Question about HP OfficeJet G55 All-In-One InkJet Printer
Scanner failiure on HP Officejet g55
My All-in-One works fine as a printer - documents sent from the computer print out. But when I go to make copies, I get an error message that says "Scanner Failure." The solution to power down and up no longer works (it did at one time). I have not upgraded any software or made other changes from when it was working. Can't I just replace a part instead of buying a new machine, like HP wants me to do when I contact customer support?
  • 6 more comments
  • Anonymous Feb 13, 2008
  • Anonymous Feb 22, 2008
    What a piece of crap. I too have the same problem "scanner failure". I unistall and reinstall the CD and it works for a little while, but soon after the same thing
  • Anonymous Mar 14, 2008
    My Hewlett Packard OfficeJet G55 works fine if I print from the computer, but when I try to make a copy I get a "SCANNER FAILURE" message and I am instructed to turn the printer off and on. This does nothing but cause agravation. Dose anyone have a solution?
  • Anonymous Jun 06, 2008
    I have the same problem since I went to windows xp.
  • Anonymous Feb 11, 2009
    please hellp me for scaner failere hp g55 can you send the solve in my maile addres please
  • Dave Tosty
    Dave Tosty Mar 09, 2009
    My HP G55 works fine as a printer, but when I try to scan or copy, the scanner makes the initial pass, and then right after completing the return pass, I get a "scanner fault" error message. I am then instructed to shut down the printer and re-start it, which does not fix the problem. The bulb is working fine. When I copy something it will make one copy and print it before the error message appears. When I try to scan something, the image initially appears on my screen but then the scanner fault error message appears and locks everything up. Upon completing the return pass, the scanner sounds like it has either gone past a physical "stop" of some kind, or that a gear is jumping a cog. No such problem or noise happens when I use it strictly as a printer.
  • xplody May 18, 2009
    thanks Tosty, it worked perfect!! and only takes me 15 mins to fix this trouble
    Xplody from Argentina
  • roger_witdou
    roger_witdou Mar 26, 2017
    Bedankt Tosty, je bent de max!
    Problem Solver:
I had this same problem and finally found the solution. The first thing you have to do is dismantle the top portion of the printer to gain access to the part you need to fix. Here is a link to an HP website with photos showing you how to do this.
Once you have it dismantled, look toward the back of the unit, near the belt that moves the light bar back and forth and you will find a small, clear disc (about an inch in diameter) that is attached to the end of the shaft of a small motor. It almost looks like a tiny disc brake and caliper. I didn't have to replace any parts; all I had to do was clean that clear disc with a q-tip that was slightly dampened with plain water. You have to be very careful when cleaning it because the disc is very thin and fragile. Don't remove the disc, just clean it in place. I also used a small can of compressed air to carefully blow off any dust particles after I finished cleaning it. If you look at the disc with a magnifying glass, you will see that its outer edge is filled with very tiny index lines. From a distance, they almost look like a grey circle around the edge of the disc. Apparently, those tiny lines and the miniature caliper count the rotations of the motor as it spins, and this tells the printer where to stop the light bar after it has scanned or copied something. When it gets dirty with dust or cigarette smoke, it can't count properly, so the scanner just makes a grinding noise after a scan because it doesn't know where to stop, and you get the "Scanner Failure" error message. I carefully cleaned that disc, re-assembled the unit, and it works like new again. I hope this helps!
Posted on Apr 22, 2009
  • bonyon Jul 16, 2011
    Just tried this suggestion on my HP G55---it really works!!! Scan and copier back in business. Thanks so much.
    Brenda in KY
  • 147 Answers
If the light doesn't come on, you may be able to solder a new one in - total cost $15.
Posted on Sep 19, 2008
Every so often when I try to print a document I
Try reinstalling the printer driver, make sure you uninstall it first.
Jan 10, 2010 | HP OfficeJet G55 All-In-One InkJet Printer
My HP C5280 scanner is not picking up my computer. USB is connected and printing works fine, but the scanner isn't recognizing my cpu.
firstly check whether the copy is working or not if not follow the document
if it does make a copy
1.go to my computer
2.go to C:
3.go to program files
4.go to hp
5.go to digital imaging
6.go to bin for the file named hpqscnvw.exe and double click on it check whether you ca n scan from there or not if yes ............. uninstall and reinstall hp solution center and if it does not scan follow the steps below
8.uninstall and install the printer
this should work .....................................thank you
Oct 20, 2009 | HP OfficeJet 6310 All-in-One Printer...
Scanner won't work
did you try the copier function?if you can copy documents then the scanner is good,well if it wont works you cant print neither..but as you said you get a print out.reinstall it carefully and slowly..the logic board has no problem,just focus on the driver..
Sep 08, 2009 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 6210 will not copy, scan or fax. It will print documents from the computer. Any attempt to do the other 3 functions results in it being "busy" and cannot cancel, have to power it off.
Well if it is printing,the drivers are working fine.The copying,faxing and scanning mechanism use the same scanner to copy the image.It seems to be a problem with the scanner mechanism on the printer.Try a reset using the # and 6 buttons while plugging in the power cord.If it works well and good.If you want any further support, an online technician from techbuddies can help you for free.For this log on to
Jun 16, 2009 | HP OfficeJet 6210 All-In-One InkJet...
HP printer works, scanner says not connected
There is a seperate driver for the scanner. I reccomend running the CD that came with the printer. If you don't have the CD you can download the software from here
Just select your operating system and download the software.
May 31, 2008 | HP PhotoSmart C4280 Laser Printer
Computer doesn't print color
Have you tried to reinstall the printer driver?
Jun 29, 2007 | HP OfficeJet G55 All-In-One InkJet Printer
HP OfficeJet G55 All-In-One InkJet Printer Logo
2,192 people viewed this question
Ben Johnson
