Question about Maytag Neptune MAH9700 Front Load Washer
Maytag Neptune Error COde "nd"
I keep getting the error code "nd" in the middle of my wash cycle. What does this mean? Also, the washer does not completely drain all of the water out upon completion of the cycle, leaving the clothes wet.
  • 6 more comments
  • Anonymous Dec 18, 2008
    ND ERROR.WASHER STOPED IN THE MIDDLE OF CYCLE
  • Anonymous Feb 14, 2009
    My wife loaded some bathroom floor mats that used have sticky rubber surface eon the bottom. Eventually they wore off and started peeling off. These rubber stuff came off like a powder and clogged all the pump inlet and outlet.
    I first cleaned the hose from the water pump output. It didn't fix the issue. You should clean the pump's inlet inlet pipe also (that connects to the the washing drum).
  • Gary Koepke Jul 04, 2012
    woo hoo, $0.31, a quarter, a nickle and a penny all stuck in or around the pump. I found the quarter blocking the inlet side of the pump. I took it out and put everything back together. No luck, same problem. I took the pump off again and found a penny in the outlet hose, put it together again and still didnt work. took the pump off the third time and finally found the nickle in the pump itself. Best pay i ever got for working on my own stuff. thanks for the info and help on this site.
  • l_just
    l_just Aug 06, 2012
    My husband has taken tbe pump apart - there was no clog. Only problem we could find is that the propeller inside the pump had come loose. Now he's trying to get it back on, but it won't stay. Any suggestions?
  • Anonymous Mar 21, 2014
    It stopped with 9 min left in cycle and now has error code nd and won't unlock.
  • Anonymous Mar 22, 2014
    nd code
    not finishing drain cycle code nd
  • Russdanes Apr 17, 2016
    This worked like a champ. Disconnected power. Took off the back panel. Disconnected the hoses. Vacuumed up the water. Disconnected wire to pump. Removed pump and inspected with a flash light from both sides. Water pump had a small rock lodged inside preventing the pump blade from turning. Took a bit to get it out but once I did I slapped it all back together and powered it up. Granted I needed to run through a full cycle as it would not just start from spin cycle like I first tried. The whole thing took 20-25 minutes. It would have been faster had I brought the right sockets into the basement with me the first go around. This fix may have saved me $100-150 or more if the repair guy was not on the up and up. Thank you everyone.
I had the exact same problem. nd code (no-drain) at the end of the cycle and when I opened the door the machine was still full of water. I took the back panel off the washer and disconnected the drain hose from the pump. (You're going to get quite a bit of water gushing out at you so be prepared with towels or a shop vac.) At this point you should see a little rubber disc over the end of the section you just exposed on the pump. This is a little drain flap. Just lift it up and you should be able to see into the pump a little bit. At this point I poked around in there with my finger and found a hair pin stuck in the pump! I wasn't able to get it out from this end of the pump so I disconnected the big rubber boot which connects the wash drum to the pump. Then I was able to twist the pump (counter clock-wise) and release it from the washer base. I didn't have to disconnect any wires and was then able to see into the other side of the pump and pull the hairpin out. Put everything back together and it's worked fine ever since. I've never even looked inside a washing machine before but it really was really fairly simple. Now my husband really does think I'm a domestic Goddess. I said he should take me out to dinner with the money we saved on a service call!!
Posted on Mar 18, 2009
  • 2 more comments
  • Ben Pine Jan 14, 2013
    This exactly happened to me! Thank you for your help!
  • tomfuller2
    tomfuller2 Mar 23, 2013
    Kudos to this post. I removed the large back panel, unscrewed the clamp holding the black drain pipe from the pump and shining a flashlight in was able to see a piece of metal from a bra. I freed it, then undid the pump just to double check that it moved freely. I used a shop vac to remove water from the washer but there was plenty left to get on the floor when I removed the drain pipe from the other side of the pump. Thank you so much!
