you depowered the box, it may need to reboot and reconnect with the cable company server. You don't indicate the service provider but with WOW, you sometimes have to have them send a rest over the system.
Jan 01, 2015 | Televison & Video
When I hook up the HDMI cable to the Cable box, the sound does not work. It comes in and out. I tried all 3 HDMI ports, same result.
Buy another HDMI cable an tried it out maybe the cable it bad.Tries the cable box with an colaxial hook up see u get the same result,could be the cable box it bad.All these thing are test,all things are good.Than the tv Tuner signal board is bad.Tries website like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Oct 22, 2010 | Televison & Video
Used to be hooked to satelite ,now cable and says
Unplug,replug the cable box about an hour later,let it reset itself.The box will reboot itself,and upgrade the software.the signal should work again,not the cable box is dead must replaced.
Apr 26, 2010 | RCA L32WD22 32 in. LCD HDTV
How can i get by without using a convertible box
what are your intentions, i have one t.v. that is hooked up to a HD channel changer, where i get a HD signal coming Thur, the other t.v. has no HD box at all and it runs str8 off of the cable,but i do not get a HD signal with that, in canada the setup is different here the HD signal comes right Thur the cable lines here, also have ya ever thought of hooking up your t.v. to a antenna, i've picked up signals of HD for free, and the picture quality is superb to that of cable company, anyways good luck
Mar 11, 2010 | Vizio L32 32 in. LCD HDTV
Problem hooking up DVD player to TV thru my cable box
Chances are you've got your DVD player hooked to OUPUT jacks on the cable box, not inputs. I haven't yet seen a box that takes any kind of an input other than the cable line, but they will have RCA jacks for audio and video outputs on the back. So your cable channels are fine, but the DVD signal is hitting a dead end.
The only solution if your TV doesn't have RCA inputs for video and audio is to get an RF converter (around $10-$20). This takes the A/V signals from your DVD and turns them into a channel 3 or 4 signal that connects to your TV's antenna input.
The converter also has a connector on the back for the cable coming from the cable box, since you'll have to disconnect that from the TV. When the DVD player is off, the cable box signal gets passed to the TV as normal. Turn on the DVD player and the RF converter switches on; put your set on channel 3 or 4 and you'll see your video.
One final thing: The converter will need an AC outlet for its power adapter or power cord, so make sure you have a spare. If you don't already have your TV and DVD player connected to one, this would be a good time to pick up a surge-protector outlet strip. Then not only will you have enough outlets, you'll be protecting your equipment as well.
If this solution has given you what you need, please take a moment to rate it appropriately. And thanks for asking here!
Feb 01, 2009 | RCA DRC277 DVD Player
When I plug in my hdmi set top box my monitor says no signal
If an HDMI cable won't work, try Component Cables.
I went through the same hassle as you.
Jan 25, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
Hooking actual live coaxial from Cable Co. to Insignia Converter Box ...
Based on the specs that I have read I am going to say you cannot hook up cable to the converter. Best thing to do would be to call cable company that provides service there and see if it was turned off on the billing side they probably just didn't come out and disconnect from the pole. That might give you service but missing some features such as tv guide channel. Now some tv's have tv guide built into them and maybe in the move that feature on the tv was turned off it they were using it that way before. Here is what the specs say about that converter:
Use this digital-to-analog converter to convert digital TV broadcast signals to analog signals on analog TVs with antenna-based reception.
Nov 08, 2008 | Insignia Digital-to-Analog Converter for...
Can't get picture
Hello matthew95765,
The TV is working, the message is coming from the dish box. What you need to do is to determine if the dish box is connected to the dish and that it has signal at the box, because the message it is delivering to the TV is that it is not receiving signal from the satellite. so you have to check the connection at the satellite and at the box because those are the only point that can generate the error you are getting.
I hope this helps,
Thank you,
Shuttle83
Jul 23, 2008 | SVA-USA SVA HD4208TIIIBU 42" Plasma...
Says no signal when switched to hdmi when there is one.
My best guess would be that the resolution settings on your reciever are set too high(It's putting out an HD signal the TV can't display) Plug in through Composite or component the the box and resolve this through you Cable box's menu, then reconnect the HDMI cable.
Dec 23, 2006 | Olevia LT27HVX 27 in. LCD Television
Acer AL2216WBD LCD Monitor Logo
63 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
