Question about Epson Printer
Trying to set the offset on Datamax Prodigy Printer
I've got a prodigy plus printer which is one of several we have in the company. The printer is not advancing far enough and results in a ripped label. When I check the settings, I can see an offset set at -20.
What I can't understand is how to change this setting. All I have to work with is dip switches and no LCD or display or any kind.
Can you please advise what I'm missing to complete this task?
  • 38 Answers
Add the OFFSET command (Oxxxx) command to beginning of the data. A value of around 0700 usually works.
The prodigy+ does not have any other facility for setting the tear-off position, nor is the effect of the O command persistent.
I don't know where you're seeing that offset value since the printer cannot report it. If it's in your printer driver, then try adjusting the value in the driver itself.
Steve
Posted on Mar 05, 2008
How can i send an ascii file to a network shared Datamax Prodigy Plus printer? It is not printing via send file, windows driver send command to printer works. Thanks for any help!
copy file.txt lpt1 is the command to copy the txt file to the printer, but it must be correctly formatted for the Datamax. I don't know Datamax's programming language, but at first glance that file looks like ZPL to me. If it is ZPL the Datamax can't print it.
Jun 15, 2015 | Datamax Prodigy Plus Thermal Printer
Datamax I-4208 has different position than i-4308 or prodigy max
On the I-4208s, press Menu button on front of printer. Go to Print Control. Go to Custom Adjustments. Go to Row Adjust. Change Row setting as needed. Ok to go negative.
Feb 17, 2012 | Datamax I-4208 Thermal Label Printer
I'm trying to figure out how to connect my Datamax Prodigy Plus Thermal printer to my PC. I have a 25 pin connector on the Printer labeled J2. Also a round plug-in labeled J4. My computer has the same...
If the cable works on the Zebra it should work on the Datamax. It must be a RS232 serial null modem cable.Check the serial port settings and make sure the printer setting match the PC serial port settings. Baud Rate=________? Data Bits=________? Parity=_______?Stop Bits=________? Handshaking=____________?
The typical settings are Baud 9600,8,n,1 Xon/Xoff.
Also make sure of the comm port being used. com1,com2......etc
Jun 09, 2011 | Datamax Prodigy Plus Thermal Printer
El display se ve de cabeza
pointer 6920: Debes de cargarle el ultimo firmware disponible, este firmware trae resuelto el problema del display. Posiblemente tengas que cargar tambien el Boot Loader para que la impresora acepte el firmware. Puedes descargar ambos archivos desde ftp://ftp.datamax-oneil.com/Printer%20Firmware/ , para cargar el boot loader debes de poner la impresora en modo descarga presionando las teclas PAUSA y TEST mientras enciendes la impresora.
Roberto Martinez
padrino99@prodigy.net.mx
Mar 31, 2011 | Datamax I-4208 Thermal Label Printer
Printer shows this error: Booting... EEROM test failed Will not reset
mmoore503: Maybe have to update firmware, and to download you must update the "boot loader" also. Download files in ftp://ftp.datamax-oneil.com/Printer%20Firmware/
Roberto Martinez
Mar 01, 2011 | Datamax I-4208 Thermal Label Printer
My datamax printer keeps spitting out 8 labels everytime i hit the feed button or print something
It is the media sensor. Try adjusting and check for stuck labels in it blocking the sensor.
Jul 21, 2010 | Datamax Prodigy Plus Thermal Printer
Ido not have any problem if I print label using Zebra. I wrote codes on Visual Basic 6 to print label using Datamax printer conneccted parallel port with command L to start. The printer printed the text...
Do you have Zebra emulation firmware installed? If not, your printer will not understand the command language that you are sending to it. Datamax has its own language and you will need a branch in your code to support that if the printer does not work with ZPL.
Jan 14, 2010 | Datamax Prodigy Plus Thermal Printer
HOW TO PRINT LABELS IN DATAMAX PRODIGY PLUS PRINTER USING VB.NET
Tu necesitas utilizar comandos DPL. Pero si vas a utilizar graficos o windows true type fonts, tu necesitas un cartucho de memoria ram o flash. You need to use DPL commands. But if you use graphics or windows true type fonts, you need a RAM or flash cartridge.
Apr 06, 2009 | Datamax Prodigy Plus Thermal Printer
My datamax prodigy plus wont print out a word doucment
You need to download the Windows Drivers from Datamax Website, you can then use the printer with all Windows based applications
Apr 13, 2008 | Datamax Prodigy Plus Thermal Printer
Epson Printer Logo
132 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