  • Pete Bruno
    Pete Bruno Jan 31, 2014
    yes thank you, pulled the underwire from the bra out with a magnet
  • prem mathew Dec 17, 2014
    That dinner thing was just great......
    President:
  • 1,294 Answers
Press "end of cycle" to get machine to normal. Then plug off the wall. Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 07, 2008
I had the same problem. I removed the back panel, disconnected the hoses, disconnected the electrical terminal (unplugged unit) and removed the three bolts to remove the pump. Then I pulled back flap and there it was a nickel laying flat. I pressed on it with a screwdriver and it flipped around so I could get it out with a pair of needle nose pliers. I put it back together it worked like a charm. It took me less then 10 minutes saving me a $75 service call. Thanks to everyone for posting your fixes.
Posted on Jul 02, 2009
I wanted to share my experience since it somewhat differs from what I've read in the previous posts. I experienced the "nd error" and I decided to follow what I read and check the pump to see if an object was stuck there.
When I disconnected the pipe from the pump I didn't find anything, but I noticed there was a rubber piece at the end of pump that opens and closes like a valve. It was closed so I opened it to see if there was an object behind it. Afterward I noticed the rubber valve stayed slightly open but I didn't think anything of it.
I figured the problem must be electrical since I didn't find anything stuck. After putting everything back, I decided to try the drain function and, surprisingly, it worked. I believe the rubber valve was the problem. I believe it is supposed to be in a slightly open position to allow the water to have easy passage to the pipe.
Also a word of advice to avoid wasting time. The pump is at the front of the machine. You can access it by unscrewing the plastic cover on the bottom. I wasted a hour taking the plate off the back and trying to position my hand to free the pipe from the pump. Hopefully knowing this will save someone time.
Ken
Posted on Apr 18, 2010
  • Bisnetti Sep 11, 2011
    The rubber flapper you are referring to is a Check Valve. This prevents dirty water from backing into the pump and soiling the clothing further. This should be closed when there is no flow and open when the pump turns on.
  • Jill Baa Sep 15, 2013
    Hi there --- please help! How do I access it through the bottom??? I have unscrewed the plastic bottom panel at the front but there's still a metal plate in place and I can't see a drain pump.
As previously posted-the inlet side of the pump(not the port connected to the drain hose)-accessible from the back of the washer after removing the large sheet metal cover revealed a mass of rubber chips-from frequent bath rug washings I suspect, a quarter-sized perfectly to completely block the inlet, and the icing on the cake-a guitar pick wedged in the blades. Worth mentioning though is the razor-sharp edge where the back of the washer has been cut open for the large sheet metal cover-I didn't realize until after I noticed blood all over the tools that my hands were cut in a dozen places as if I had swiped over them with a blade-be very careful and draping a towel over this edge would be a good idea!Maytag Neptune Error COde 962b4cc.jpg
Posted on Oct 28, 2010
Thank you so much for these postings! Saved a huge service call - I removed the broken piece of toothpick from the pump in less than 15 minutes. The hardest part was pulling the washer away from the wall.
Posted on Dec 09, 2009
  • Sunset106 Aug 20, 2011
    Thanks everyone!! I found a quarter in my pump. My husband is very impressed with my appliance repair skills. :)
  • kjbradley7 Aug 30, 2011
    Same nickle stuck in the inlet side problem with me. thought I was on top of it except when I closed it up and the pump didn't operate.....forgot to clip the plug on.. : [
Same problem here! Only it was the lens from a toy flashlight. I told my wife - just think if it weren't for the Internet we'd be shelling out $60 or more for something so simple!
Posted on Mar 29, 2009
My husband and I tackled the "nd" washer problem together. We removed both hoses and the drain pump from the bottom of the washer. But neither of the hoses were clogged. Looking down into the pump impeller, we saw a small red "something". We removed the pump motor from the pump housing to get to the impeller. A large rubber band was wrapped around the back of the impeller. It's running great now! Thanks everyone for your postings!
Posted on Jan 06, 2010
  • Reid Siebert Dec 11, 2011
    Mine had a rubber band wadded up in the same place!
