Question about RCA P52939 52" Rear Projection Television
NO POWER RCA TV WON'T TURN ON HAD NO PREVIOUS PROBLEMS. FINE ONE DAY NO POWER THE NEXT
  • 9 more comments
  • nopower Jan 07, 2008
    NO clicking No flashing.....No Nothing..........
  • JTMcD Jan 08, 2008
    Same exact thing happened to mine today.
  • Anonymous Jan 12, 2008
    Mine did the same thing today. I also noticed on other sites problems with power supply started coming up in late 2007. May be age related?
  • Anonymous Feb 21, 2008
    The set turns on for approximately 15 to 20 seconds, then goes dead.
  • rainward1 Aug 04, 2008
    My tv was fine a couple of days ago and now does not work, there's nothing. please help, it is only 5 years old. I did unplug it, checked all connections and plugged back in still nothing, there seems to be a ticking sound though, don't know if this is just the satellite box or what?
  • Anonymous Sep 07, 2008
    My RCA TV will not turn on at all, Previous to turning off by itself, then suddenly it wont do anything, no sound no picture, no anything what can I do ?
  • Anonymous Oct 14, 2008
    when you press the power button, light comes on but then goes off and continues to do so several times. Finally after pressing the button several times the power will come on. But acts as if it doesnt want to come on.
  • illassua Oct 28, 2008
    i have the same problem. my rca turned off one day and wont come back on. there seems to be a ticking noise when i plug it in but wont respond to any buttons or power on.
  • j_dawg_69 Dec 07, 2008
    i plug it in and push power button and it makes a noise about 3 time and the light by the power button flashes each time
  • jessicarabbi Jan 11, 2009
    my tv makes a ticking noise when pluged in. Doesn't turn on at all, just ticking noise. If someone knows what this is please let me know. Thanks
  • srtreece Feb 04, 2009
    My tv started shutting off and then on. Now nothing, but a ticking sound. I see from the posts below it could possibly be a transformer or power supply - any ideas on the cost to fix or just buy a newer model?
Hv distribution box
Posted on May 26, 2008
I don't get a clik or flash of any kind. Opened the back and looked at the fuse, don't see a problem there and rechecked the outlet as well.
Posted on Jan 12, 2008
  • Anonymous Jan 24, 2008
    I sent it in. Turns out it is the transformer. Looks like age caught up. Similar problmes starting on various websites in November 2007.
    President:
  • 4,402 Answers
Does it click at all or led flash? if so how many times?
Posted on Jan 07, 2008
6ya staff
SOURCE:
Rca tv won't power on, red display light blinks on and off
Its more than likley a power supply issue bad caps or bad regulator etc. Replacing the power supply board may solve the issue for you. You can get replacement power supply board from www.tvcircuitboards.com
Jan 12, 2013 | RCA L42WD22 42 in. LCD Television
Function problems
Try an other remote control.
Jun 02, 2012 | Dynatron MR200 Remote Control
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
My 1995 RCA 52
Replace capacitors in power supply,( 4 cap. ) 2.2uf 100V, 39uf 100V, 470uf 25V, Ready!!
Apr 25, 2008 | RCA P52926 52" Rear Projection Television
Power problems
Most likely the power supply. The part number is 270530 and cost around $130. You would need a volt meter to test.
Mar 30, 2008 | RCA L26W11 26 in. HD-Ready LCD Television
Not turning on again
try cleaning The air filter in your set. It may be a thermal problem due to a clogged air filter.
Jan 19, 2008 | RCA HD61LPW42 61" Rear Projection HDTV
RCA P50830BL will not turn on
You have a shorte chopper diode, on main board look in middle of BD. You will need to change Horizontal output and Block blue caps and big Diode.
Nov 26, 2007 | RCA P50830BL 50" Rear Projection...
RCA 52in HDTV
If this set is under a warranty period or the manufacter warranty do not attempt to touch set as they will blame you if you attaempt to open set. Call the agent who serviced it and if they refuse to take care of the problem contact the manufacturer
Mar 24, 2006 | RCA HD52W58 52" TV
RCA P52939 52" Rear Projection Television Logo
280 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
