Question about Philips 9P5034C 50" Rear Projection Television
I have a philips tv, model # 9p5034 c103
I have had this tv since 2000. I moved it yesterday from one town to another. About a 40 mile drive. It was covered in the back of a truck. However, once we got it turned back on the screen has some issues. Anything white, shows a white haze around it. I have played with the color/brightness settings and the convergence. Nothing seems to be working. Anyone have an ideas?
  • mulford_4 Jan 07, 2008
    Is this a costly repair?
  • laziflower Mar 10, 2008
    ** picture or sound. the power light comes on. i don' t ** model# it's a 50 inch phillips magnavox.
I HAVE A PHILLIPS MAGNOBOX TV MODEL 9P5O34C103 AND I CANNOT FIND A PART. I NEED A CAPACITOR ELECTROLIC 470UF 200V
Posted on Jan 08, 2008
You need a repairman to reset the prizum
Posted on Jan 07, 2008
I own a 40 inches philipps model 40PFL7505D, there is a blackout after about 2 hours of listening. The sound is also out at the same time. That's happening like 3 times a minute and the tv is still working...
If you are sure the set is getting a good sound signal the ask Philips at: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=ca&userLanguage=en A lot of HD cable systems have breaks in the sound transmission. It drives me nuts.
Feb 11, 2015 | Philips 40pfl7505d/f7 40-inch 1080p 120 Hz...
Nissan D21 automatic wont move when running
Check the trans fluid level first with the engine running. If its low , top it up. Then go back and have them take care of the valve issue.
Mar 09, 2014 | 1993 Nissan Pickup
Foggy picture
not worth it, likely been dropped and all the lenses etc are out, or just worn out from a hard life.
Oct 12, 2009 | Philips 9P5034C 50" Rear Projection...
1997 Chrysler Town and Country Transmission clunks with downshift
Check the universal joints in the drive shaft to rear axel. 120,000 miles, its time for replacement. Safety hazard exist, check soon. Also transmission filter should have been serviced at 60,000 miles. Its time.
May 20, 2017 | Chrysler Town and Country Cars & Trucks
Phillips Magnavox model 9p5034 c101
You can get the actual remote control for that model at the following link. If your not sure which one it is just leave them a email with your model number and they will respond quickly. Heres the link.
http://servicemanuals.vstore.ca/
Aug 02, 2008 | Philips Magnavox 9P6034C 60" Rear...
Sometimes it turns on, sometimes it doesn't,9P5034 C101 PHILIPS
NOT EXPENSIVE POWER SUPPLY PARTS ARE NEEDED TO BE REPLACED . ONLY A TECH WHO , HAS EXPERIENCE ON THIS TV MODEL AND THE KNOWLEDGE ABOUT THIS PROBLEM ,COULD FIX THE TV RIGHT THE FIRST TIME. OTHERWISE REPLACE POWER DEFLECTION BOARD ,PARTS AVAILABLE AT PARTSTORE OR SIMILAR COMPANIES
Apr 18, 2008 | Philips 9P5034C 50" Rear Projection...
Magnavox Projection Model # 9P5034 C101
Yes you will need to discharge any electrical equipment before working. One way of doing this is keep equ. unplugged for sometime or after unplug short hot to ground which will most times cause a spark. You can go to vancebaldwin.com or andrewelectronics.com or any online parts store and get the part number off old IC, yes these are on the convergence module. They are big STK's, also there are resistors that will need to be changed and maybe pico fuses.
Jan 05, 2008 | Philips 9P5034C 50" Rear Projection...
Fix the cross on my tv
You will have to get the original remote I,m afraid. There are not any universal remotes except the programmable learning type remotes that will work those functions for you. You can get an original replacement remote from here http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=9P5034C103&brand_pn=MAGNAVOX_9P5034C103&mode=large&uid=11889902397190 Good Luck
Sep 05, 2007 | Philips 55P8241 55" Rear Projection...
Black Screen, With Sound
the high voltage section is not turning on due to many possible reasons, would not recommend trying to service yourself, but is fixable for around 100$ or so
Mar 14, 2007 | Philips Magnavox 9P6034C 60" Rear...
Philips 9P5034C 50" Rear Projection Television Logo
145 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