Inglis IFW7200TW error code ND. Unplug the machine from the power outlet. As indicated on this site I removed the back panel of the washing machine - stainless steel with 2 screws. Unhooked the drain hose (grey) and flushed it in the sink. Had lots of towels on hand to catch the water. While the hose was plugged this was not the only problem. The drain hose is attached to a type of motor. I reached inside the motor and low and behold there was a bobby pin stuck in there which prevented the motor from spinning. Once I removed the bobby pin and reconnected everything the machine works fine. BE CAREFUL though... When I was replaced the hose I sliced my hand open on the side of the machine. It is very sharp! Thanks to all who posted on this site!
Posted on Jul 01, 2012
Error code "nd" came up, washer full of water. Husband took the shop vac and vacuumed all water out of inside. Then he took the drain hose out of the wall where water goes out of washer and sucked the hose out removing all water from insides of machine and low and behold a bandaid wrapper came out, works great now and we did not have to take anything apart.
Posted on Jan 06, 2011
Thanks to everyone who made these postings! Only we didn't have a coin or bobbie pin, it was a bra wire - in pieces! How are these things getting in there!
Posted on Nov 26, 2009
The solutions suggested were clear and easy to follow. But when I found and opened up the pump, I found it completely clear: no nickels, no guitar picks, no bobby pins. What was really mystifying was that the washer displayed the "nd" code (no drain) but it still dumped a lot of water on the laundry room floor. Probably a 1/4 inch deep. If the machine knows that there is a drain problem, why does it keep admitting water? Took off the door and front panel, couldn't find anything amiss. Called appliance repair. Repairman poked at the various cycles; "spin" and "rinse" displayed the right number of minutes, but the longer cycles displayed way more minutes than what should have been. He said the machine needed "a new brain" (consistent with dropping water on the floor under an "nd" situation) and said it would be $250 at least. So instead of getting a brain transplant or buying a new machine, we activated the washing machine that we had brought with us when we moved some years before.
Posted on Sep 15, 2012
I keep getting the error code PF. What does this mean?
Posted on Aug 31, 2012
Thank you much! I had several coins in the external hose (house going from pump to drain soource) and a penny wedged in the pump's propeller. I disconnected the electrical wire to the pump, unbolted the pump and its platform from the base of the washer, then disassembled the pipe housing of the pump which exposed the propeller (and there was the culprit penny, wedged behind the propeller). One of the blades was halfway chipped but it seems not hinder its performance for now. working as good as new!!!!!!
Posted on Mar 26, 2012
We received the error code "nd" and luckily happened upon this site while searching for a solution. It worked! We detached both hoses from the pump and found a long piece of metal lodged inside both the pump and in one of the hoses which prevented the fan inside the pump from roating to allow the water to drain properly. Washer works like a charm now. Thanks.
Posted on Oct 17, 2010
  • fix it pleas Oct 17, 2010
    I also would like to add that if your drain pump in fact broken, you can possibly find a replacement on ebay -- it is certainly cheaper than having the repairman come out or buying a new washer.
Thanks dilorio and others, our prob was same, only the culprit was a bobbie pin!! Now it works like a charm. thanks a million!! Virtual drinks on me!
Posted on Jul 12, 2009
    Problem Solver:
  • 11 Answers
The drain hose can also have an object in it. Remove the hose and run a rod or something through it that is nearly the same diameter. Mine had a dime in it. Be sure to squeeze the intake boot and dump the objects out of it. Mine had several coins in it waiting to plug it again. The little flap on the pump is the anti backflow valve. It is a necessary item. The 3 impeller blades can break off and the pump won't work and must be replaced.
Posted on Oct 29, 2014
    New Friend:
I followed all the advice, drain pump works if you apply power externally, but does not work cycles controlled from the panel. what is the problem?
