Question about Toshiba Satellite M45-S265 Notebook
Wireless connection problems
My Satellite has generally VERY WEAK and very unstable connections to wireless. Only if I am right next to a very strong hub does the signal remain strong and intact - and even then it may cut out every 20-30 minutes. In my house 5 of us use the wireless and everyone else is just fine, but mine again only works very near the hub - and again with breaks (often meaning downloads have to be restarted, etc.)
I am using the Intel PRO/Wireless 2200BG hardware and have downloaded the latest drivers and have set the power use to maximum. I'm not 100% sure about the other settings. I have enabled throughput enhancement. Should I maximize roaming aggressiveness? Should I purchase an external USB wireless adaptor?
Any other suggestions?
  • philosopher Jan 16, 2008
    Thanks OminiousD,
    I did go out and buy a Belkin G+ wifi USB antenna. It was pricy, at about $85, but it works great, so I'll consider my problem solved. If I had the time to play around with less expensive ones, I would have.
    Thanks again.
    Problem Solver:
  • 9 Answers
I would see if buying a cheapy PCMIA wireless card and trying that out.
It sounds like your wireless card might be screwed up. And there are so many things that can interfere with those things. They are kind of finicky.
Definitely look into getting a PCMIA or USB wireless device and try it out. I personally wouldn't buy something that was pricey and would try and get something reasonable. REMEMBER 802.11 is backwards compatible (G is compatible with B AND A) so you don't necessarily need the newest greatest thing.
Best of luck.
~Ominious Depression
Posted on Jan 08, 2008
Authentication error
Had same problem - said signal weak although strong on other devices, and hung on authenticating.
Cordless phone on base unit was beside wireless router. Moved unit and turned off phone. Problem disappeared, and signal showed strong.
Jul 12, 2013 | NetGear WNDR3400 N600 Wireless Dual Band...
Laptop not connecting to wireless network
Don't wait tell you laptop is defective, at least buy a new wireless lan before its too late.
Sep 30, 2009 | Dell Inspiron 5100 Wireless Mini-pci...
Intermittent connection from router
Have you checked with your ISP on the strength and consistency of the signal before troubleshooting the router. If you're having problems with the wired connection, I would first try connecting directly to the modem to make sure you have a strong signal.
Let me know if you have a strong signal directly from the modem. We can troubleshoot the wireless router once we ensure the signal from the modem is good.
Aug 14, 2009 | Airlink Router
My Acer Aspire notebook keeps losing its internet connection. I have used 2 different routers and the signals were strong on both, so it's not that. I've also downloaded what I took to be the appropriate...
If you are using the supplied Acer program to setup your wireless, I would suggest removing the program. In most cases, removing their software does not remove the drivers, and thus, Windows Zero Configuration will take over the wireless.
WZC, in my opinion, works very reliably and has solved this type of issue in the past, although it is not the only reason for disconnects. For instance; a weak signal and a lot of interference from neighboring networks can cause your wireless to become unstable.
If this doesn't fix your connection issue, you may have an issue with the wireless card itself.
Jul 29, 2009 | Acer Aspire One AOA110-1588 Notebook
Weak connection on one computer in network
set the wireless channel for you router to the maximum level and save the changes
Nov 13, 2008 | Linksys Wireless-G WRT54G Router
if it says 'no server' that means your wireless internet connection signal is weak. try to find a location where you can get a strong signal
Oct 15, 2008 | Toshiba Satellite A135-S4527 Notebook
Computer will not connect to wireless router
the antenna wire sounds pinched it is in the usually in the lid and can be found by looking in the hinge area
Look to see if it is kinked
Sep 21, 2008 | ASUS Eee PC 900 16G Notebook
Check the wireless network card
try to reinstall the driver
Jul 27, 2008 | Computers & Internet
Wireless router
I think 2wire routers are good in providing signal strength. Contact the 2wire vendor regarding your requirements.
take care
May 01, 2008 | AT&T High Speed DSL Modem
Wireless not working
Make sure the wireless power switch on the right side (next to the USB port) is turned on.
Jan 13, 2008 | Toshiba Satellite A65-S1065 Notebook
Open Questions:
See all Toshiba Satellite M45-S265 Notebook Questions
Toshiba Satellite M45-S265 Notebook Logo
102 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
