Replacing lid switch on Kenmore 80 series washing machine
One of your guys has told me that I probably have a bad lid switch, because my washing machine stops running in the middle of a cycle (won't rinse completely or go through spin mode).
Can you tell me how to replace the lid switch & where I might find the part (Lowe's, Home Depot, etc.)?
Thanks,
Joel
  • 1 more comment
  • DrJRB Jan 07, 2008
    I know where it is; I need to know how to replace it & where to find the part. Is it hooked up electrically inside the panel or what?
  • krdillon99 Aug 20, 2008
    need to know how to replace lid switch on kenmore 80 series washer model # 110.29842991
  • Anonymous May 01, 2009
    HOW DO YOU OPEN THE CONSOLE?
  • 283 Answers
It's attached under the top panel but depending on the year of manufacture it could be on the right, below a hole where the strike comes down or on the left rear under the console.
Posted on Jan 07, 2008
  • GORDON'S APPLIANCE SERVICE
    If it's the older type it mounts to the right side of the lid opening with two screws. A long "tail" comes with the replacement. It's easier to remove the cabinet to get to the rest of the harness.
    If it's the type that mounts in the left rear just remove the console and unclip the switch
6ya staff
SOURCE:
Kenmore 80 series fills with water then doesn't
the lid switch under the control panels bad replace it and it will again wash,they just unsnap out of the top of the cabinet after you remove the control panel
Jul 07, 2011 | Kenmore Washing Machines
How do you remove the top off the washing machine to replace the lid switch in a kenmore super capacity 80 series?
The following link explains step-by-step how to replace the lid switch on a Kenmore top loader:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
If you have any questions about this repair, please post back and let me know. I hope you find this information helpful.
Oct 26, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Can I replace the lid switch? is it expensive? How do I replace it?Kenmore 80 series washing machine.
you can replace the lid switch. Go to searspartsdirect.com and put in your model #. it will pull up part #s and diagrams. You will probably have to take the cab off, which can be tricky. first unscrew the backguard and flip it back. You should be able to tip the cab forward now. The lidswitch will be attached to the cab, and there will be a plug attached to the backguard.
Nov 19, 2009 | Kenmore Washing Machines
Kenmore Series 80 washing machine won't drain after wash cycle. The machine just stops.
Check the lid switch under the edge of the top where the lid closes. When you are about 1 inch from closing the lid you should here a little click sound. That is the switch closing. I fyou do not here the click then the switch is bad.
Sep 01, 2009 | Kenmore Washing Machines
Kenmore washing machine 80 Series 110 20802 990 Will not agitate or spin"
You need to replace the Kenmore Washer Lid Switch. I had the same problem so being lazy I would just push down on the washer's lid and it would push the lid switch further down. making the water drain. after a while I just replaced the lid switch.
Apr 22, 2009 | Washing Machines
Kenmore series 70 washer won't stop agitating when lid Is lifted.
I have a Series 80 and when I lift the lid it does not stop aggitating when in wash mode. When I lift the lid it does stop spinning when in rinse mode. As designed.
To stop wash-mode aggitation at lid-lift, using the existing lid switch and other electrical components, is not easy and not recommended. I can think of a way to do it (triple-pole lid switch) but I will not detail the idea .. for safety concerns.
To stop aggitation, simply use the main settings dial control. You'll save money and possibly prevent a fire hazard!
Jan 23, 2009 | Kenmore 22422 Top Load Washer
80 SERIES NOT SPINNING
It wont be the capacitor or the motor wouldnt work on the wash cycle. It could be the lid switch, & yes you could bypass the switch to prove if it is open circuit, you may even find a burned out wire to the switch. TURN THE POWER OFF FIRST THOUGH!!
Oct 22, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
2,115 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