Posted on May 12, 2014
    New Friend:
So far we have cleaned out the hose, the pump and found no coins, hair pins or anything lodged in anywhere.... seems the drain pump works or starts to work and stops... as long as we **** the water from the drain hose using a shop vac during it's rinse cycle it continues to work.... very time consuming and discouraging... any suggestions?
Posted on Oct 14, 2013
    New Friend:
These posts have been very helpful...but I have only partially solved the issue with my maytag neptune front load washer by troubleshooting the drain pump.
My steps are as follows:
1. Unplug washing machine from power source.
2. Pull washing machine away from the wall.
3. Remove 3 screws holding the back panel in place. Remove back panel.
4. Locate drain pump at bottom left of the washer. Un-snap the pump wiring harness. Open the clamps on the drain hose and the drum side of the pump. Pull hoses off pump. Remove 3 bolts holding the pump in place.
5. Inspect pump and hoses for obstructions. Nothing in the pump, and I knew the hoses were free of obstructions because the water flowed freely when the drain hose was placed on the floor. Luckily we have a drain hole in our laundry room floor, otherwise it would be advisable to have a shop vac or plenty of towels handy. My assumption was that the pump was faulty.
6. Make phone calls to find a replacement drain pump. I was able to find a new pump locally at Reliable on Bank Street Ottawa - $99 plus tax for the unit. This seemed like a reasonable cost to me - I know it would cost at least that for a service call...living in a rural town outside Ottawa.
7. It took me less than 5 minutes to install the new pump. Reverse removal steps to install and connect the new pump, and then I connected the washer back to power. I tried a rinse and spin cycle with an empty machine - this worked fine with no error messages resulting. Success I thought....since this was not possible before installing the new pump. However, when I try the Quick Wash or any other wash cycle, with a load of laundry it takes much longer (double the time or longer) than normal for the wash to complete and some times the nd - no drain error occurs in the middle of the cycle. The nd error at this point is easily solved by stopping and starting the wash cycle. I notice that each wash cycle seems to get stuck around the 9 minute mark. It's my assumption that the control panel is also defective, which probably caused the initial burn-out of the original drain pump. Or maybe the original drain pump burned out and damaged the control panel - who knows! From what I research online a replacement control panel can cost up to $500. It seems pretty expensive given that a new front load washer starts at $699 and up. So, I think I'll take the time before the replacement pump burns out to shop for a new washer.
Posted on May 07, 2013
    New Friend:
This site rocks! I was nearly ready to call-in a pro when I found Fix 'ya on a Google search. Instead of finding a hair clip or a nickel wedged in the motor, I found a quarter!
Now we're catching up on several loads of laundry and the machine is as good as new.
Thanks everyone!
Posted on Feb 10, 2013
  • Dave Feb 10, 2013
    Thanks everyone!
Thanks for all on posting their findings! My husband and I had to mop up a lot of water when removing the pump! My husband found a hair pin in the pump and removed it.
Posted on Dec 10, 2011
Same as all the others. Coin was stuck. Unfortunately, my husband didn't listen and pushed it all the way back into the pump so we had to remove the pump to get it out. Not a big deal, just took a few more minutes. Thanks for all your posts. It was 3:00am when this happened and I was leaving for a trip at 6:00am. Nothing like waiting for the last minute to do laundry!! ;-)
Posted on Jul 17, 2010
Same Issue here. Removed the pump and impeller. There was a Nickel clogging the drain pipe. Save $$$'s on a service call. This site rocks!
Posted on Apr 06, 2010
On EASTER no less..... Made for an interesting morning. Thanks everyone for saving me $$$.
Posted on Apr 04, 2010
Same problem here... the above solutions helped! Mine was a color grabber sheet that was lodged in the pump! (size of a baby's washcloth!) How are these things getting through!!!!!!!!!
Posted on Jan 24, 2010
I had a similar problem until it finally gave up draining altogether. I took the drain pump apart and found that a quarter was jammed in the pump after it broke a vain off. I don't know how the quarter got past the basket but this was definitely my problem.
