Screen flashes black
TV= LG 50PC56 screen flashes black during some: programes(tv)/websites(pc)/folders(pc). All cables and connections appear fine.
Hi. The method above is only for LCD.
Your problem is on PSU board. It`s in the middle when you open the back cover of the set. The board fixed with 8 screws . 3 crews (one on the left and 2 on the bottom) have small metal plates soldered in to the board. You have to unscrew it and clean the plates under it. The plates connected to the ground and must be screwed very well. Bad joint of the plates to the panel ground causes black screen problem.
Posted on Jul 12, 2014
You mentioned this would work for LCD monitors, is the method the same for plasma screen's, thanks for any help!
Posted on Mar 07, 2008
    Novelist:
  • 138 Answers
Hi this is the way how to examine what's wrong with your LCD monitors. After you turned it on and the screen blacked out, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
LG Tv M227WDL HDMI black screen
If the HDMI input is failing you will need to ring Customer Support or Get a New TV because if its not outputting then The HDMI may not get Prosecced (sorry about spelling) And make sure you have checked its the Correct port and that there is no Blue-Tac or dust in the port ( that ussually solves this) If all else fails Use a Hairdyer and give it a Big clean :D
Mar 14, 2014 | Televison & Video
Tv appears to go while connected to cable box, change cable channel tv is on
swap out the box as it could be the problem and if it never does it with a DVD being played it is not likely to be the set.
May 15, 2012 | LG Televison & Video
Broken Laptop screen, trying to connect to tv.
OK, you have to hit the FN (Function Key) + the F4 key to get the image to display on the TV. Press and hold the FN key then hit the F4 key and the image should appear on the tv if you have a VGA cable connected to the TV and to the HP Netbook.
Once you see your desktop on the tv you can get your files off my purchasing a USB Flash Drive of at least 8GB or 16GB (Just depends on how big your My Documents folde is). Then put the usb flash drive in the usb port and copy whatever files you want. Most of the things you want will probably be your documents, music, pictures and videos. These are normally found in the My Documents, My Pictures, My Music, My Videos folders. There is no need copying things like programs or other stuff because they will not work. They have to be installed thru the normal process to update the windows folders, settings and registry.
Mar 21, 2012 | HP Mini 1000 Netbook
Thin vertical red line on my LG 50PC56
First you must clean connector contacts between plasma module and driver boards, if not solve the problem and continuing increment of wide red line, may be you must change plasma module to solve this problem,
May 27, 2010 | Televison & Video
Screen suddenly went to complete snow no video or audio
Well the LG tv is not getting the cable signal.Unplug the cable box about an hour.Replug the box let the software to upgrade the cable box.The LG tv should get the signal back as normal.Not,than the LG tv Tuner board have problems it dead.Tries Websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Apr 21, 2010 | LG 32LG30 32 in. LCD HDTV
When i record spanish satalite station the recorded program goes black and white on a regular basis
Well, if the program is showing in color on the TV, then the TV is fine. If she's recording using a VCR, then I presume she doesn't have a cable box? If she doesn't have a cable box and has the cable from the wall going into the VCR and the VCR connected to the TV, then the problem is the VCR if the program appears in color when showing "live" on the TV but black and white when played back on the VCR. Does that make sense? Let me know if you understand what I'm telling you.
Feb 07, 2010 | LG 32LG30 32 in. LCD HDTV
I'm trying to connect my desktop Dell (PC) to my 26LG30 tv. When I start it up, all appears to go as normal - and then it goes to "invalid format" on the screen. I've set the TV input to RGB-PC and...
Try to reinstall the video driver for the desktop. you can download the drivers from http://support.dell.com
Also flash the bios of the computer by download int the file from the above website.
and also try to change the resolution by connecting to a monitor and try connecting to the TV ..
Dec 26, 2009 | LG 26LG30 26 in. LCD TV
Can't figure out how to turn on cable on Sony Trinitron TV
Setting Up the TV
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
(Make sure CABLE is connected on coaxial and you are not using any other connections such as cable box, hdtv or satellite antenna)
1 Press to turn on the TV. The Initial Setup screen appears.
2 Press on the remote control or on the TV front panel to start Auto Program, or press
to exit.
To perform Auto Program again
Press .
2 Press g to highlight Channel Menu.
3 Press f to highlight Cable. Press to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select.
5 Press f to highlight Auto Program. Press to search for channels.
6 After Auto Program finishes, press to exit.
To reset the TV to factory settings
Turn the TV on.
2 Hold down on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release .
✍ When you start Auto Program wait until it is finished; otherwise it will skip over channels that are
available. Perform Auto Program again to program receivable channels.
✍ The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
Initial Setup
Auto Program [CH+]
[CH–]
First please connect
cable/antenna
Exit
Jan 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Screen going black on LG60PG60 TV
It does seem to be a tv problem, check the input connector to the tv next time when it happen, this tv seems to have problems with connectors or could be the video processor good luck
Nov 22, 2008 | LG MU-60PZ11 60 in. Plasma Television
Computers & Internet Logo
729 people viewed this question
Alun Cox
David Payne
David Payne
