Playing a dvd
When i place a dvd in the drawer and press play, the draw closes it goes to 1 and then the draw opens again, obviously not playing the dvd .there is no error message
  • 2 more comments
  • dalink12 Feb 05, 2008
    Sorry this wasnt a solution but a similar problem...(previous post)
    I'm having a similar issue....I load a DVD and the player goes thru the normal cycle and just when you think you hear the DVD start to spin...is cycles again and ejects and closes half way then powers off? I took off the cover (like I know what I'm doing) and figured that the leverage gear which raises the laser to the turn pad thing isnt getting acctuated....? I cant figure out what makes that gear turn..there is nothing really touching it?
  • Anonymous Mar 12, 2008
    My SD200E also turns on, the drawer comes out, I load the disc, the drawer loads and the lazer lifts up to the disc, however it does not turn the disc but ejects every time. It also will not power down when I hit the power button..I have to unplug it to lose power. It seems to load and lock fine, but it will not play. frustrating since its not old enough for me to accept this failure.
  • acomenzo Jul 19, 2008
    Having the same trouble as everyone else. The laser head does move on mine, however. It looks like it's and electromagnet - when current is applied it floats up to read the disk (I've been poking it w/ a toothpick - very high tech).
    In my case, the disk spins up but almost sounds like it doesn't get up to playing speed and then fails w/o reading the disk. Truly sucks since this player was used a total of two times (about 8hrs of play). If anyone has an idea please post it here!
I'm having a similar issue....I load a DVD and the player goes thru the normal cycle and just when you think you here the DVD start to spin...is cycles again and ejects and closes half way then powers off? I took off the cover (like I know what I'm doing) and figured that the leverage gear which raises the laser to the turn pad thing isnt getting acctuated....? I cant figure out what makes that gear turn..there is nothing really toughing it gear or spring? anyways I'm looking for a solution myself.
Posted on Feb 05, 2008
My sl pg 320 switches on, cd goes in, the play light comes on when I press play but then goes off again and does not play. Each time I open and close the draw the play will activate and then go off
Hi. It's possible the loading belt is in need of replacement if the drawer isn't fully loading.
Or could be in need of the lens cleaning / replacement laser.
Hope this makes sense.
Feb 02, 2018 | The Audio Players & Recorders
Unlocking my DVD player
some others
new model pacific 1002mk2 (ASDA) using remote.;
press open on remote
press clear
press 1-3-6-9 Then 0(for multiregion)
Press close
It's important to note that you will not see anything happen on screen or display!
The buttons are small,so you'll have to be precise
1. PUT A REGION 2 DISC IN PLAYER
2. WHEN IT IS LOADING UP PRESS "SETUP"
3. PRESS "7" FOR MULTI REGION
4. PRESS "PAUSE/STEP"
5. PRESS PREVIOUS " |> "
6. PRESS SETUP
YOUR PLAYER IS NOW MULTI REGIONAL.. IS YOU WANT TO SET THE REGION IN STEP 3 PRESS 1 FOR USA OR WHATEVER YOU REQUIRE....
or
switch on.on the remote press "open/close",0,1,2,3,open/close and it plays straigt away. but nothing is shown on the screen.
or
It's true - a quality DVD player from Asda for £59.95. Highly recommended. This 1359 hack worked with my Pacific 1002 purchased March 03.
Note. There is no on screen display or any indication on the machine when entering the hack.
Switch machine on and using the remote control only:
1. Press 'open/close' button (the draw should be left open).
2. Press the 'clear' button.
3. Press '1'.
4. Press '3'.
5. Press '6'.
6 Press '9'.
7. Press '0' (zero for multi-region).
8. Press 'open/close' button.
End.
or
1. switch on dvd with remote (leave drawer closed)
2. Press: setup
3. press: 7 (note nothing will happen)
4. press: pause/setup button (again nothing will happen)
5. press: previous/I<< button (nothing will happen)
6. press: Next/>>I button (nothing will happen)
7. press: setup
Dec 05, 2007 | Televison & Video
MHC-RG270 cd draw won't open
cd drawers often jam.
In the cd/dvd drawer you will see a small hole. Use a blunt pin or a straightened-out paper clip, insert it into the small hole and gently press. The drawer should then click open.
Try cleaning the plastic drive teeth/mechanism with a light drop of oil. Press the drawer button and it should then close. Press it again to see if the drawer opens as per normal.
If your cd drive plays a dvd as per normal but doesn't open when the button is pressed, continue using a blunt pin/paperclip. If the plastic open-close mechanism is worn or damaged there's very little you can do about it expect replace the entire drive.
Feb 01, 2014 | BenQ FP91G+ 19" LCD Monitor
Draw will not close
Look under the drawer and look for a plastic pin sticking up. This pin needs to be in the track on the bottom of the drawer for it to close and load correctly.
Feb 22, 2013 | Panasonic DVD-XV10 DVD Player
Unlock Toshiba DVD player SDP93S bought in America to play Australian DVD's
Thanks for understanding. Please let me know if you require any clarifications.
Jul 09, 2011 | Toshiba SDP93S Portable DVD Player
I have a dvd from England and my old Sony DVP-C670D keeps giving me a prohibited message4 every time i try to play it. How do i unblock the region code.
Although no guarantee, this 'region hack' is rumoured to work:
1. Place the DVD player into 'standby' mode.
2. Using the Sony remote, press the following button sequence: Title; Clear; Power (green button); 0 (zero button)
3. Using the remote, Open the disc tray, then close again.
Now insert your disc and attempt to play - allow up to 2mins to load/play. If no response, open/close tray and try playing disc again.
Cheers,
Jun 22, 2011 | Sony DVP-C670D
Wrong region message
power on.
open the drawer & LEAVE IT OPEN
press on the remote control
1 3 7 9
four small stars appear in the top left of the screen whilst you enter the code chose whatever region you want 0 is region free
once the code is entered simply enter the region number you require, close the drawer & press play
Mar 31, 2011 | Daewoo DVG-8500N DVD Player
I have a dvd player daewoo dvg 8500n and don't work on region 2. thanks
Open the drawer and LEAVE IT OPEN
Press 1379
Four star will show up on screen
Press 0
Close drawer with control
Press play
Feb 14, 2011 | Daewoo DVG-8500N DVD Player
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