Posted on Mar 29, 2008
  • 3 Answers
Symptom/problem
Posted on Oct 03, 2010
3 Suggested Answers
SOURCE:
aborcass
  • 2651 Answers
SOURCE: Maytag Neptune Error COde "nd"
"nd" refers to a No Drain issue . check for rstriction in pump assy, restricted drain hose loose wire at pump, bad pump
Posted on Mar 03, 2008
This is now the 3rd time this has happened. The 1st 2 times it cost me ~$100 to have a technician come in and fix.
This time, I did it easily. For my Maytag Neptune washer, I removed the back panel (2 screws). On the bottom tray is the water discharge pump. On the output side of the pump there is a small cavity under the rubber flapper where a nickle fits perfectly. I removed the nickle, reattached the output drain line. started it up ...
and viola! the problem solved.
Posted on Jun 28, 2009
My Maytag Neptune washer has "np" flashing. The door is locked and the cycle is not complete
Are you sure this is not an nd and not an np flash code? If so then the code stands for no drain, likely something is clogging the washer pump inlet.
Aug 20, 2016 | Maytag Neptune Washing Machines
What does the code od mean?
The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Read more: Maytag Neptune Washer Error Codes ' eHow.com http://www.ehow.com/list_7170826_maytag-neptune-washer-error-codes.html#ixzz2GZKry68n
Dec 30, 2012 | Maytag Neptune MAH5500B Front Load Washer
Nd keeps coming up
The ND error code means NO DRAIN. To see why the ND code keeps coming up the drain pump needs to be checked for a partial blockage.
GENE
Sep 13, 2011 | Maytag Neptune FAV6800AW Top Load Washer
May tag Neptune showing codes
Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
Do
Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
FL
The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
Sd
The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
PF
The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
Nd
The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
LO
The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
Lr
The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional. Maytag Neptune Priority One Service: (888) 462-9824
NF
The "nF" code appears when the washing machine has tried to fill with water and has failed. Verify that the inlet hoses aren't kinked and that the faucets are fully open.
Od
Other Codes
* If your Maytag Neptune washing machine displays any codes that are not listed above, contact Maytag Neptune Priority One Service for assistance. Maytag Neptune Priority One Service: (888) 462-9824
Hope this helps (remember to rate and comment this answer).
Apr 03, 2011 | Maytag Dryers
I am getting the nd error
you can get help in this matter at appliancerepairplanet.vstore.ca and you can get a sevice manual and help in this matter
Dec 15, 2010 | Maytag Neptune MAH6700A Front Load Washer
If you get the FL how do you get the door to open??
  1. Your Maytag Neptune washing machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
  2. Do
  3. Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
  4. FL
  5. The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
  6. Sd
  7. The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
  8. PF
  9. The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
  10. Nd
  11. The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
  12. LO
  13. The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
  14. Lr
  15. The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional.
Dec 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Someone put some heavy things in it and it stopped mid-cycle. We removed the heavy objects, and then attempted to drain the leftover water by putting it on "rinse and spin." It never really...
The ND error code on a digital Neptune front load washer. The ND code means 'No Drain' and it is probably just something caught in the pump. Sometimes this is a early sign of the pump going out or a control board issue.
Nov 23, 2010 | Maytag Neptune MAH5500B Front Load Washer
I keep getting the error code nd on my Maytag neptune whats this mean?
Error ND means that there is a drain problem.
Either there is debris inside drain pump hose, or the pump itself is faulty.
The problem is fixed accessing the drain pump hose to check for a blockage.
Keep a container ready to collect water when you undo pump hose.
Parts and diagrams available here.
Nov 14, 2009 | Maytag Neptune MAH9700 Front Load Washer
Stops mid-cycle, does not drain, displays nd error code?
Hello.
That code is telling you that the unit is draining to slow. After 15 minutes it is not below the low water level and will not spin out. The best repair for this is to replaced the pump on your unit.
Jul 15, 2009 | Maytag Neptune MAH9700 Front Load Washer
Feb 28, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH9700 Front Load Washer Logo
31,630 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
