Question about Sharp PRICOM 3100 (ARPS3100) Print Server
Need Print server for Sharp ARM45N
Please i Need Print server for Sharp ARM45N printer/copier/scanner.
Very urgent please.
0 characters
1 Points
You need to buy a new drum - cost about the same as new printer.
Some people (on ebay) sell a chip (a fuse actually) to reset the drum - Buy one provided your drum is still giving perfect prints
Jul 22, 2014 | Samsung Clx 3185 Multifunction Printer...
Problem scanning with a Xerox 4118x printer
you might have to configure the scanner manualy
May 24, 2010 | HP Jetdirect 175x Print Server
That is correct ..that print server does not support bi-directional functions.
Nov 09, 2009 | Linksys Wireless-G WPS54G Print Server
This is not a solution just a possible fly in the ointment. I have often found that scanners only work when attached directly to a computer. Scanning over the network is not a solution I have found. You can always share out the printer from the attached pc.
Jan 09, 2008 | D-Link DP 301U (DP-301U) Print Server
Configuring Printer
You posted this question THREE years ago.
Please provide more details.
Nov 13, 2007 | Print Servers
Sharp Copy Machine
You don't say if you are using a server/client network or a peer-to-peer. Go to START >printers and Faxes >Add a printer >Next and select A Network printer select Connect to the printer and then enter the path to the printer eg \\server\printer name
Oct 01, 2007 | Print Servers
Multifunction printer
For this print server it will not support any other function of the printer other than the printing part. If you are trying to use the scanner look for multifunction print server.
Aug 28, 2007 | D-Link DP 301U (DP-301U) Print Server
Emulex NetQue Pro2 Print Server how do I connect to it
Your DHCP server will keep track of which MAC Addresses have been given what IP addresses. From there, find the IP address of your Print Server. Ping the IP address to confirm IP connectivity between your computer and the print server. You should then be able to upgrade the firmware.
Oct 04, 2006 | Emulex NetQue Pro2 (NP02) Print Server
Sharp PRICOM 3100 (ARPS3100) Print Server Logo
128 people viewed this question
Top Sharp Print Servers Experts
old marine
old marine
Are you a Sharp Print Server Expert? Answer questions, earn points and help others
