Posted on Nov 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sharp SF-7320 produces grainy copies
I have a Sharp SF-7320 copier that produces grainy output. I removed the drum and the developer, blew out the dust and loose toner with an air compressor, made sure the glass, mirror and pickup lens is clean, and installed a brand new drum. The copies come out but there's specks of toner in random places on the page (like static). Is this an electronic or mechanical issue?
Anthony Karuku
Level 2:
  • Office Equip... Expert 268 Answers
  • Posted on Nov 11, 2009
Anthony Karuku
Level 2:
Answers
268
Questions
Helped
104874
Points
615
Clean the drum unit seal blade thats leaking or replace it.
2helpful
2answers
After changing toner on my sharp, SF-2022 copy machine, the copies are coming out with black smudge marks across the paper? how/where should i clean?
This means the machine is over-toning ie using more toner than required caused by either improper toner or different brand of toner. The correct toner is sf 222T1. Replace developer and use the right toner and clean the drum and its blade. You may need to clean fuser rollers for cleaner copies.
2helpful
2answers
I have a Sharp SF-7320 copier. It is making a
Replace the copying clutch or clean the reverse copy clutch and clean and oil the scanner rail.
1helpful
2answers
Copy machin SHARP SF-7320
Check the copy lamp and its thermal fuse if they are okay, then clean optics, check drum and blade and clean or replace and finally clean or replace fuser rollers. If the above is ok and still black copies, check the copy lamp wire harness for continuity or the copy control board located underneath the display panel and check for bad component like triac and replace. If OK replace the main control board.
1helpful
2answers
Full black
Check copy lamp if its lighting during copying if not Switch off and remove socket outlet and check lamp and thermal fuse . Clean optics.
3helpful
Our nonprofit got a sharp sf-2040 donated. It prints a too light of a copy. I tried to replace toner it was full. No keys or directions light up - does it need a new drum or something.....??
There are several solutions to this problem:
1. Adjust the exposure
2. The drum may be out.
3. The developer may be out.
4. Finally, You may need a PM for the copier. (replace the drum, developer, drum blade)
1helpful
2answers
SHARP SF-7320 doesn't start
Also adjust your front door which acts as a switch.
1helpful
2answers
Sharp sf 2114 too much toner on copies
Sound like you need to have the developer, drum and drum blade replaced, you might want to have a tech look at this.
Hope that helps.
Lbcoaster
Sharp AR 5316e copier
check if the developer that comes in a silver bag has been installed and the screw that fastens the scanner has been removed.
1helpful
2answers
No bottons are working
This means the developer unit is not installed . Check and instal.
k24674
ADMIN Andrew
ADMIN Andrew
