Question about Philips 170B5CB 17" LCD Monitor
Computer says disk boot failure when I turn it on.
My Philips 170B when turned on just stays on a black screen with the writing saying Disk boot failure. What does this mean?
  • tkrause Jan 07, 2008
    There is no floppy disk or cd in the drive. If the hard drive has failed, is there away to fix it?
    Thankyou
  • Anonymous Sep 18, 2008
    when i open my computer it read as disk boot failure, help me solve it
    President:
  • 4,402 Answers
Hard drive failed or you have a cd in or floppy in the drive.
Posted on Jan 07, 2008
  • Cary Farah
    Cary Farah Jan 07, 2008
    replace the hard drive and load new OS should have a disk (emergency) that came with it.
6ya staff
SOURCE:
Once powered on it goes to black screen and says - INVALID SYSTEM DISC,replace the disc, and then press any key.
Are you sure the BIOS is set to boot from hard disk?
It looks like it is trying to boot from network (PXE) and then from floppy disk.
Jan 04, 2014 | Computers & Internet
When I turn the computer on, I get the following message: PXE-E61 media test failure, check cable PXE-M0F exiting intel boot agent Reboot and select proper boot device or insert boot media in selected...
This happens when the BIOS can't find the hard disk. If you're lucky it's just the hard disk that has failed, if you're not it's the motherboard itself the one that failed.
To find out which replace the hard disk with a good one then try to boot in th BIOS - if you can it's the hard disk, if you can't it's the motherboard.
Nov 26, 2010 | Gateway 510 X (10272197) PC Desktop
My compaq computer turns on and then it goes to a black screen for a couple seconds, then it says : 'dsk boot failure, inster disk,then press enter' What disk ?!?
DISCONECT AND CONECT YOUR HARD DRIVE IT WORKS SOME TIMES MY BE CONECTOR CABLE ARE MISS IF NOT MAY BE YOUR HARD DRIVE ARE BAD.
Nov 23, 2010 | Computers & Internet
Disk Boot Failure
Any system can be recovered, although it depends on what is wrong.. this error can mean no info on the hard disk, or damaged hd...more than likely whoever had the computer erased it for data's sake...I would've...get an os and load it.
Aug 08, 2009 | Computers & Internet
Startup repair won't run
"Unmountable boot volume" this problem is your hard disk partition which is failure to recognize & identify the operating system running on the hard disk. Reformat your hard disk and put another operating system to run again your computer.
Jul 27, 2009 | Computers & Internet
Volume Control Bar does not go away
IN THE SETTING OF THE COMPUTER SOME WHERE IN THE SETUP OF THE COMPUTER YOU CHECK A BOX NO ON PERPOSE JUST BY ACCENDLY PICKING IT AND NOT UNDERSTANDING WHAT THEY MENT IN THE BOIS, INTER NET OPTIONS OR YOU MAY HAVE TO GO INTO THE BOOT LOG AND UNCHECK THE BOX FOR BOOT SEQUENCE SETTINGS,SYSTEM CONFIGURATION, BOOT OR STARTUP FILES
REBOOT SYSTEM YOU MAY HAVE TO DO THIS SEVERILY TIMES
ROD
YOU MAY HAVE REGEDIT
IF YOU NEED THAT TYPE OF ASSISTANCE I MAYBE ABLE TO HELP YOU BUT I PERFER YOU GO TO SOMEONE THAT DOES COMPUTER PROGRAMMING
ROD
Feb 09, 2009 | Philips Business 170B 17" Flat Panel LCD...
Computer not booting up
hiiiiiiii ther
how r u ??
the boot disk is any OS bootble CD or disk start up
plz tell me more so i can hellp u
what is ur machine ?
what is teh problem ? is it running slow or u need to boot ?
and if u need any further assistance email me
u take care and have fun
salammmmmm {bye in arabic }
p.s rate me thanks
Nov 25, 2008 | HP Compaq Evo n610c Notebook
"Disc Boot Failure" upon powering up the compaq
your harddisk is not detected.
open your cpu case.
then reattch the power code and datacode to hard disk.
Nov 03, 2008 | Compaq Presario S6300NX PC Desktop
My hp compact presario will no boot it is saying boot failure insert disk error message is on black screen and I cannot find my system disk
Did you check to make sure you don't have any discs, cd's or floppy discs in the pc when you turn the machine on?
May 11, 2008 | Computers & Internet
Philips 170B5CB 17" LCD Monitor Logo
208 people viewed this question
Top Philips Computers & Internet Experts
Ekse
Herb Box
Herb Box
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
